请选择 进入手机版 | 继续访问电脑版
查看: 4159|回复: 10
[技术分享] lua + FatFS,实现lua调用其他lua文件,需要重载c库文件操作函数
发表于 2020-4-24 14:59:21 | 显示全部楼层 |阅读模式
重载如下C库的文件操作函数,将标准文件操作函数和FatFS文件操作函数关联起来。
目前已实现lua中执行dofile函数加载其他文件
dofile("0:/H7-TOOL/Lua/产品测试/TestRS232.lua")
TestErr()
需要重写的函数名是从 C:\Keil_v5\ARM\ARMCC\include\stdio.h 中找出来的,然后查看lua源码调用哪些函数,一一比对。
--------------需要重载的函数如下(只做了读接口,写功能暂时未做) -----------------------
extern _ARMABI int remove(const char * /*filename*/) __attribute__((__nonnull__(1)));
    * causes the file whose name is the string pointed to by filename to be
    * removed. Subsequent attempts to open the file will fail, unless it is
    * created anew. If the file is open, the behaviour of the remove function
    * is implementation-defined.
    * Returns: zero if the operation succeeds, nonzero if it fails.
extern _ARMABI int rename(const char * /*old*/, const char * /*new*/) __attribute__((__nonnull__(1,2)));
    * causes the file whose name is the string pointed to by old to be
    * henceforth known by the name given by the string pointed to by new. The
    * file named old is effectively removed. If a file named by the string
    * pointed to by new exists prior to the call of the rename function, the
    * behaviour is implementation-defined.
    * Returns: zero if the operation succeeds, nonzero if it fails, in which
    *          case if the file existed previously it is still known by its
    *          original name.
extern _ARMABI FILE *tmpfile(void);
    * creates a temporary binary file that will be automatically removed when
    * it is closed or at program termination. The file is opened for update.
    * Returns: a pointer to the stream of the file that it created. If the file
    *          cannot be created, a null pointer is returned.
extern _ARMABI char *tmpnam(char * /*s*/);
    * generates a string that is not the same as the name of an existing file.
    * The tmpnam function generates a different string each time it is called,
    * up to TMP_MAX times. If it is called more than TMP_MAX times, the
    * Returns: If the argument is a null pointer, the tmpnam function leaves
    *          its result in an internal static object and returns a pointer to
    *          that object. Subsequent calls to the tmpnam function may modify
    *          the same object. if the argument is not a null pointer, it is
    *          assumed to point to an array of at least L_tmpnam characters;
    *          the tmpnam function writes its result in that array and returns
    *          the argument as its value.
//extern _ARMABI int fclose(FILE * /*stream*/) __attribute__((__nonnull__(1)));
_ARMABI int fclose(FILE * stream)
    * causes the stream pointed to by stream to be flushed and the associated
    * file to be closed. Any unwritten buffered data for the stream are
    * delivered to the host environment to be written to the file; any unread
    * buffered data are discarded. The stream is disassociated from the file.
    * If the associated buffer was automatically allocated, it is deallocated.
    * Returns: zero if the stream was succesfully closed, or nonzero if any
    *          errors were detected or if the stream was already closed.
    FIL *fp;
    FRESULT result;
    fp = (FIL *)stream;
    result = f_close(fp);
    if (result != FR_OK)
        return result;
    return 0;
extern _ARMABI int fflush(FILE * /*stream*/);
    * If the stream points to an output or update stream in which the most
    * recent operation was output, the fflush function causes any unwritten
    * data for that stream to be delivered to the host environment to be
    * written to the file. If the stream points to an input or update stream,
    * the fflush function undoes the effect of any preceding ungetc operation
    * on the stream.
    * Returns: nonzero if a write error occurs.
_ARMABI FILE *fopen(const char * filename /*filename*/,
                           const char * mode /*mode*/)
    * opens the file whose name is the string pointed to by filename, and
    * associates a stream with it.
    * The argument mode points to a string beginning with one of the following
    * sequences:
    * "r"         open text file for reading
    * "w"         create text file for writing, or truncate to zero length
    * "a"         append; open text file or create for writing at eof
    * "rb"        open binary file for reading
    * "wb"        create binary file for writing, or truncate to zero length
    * "ab"        append; open binary file or create for writing at eof
    * "r+"        open text file for update (reading and writing)
    * "w+"        create text file for update, or truncate to zero length
    * "a+"        append; open text file or create for update, writing at eof
    * "r+b"/"rb+" open binary file for update (reading and writing)
    * "w+b"/"wb+" create binary file for update, or truncate to zero length
    * "a+b"/"ab+" append; open binary file or create for update, writing at eof
    * Opening a file with read mode ('r' as the first character in the mode
    * argument) fails if the file does not exist or cannot be read.
