查看: 4701|回复: 3
[SPI/QSPI] STM32H750的QSPI复位W25Q128JV时,查询状态寄存器始终超时
发表于 2019-1-14 10:14:08 | 显示全部楼层 |阅读模式
环境:STM32H750,QSPI,W25Q128JV,IAR,JLINK
//QSPI初始化
static void MX_QUADSPI_Init(void)
  /* USER CODE BEGIN QUADSPI_Init 0 */
  /* USER CODE END QUADSPI_Init 0 */
  /* USER CODE BEGIN QUADSPI_Init 1 */
  /* USER CODE END QUADSPI_Init 1 */
  /* QUADSPI parameter configuration*/
  hqspi.Instance = QUADSPI;
  hqspi.Init.ClockPrescaler = 1;
  hqspi.Init.FifoThreshold = 4;
  hqspi.Init.SampleShifting = QSPI_SAMPLE_SHIFTING_HALFCYCLE;
  hqspi.Init.FlashSize = 23;
  hqspi.Init.ChipSelectHighTime = QSPI_CS_HIGH_TIME_6_CYCLE;
  hqspi.Init.ClockMode = QSPI_CLOCK_MODE_0;
  hqspi.Init.FlashID = QSPI_FLASH_ID_1;
  hqspi.Init.DualFlash = QSPI_DUALFLASH_DISABLE;
  if (HAL_QSPI_Init(&hqspi) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN QUADSPI_Init 2 */
  /* USER CODE END QUADSPI_Init 2 */
  * @brief  读取存储器的SR并等待EOP
  * @param  qspiFlash: QSPI句柄
  * @param  Timeout 超时
  * @retval 无
static uint8_t QSPI_AutoPollingMemReady(uint32_t Timeout)
    QSPI_CommandTypeDef     s_command;
    QSPI_AutoPollingTypeDef s_config;
    /* 配置自动轮询模式等待存储器准备就绪 */
    s_command.InstructionMode   = QSPI_INSTRUCTION_1_LINE;
    s_command.AddressSize          = QSPI_ADDRESS_24_BITS;
    s_command.AlternateByteMode = QSPI_ALTERNATE_BYTES_NONE;
    s_command.DdrMode           = QSPI_DDR_MODE_DISABLE;
    s_command.DdrHoldHalfCycle  = QSPI_DDR_HHC_ANALOG_DELAY;
    s_command.SIOOMode          = QSPI_SIOO_INST_EVERY_CMD;
    s_command.Instruction       = READ_STATUS_REG1_CMD;
    s_command.AddressMode       = QSPI_ADDRESS_NONE;
    s_command.DataMode          = QSPI_DATA_1_LINE;
    s_command.DummyCycles       = 0;
    s_config.Match           = 0x00;
    s_config.Mask            = W25Q128FV_FSR_BUSY;
    s_config.MatchMode       = QSPI_MATCH_MODE_AND;
    s_config.StatusBytesSize = 1;
    s_config.Interval        = 0x20;
    s_config.AutomaticStop   = QSPI_AUTOMATIC_STOP_ENABLE;
    if (HAL_QSPI_AutoPolling(&qspiFlash, &s_command, &s_config, Timeout) != HAL_OK)
        return QSPI_ERROR;
    return QSPI_OK;
//复位QSPI存储器。
static uint8_t QSPI_ResetMemory()
    /* 初始化复位使能命令 */
    s_command.Instruction       = RESET_ENABLE_CMD;
    s_command.DataMode          = QSPI_DATA_NONE;
    /* 发送命令 */
    if (HAL_QSPI_Command(&qspiFlash, &s_command, HAL_QPSI_TIMEOUT_DEFAULT_VALUE) != HAL_OK)
        return QSPI_ERROR;
    /* 发送复位存储器命令 */
    s_command.Instruction = RESET_MEMORY_CMD;
        return QSPI_ERROR;
    bsp_Delayus(100);
    /* 配置自动轮询模式等待存储器就绪 */
    if (QSPI_AutoPollingMemReady(HAL_QPSI_TIMEOUT_DEFAULT_VALUE) != QSPI_OK)
        return QSPI_ERROR;
    return QSPI_OK;
  * @brief  初始化QSPI存储器
  * @retval QSPI存储器状态
uint8_t BSP_QSPI_Init(void)
    uint8_t value = W25Q128FV_FSR_QE;
    /* QSPI存储器复位 */
    if (QSPI_ResetMemory() != QSPI_OK)
        return QSPI_NOT_SUPPORTED;
    /* 使能写操作 */
    if (QSPI_WriteEnable() != QSPI_OK)
        return QSPI_ERROR;
    /* 设置四路使能的状态寄存器,使能四通道IO2和IO3引脚 */
    s_command.Instruction       = WRITE_STATUS_REG2_CMD;
    s_command.NbData            = 1;
    /* 配置命令 */
        return QSPI_ERROR;
    /* 传输数据 */
    if (HAL_QSPI_Transmit(&qspiFlash, &value, HAL_QPSI_TIMEOUT_DEFAULT_VALUE) != HAL_OK)
        return QSPI_ERROR;
    /* 自动轮询模式等待存储器就绪 */
    if (QSPI_AutoPollingMemReady(W25Q128FV_SUBSECTOR_ERASE_MAX_TIME) != QSPI_OK)
        return QSPI_ERROR;
    return QSPI_OK;
 楼主| 发表于 2019-1-14 10:17:19 | 显示全部楼层
        return QSPI_ERROR;
这里始终执行超时
 楼主| 发表于 2019-1-14 11:23:45 | 显示全部楼层
        return QS ...
问题找到了,代码没问题,时钟达不到这么高频率,硬件设计有限制,实测时钟只能达到30M
发表于 2019-8-13 14:53:14 | 显示全部楼层
你这个应该是GPIO速度设置的不合适导致的,cube生成的代码这块有点小问题,修改告诉之后能跑带100M
GMT+8, 2025-5-14 08:06 , Processed in 0.206991 second(s), 23 queries .