    * Opening a file with append mode ('a' as the first character in the mode
    * argument) causes all subsequent writes to be forced to the current end of
    * file, regardless of intervening calls to the fseek function. In some
    * implementations, opening a binary file with append mode ('b' as the
    * second or third character in the mode argument) may initially position
    * the file position indicator beyond the last data written, because of the
    * NUL padding.
    * When a file is opened with update mode ('+' as the second or third
    * character in the mode argument), both input and output may be performed
    * on the associated stream. However, output may not be directly followed
    * by input without an intervening call to the fflush fuction or to a file
    * positioning function (fseek, fsetpos, or rewind), and input be not be
    * directly followed by output without an intervening call to the fflush
    * fuction or to a file positioning function, unless the input operation
    * encounters end-of-file. Opening a file with update mode may open or
    * create a binary stream in some implementations. When opened, a stream
    * is fully buffered if and only if it does not refer to an interactive
    * device. The error and end-of-file indicators for the stream are
    * cleared.
    * Returns: a pointer to the object controlling the stream. If the open
    *          operation fails, fopen returns a null pointer.
        fatfs官网有兼容方式定义格式
        http://elm-chan.org/fsw/ff/doc/open.html
        POSIX        FatFs
        "r"            FA_READ
        "r+"        FA_READ | FA_WRITE
        "w"            FA_CREATE_ALWAYS | FA_WRITE
        "w+"        FA_CREATE_ALWAYS | FA_WRITE | FA_READ
        "a"     FA_OPEN_APPEND | FA_WRITE
        "a+"    FA_OPEN_APPEND | FA_WRITE | FA_READ
        "wx"    FA_CREATE_NEW | FA_WRITE
        "w+x"   FA_CREATE_NEW | FA_WRITE | FA_READ
    FRESULT result;
    BYTE ff_mode;
    if (strcmp(mode, "r") == 0)         ff_mode = FA_READ;
    else if (strcmp(mode, "r+") == 0)   ff_mode = FA_READ | FA_WRITE;
    else if (strcmp(mode, "w") == 0)    ff_mode = FA_CREATE_ALWAYS | FA_WRITE;
    else if (strcmp(mode, "w+") == 0)   ff_mode = FA_CREATE_ALWAYS | FA_WRITE | FA_READ;
    else if (strcmp(mode, "a") == 0)    ff_mode = FA_OPEN_APPEND | FA_WRITE;
    else if (strcmp(mode, "a+") == 0)   ff_mode = FA_OPEN_APPEND | FA_WRITE | FA_READ;
    else if (strcmp(mode, "wx") == 0)   ff_mode = FA_CREATE_NEW | FA_WRITE;
    else if (strcmp(mode, "w+x") == 0)  ff_mode = FA_CREATE_NEW | FA_WRITE | FA_READ;
    /* 打开文件 */
    f_close(&g_file);
    result = f_open(&g_file, filename, ff_mode);
    if (result == FR_OK)
        return (FILE *)&g_file;
    return 0;
_ARMABI FILE *freopen(const char * filename /*filename*/,
                    const char * mode /*mode*/,
                    FILE * stream /*stream*/)
    * opens the file whose name is the string pointed to by filename and
    * associates the stream pointed to by stream with it. The mode argument is
    * used just as in the fopen function.
    * The freopen function first attempts to close any file that is associated
    * with the specified stream. Failure to close the file successfully is
    * ignored. The error and end-of-file indicators for the stream are cleared.
    * Returns: a null pointer if the operation fails. Otherwise, freopen
    *          returns the value of the stream.
    return 0;
extern _ARMABI void setbuf(FILE * __restrict /*stream*/,
                    char * __restrict /*buf*/) __attribute__((__nonnull__(1)));
    * Except that it returns no value, the setbuf function is equivalent to the
    * setvbuf function invoked with the values _IOFBF for mode and BUFSIZ for
    * size, or (if buf is a null pointer), with the value _IONBF for mode.
    * Returns: no value.
extern _ARMABI int setvbuf(FILE * __restrict /*stream*/,
                   char * __restrict /*buf*/,
                   int /*mode*/, size_t /*size*/) __attribute__((__nonnull__(1)));
    * may be used after the stream pointed to by stream has been associated
    * with an open file but before it is read or written. The argument mode
    * determines how stream will be buffered, as follows: _IOFBF causes
    * input/output to be fully buffered; _IOLBF causes output to be line
    * buffered (the buffer will be flushed when a new-line character is
    * written, when the buffer is full, or when input is requested); _IONBF
    * causes input/output to be completely unbuffered. If buf is not the null
    * pointer, the array it points to may be used instead of an automatically
    * allocated buffer (the buffer must have a lifetime at least as great as
    * the open stream, so the stream should be closed before a buffer that has
    * automatic storage duration is deallocated upon block exit). The argument
    * size specifies the size of the array. The contents of the array at any
    * time are indeterminate.
    * Returns: zero on success, or nonzero if an invalid value is given for
    *          mode or size, or if the request cannot be honoured.
extern _ARMABI size_t fread(void * ptr /*ptr*/,
                    size_t size/*size*/, size_t nmemb/*nmemb*/, FILE * stream /*stream*/)
    * reads into the array pointed to by ptr, up to nmemb members whose size is
    * specified by size, from the stream pointed to by stream. The file
    * position indicator (if defined) is advanced by the number of characters
    * successfully read. If an error occurs, the resulting value of the file
    * position indicator is indeterminate. If a partial member is read, its
    * value is indeterminate. The ferror or feof function shall be used to
    * distinguish between a read error and end-of-file.
    * Returns: the number of members successfully read, which may be less than
    *          nmemb if a read error or end-of-file is encountered. If size or
    *          nmemb is zero, fread returns zero and the contents of the array
    *          and the state of the stream remain unchanged.
    FRESULT result;
    uint32_t br = 0;
    FIL *fp;
    fp = (FIL *)stream;
    result = f_read(fp, ptr, nmemb,  &br);
        return br;
    return 0;
extern _ARMABI size_t fwrite(const void * __restrict /*ptr*/,
                    size_t /*size*/, size_t /*nmemb*/, FILE * __restrict /*stream*/) __attribute__((__nonnull__(1,4)));
    * writes, from the array pointed to by ptr up to nmemb members whose size
    * is specified by size, to the stream pointed to by stream. The file
    * successfully written. If an error occurs, the resulting value of the file
    * Returns: the number of members successfully written, which will be less
    *          than nmemb only if a write error is encountered.
extern _ARMABI int fseek(FILE * /*stream*/, long int /*offset*/, int /*whence*/) __attribute__((__nonnull__(1)));
    * sets the file position indicator for the stream pointed to by stream.
    * For a binary stream, the new position is at the signed number of
    * characters specified by offset away from the point specified by whence.
    * The specified point is the beginning of the file for SEEK_SET, the
    * current position in the file for SEEK_CUR, or end-of-file for SEEK_END.
    * A binary stream need not meaningfully support fseek calls with a whence
    * value of SEEK_END.
    * For a text stream, either offset shall be zero, or offset shall be a
    * value returned by an earlier call to the ftell function on the same
    * stream and whence shall be SEEK_SET.
    * The fseek function clears the end-of-file indicator and undoes any
    * effects of the ungetc function on the same stream. After an fseek call,
    * the next operation on an update stream may be either input or output.
    * Returns: nonzero only for a request that cannot be satisfied.
_ARMABI int fseek(FILE *stream, long int offset, int whence)
    return 0;
extern _ARMABI long int ftell(FILE * /*stream*/) __attribute__((__nonnull__(1)));
    * obtains the current value of the file position indicator for the stream
    * pointed to by stream. For a binary stream, the value is the number of
    * characters from the beginning of the file. For a text stream, the file
    * position indicator contains unspecified information, usable by the fseek
    * function for returning the file position indicator to its position at the
    * time of the ftell call; the difference between two such return values is
    * not necessarily a meaningful measure of the number of characters written
    * or read.
    * Returns: if successful, the current value of the file position indicator.
    *          On failure, the ftell function returns -1L and sets the integer
    *          expression errno to an implementation-defined nonzero value.
_ARMABI long int ftell(FILE *stream)
    FIL *fp;
    fp = (FIL *)stream;
    return fp->fptr;
extern _ARMABI void clearerr(FILE * /*stream*/) __attribute__((__nonnull__(1)));
    * clears the end-of-file and error indicators for the stream pointed to by
    * stream. These indicators are cleared only when the file is opened or by
    * an explicit call to the clearerr function or to the rewind function.
void clearerr(FILE *stream)
    FIL *fp;
    fp = (FIL *)stream;
    fp->err = 0;
extern _ARMABI int feof(FILE * /*stream*/) __attribute__((__nonnull__(1)));
    * tests the end-of-file indicator for the stream pointed to by stream.
    * Returns: nonzero iff the end-of-file indicator is set for stream.
_ARMABI int feof(FILE *stream)
    FIL *fp;
    fp = (FIL *)stream;
    if (fp->fptr >= fp->obj.objsize)
        return 1;
    return 0;
extern _ARMABI int ferror(FILE * /*stream*/) __attribute__((__nonnull__(1)));
    * tests the error indicator for the stream pointed to by stream.
    * Returns: nonzero iff the error indicator is set for stream.
_ARMABI int ferror(FILE *stream)
    FIL *fp;
    fp = (FIL *)stream;
    return fp->err;
*    函 数 名: fgetc
*    功能说明: 重定义getc函数,这样可以使用getchar函数从串口1输入数据
*    形    参: 无
*    返 回 值: 无
int fgetc(FILE *f)
    if (f == &__stdin)
        return 0;   /* sacan 标准输入,还未做 */
    else    /* 文件操作, lua dofile()会执行这个分支 */
        FRESULT result;
        uint32_t br = 0;
        FIL *fp;
        char buf[2];
        fp = (FIL *)f;
        result = f_read(fp, buf, 1,  &br);
            return buf[0];
        return 0;
*    函 数 名: fputc
*    功能说明: 重定义putc函数,这样可以使用printf函数从串口1打印输出
*    形    参: 无
*    返 回 值: 无
extern uint8_t USBCom_SendBuf(int _Port, uint8_t *_Buf, uint16_t _Len);
extern void lua_udp_SendBuf(uint8_t *_buf, uint16_t _len, uint16_t _port);
extern MEMO_T g_LuaMemo;
extern uint16_t g_MainStatus;
int fputc(int ch, FILE *f)
    if (f == &__stdout)
        uint8_t buf[1];
        buf[0] = ch;
    #if PRINT_TO_UDP == 1
        lua_udp_SendBuf(buf, 1, LUA_UDP_PORT);
        if (g_MainStatus == MS_LUA_EXEC_FILE)
            LCD_MemoAddChar(&g_LuaMemo, ch);
    #else
        USBCom_SendBuf(1, buf, 1);
        //comSendChar(COM1, ch);
        return ch;
        /* FatFS文件操作,还未做 */
        return 0;
发表于 2020-4-24 19:40:20 | 显示全部楼层
发表于 2020-4-25 11:44:42 | 显示全部楼层
拓展了fatfs的C标准接口调用方式
代码不规范,亲人两行泪!
发表于 2020-8-25 17:19:45 | 显示全部楼层
这个是直接在stdio.h里面修改吗  会出现cannot write file的错误
发表于 2020-8-25 17:56:47 | 显示全部楼层
参考我们的实现即可
发表于 2022-2-23 16:43:07 | 显示全部楼层
您好,请问有IAR版本的lua + FatFs吗?
发表于 2022-12-21 15:24:57 | 显示全部楼层
我也想在ZYNQ 上跑起来,Freertos , 但是lua 文件跑不起来
发表于 2022-12-21 15:30:19 | 显示全部楼层
参考这个,上手比较快。
STM32-V6 LUA简单移植
https://www.armbbs.cn/forum.php? ... 4757&fromuid=58
发表于 2022-12-21 15:58:47 | 显示全部楼层
eric2013 发表于 2022-12-21 15:30
参考这个,上手比较快。
STM32-V6 LUA简单移植
我重载了一些函数,do_string 是可以的,do_file时,在pcall  函数里面报错了
发表于 2022-12-22 10:37:08 | 显示全部楼层
感谢硬汉哥,我目前已经实现了ZYNQ 裸机状态下,直接执行SD 卡里面的lua 文件,并能使用require 函数加载其他的lua 文件,昨天是open 函数有问题,返回的文件描述符忘了改了;
发表于 2022-12-22 10:42:30 | 显示全部楼层
感谢硬汉哥,已经实现了ZYNQ 在裸机状态下(跑的freeRTOS), 直接加载SD 卡里面的文件并执行,并且可以使用require 加载其他的lua 脚本;
昨天是open 函数的返回有问题,debug 的时候发现读到了第一个字符,以为可以了;
我这边重载的思路稍有不同,我是将要重载的函数先 undef ,然后在用宏定义将这些函数重载,硬汉哥这种方式还有点没理解,在 lua.h 里面包含重载的函数吗?
GMT+8, 2024-4-18 09:42 , Processed in 0.272959 second(s), 25 queries .
