https://jk-jeon.github.io/posts/2022/02/jeaiii-algorithm/
一般都用sprintf,itoa或者手动计算:
- char* itoa_naive(std::uint32_t n, char* buffer) {
- char temp[10];
- char* ptr = temp + sizeof(temp) - 1;
- while (n >= 10) {
- *ptr = char('0' + (n % 10));
- n /= 10;
- --ptr;
- *ptr = char('0' + n);
- auto length = temp + sizeof(temp) - ptr;
- std::memcpy(buffer, ptr, length);
- return buffer + length;
新实现:
- #include <cstdint>
- #include <cstring>
- #include <type_traits>
- static constexpr char radix_100_table[] = {
- '0', '0', '0', '1', '0', '2', '0', '3', '0', '4',
- '0', '5', '0', '6', '0', '7', '0', '8', '0', '9',
- '1', '0', '1', '1', '1', '2', '1', '3', '1', '4',
- '1', '5', '1', '6', '1', '7', '1', '8', '1', '9',
- '2', '0', '2', '1', '2', '2', '2', '3', '2', '4',
- '2', '5', '2', '6', '2', '7', '2', '8', '2', '9',
- '3', '0', '3', '1', '3', '2', '3', '3', '3', '4',
- '3', '5', '3', '6', '3', '7', '3', '8', '3', '9',
- '4', '0', '4', '1', '4', '2', '4', '3', '4', '4',
- '4', '5', '4', '6', '4', '7', '4', '8', '4', '9',
- '5', '0', '5', '1', '5', '2', '5', '3', '5', '4',
- '5', '5', '5', '6', '5', '7', '5', '8', '5', '9',
- '6', '0', '6', '1', '6', '2', '6', '3', '6', '4',
- '6', '5', '6', '6', '6', '7', '6', '8', '6', '9',
- '7', '0', '7', '1', '7', '2', '7', '3', '7', '4',
- '7', '5', '7', '6', '7', '7', '7', '8', '7', '9',
- '8', '0', '8', '1', '8', '2', '8', '3', '8', '4',
- '8', '5', '8', '6', '8', '7', '8', '8', '8', '9',
- '9', '0', '9', '1', '9', '2', '9', '3', '9', '4',
- '9', '5', '9', '6', '9', '7', '9', '8', '9', '9'
- // /\____________
- // / \______ \______
- // 0 1 /\ /\ /\ /\
- // 2 3 4 5 6 7 8 9
- char* itoa_better_y(std::uint32_t n, char* buffer) {
- std::uint64_t prod;
- auto get_next_two_digits = [&]() {
- prod = std::uint32_t(prod) * std::uint64_t(100);
- return int(prod >> 32);
- auto print_1 = [&](int digit) {
- buffer[0] = char(digit + '0');
- buffer += 1;
- auto print_2 = [&] (int two_digits) {
- std::memcpy(buffer, radix_100_table + two_digits * 2, 2);
- buffer += 2;
- auto print = [&](std::uint64_t magic_number, int extra_shift, auto remaining_count) {
- prod = n * magic_number;
- prod >>= extra_shift;
- auto two_digits = int(prod >> 32);
- if (two_digits < 10) {
- print_1(two_digits);
- for (int i = 0; i < remaining_count; ++i) {
- print_2(get_next_two_digits());
- else {
- print_2(two_digits);
- if (n < 100) {
- if (n < 10) {
- // 1 digit.
- print_1(n);
- else {
- // 2 digit.
- print_2(n);
- else {
- if (n < 100'0000) {
- if (n < 1'0000) {
- // 3 or 4 digits.
- // 42949673 = ceil(2^32 / 10^2)
- print(42949673, 0, std::integral_constant<int, 1>{});
- else {
- // 5 or 6 digits.
- // 429497 = ceil(2^32 / 10^4)
- print(429497, 0, std::integral_constant<int, 2>{});
- else {
- if (n < 1'0000'0000) {
- // 7 or 8 digits.
- // 281474978 = ceil(2^48 / 10^6) + 1
- print(281474978, 16, std::integral_constant<int, 3>{});
- else {
- if (n < 10'0000'0000) {
- // 9 digits.
- // 1441151882 = ceil(2^57 / 10^8) + 1
- prod = n * std::uint64_t(1441151882);
- prod >>= 25;
- print_1(int(prod >> 32));
- else {
- // 10 digits.
- // 1441151881 = ceil(2^57 / 10^8)
- prod = n * std::uint64_t(1441151881);
- prod >>= 25;
- print_2(int(prod >> 32));
- return buffer;
- #include <iostream>
- int main() {
- char buffer[11];
- *itoa_better_y(1, buffer) = '\0';
- std::cout << buffer << "\n";
- *itoa_better_y(12, buffer) = '\0';
- *itoa_better_y(123, buffer) = '\0';
- *itoa_better_y(1234, buffer) = '\0';
- *itoa_better_y(12345, buffer) = '\0';
- *itoa_better_y(123456, buffer) = '\0';
- *itoa_better_y(1234567, buffer) = '\0';
- *itoa_better_y(12345678, buffer) = '\0';
- *itoa_better_y(123456789, buffer) = '\0';
- *itoa_better_y(1234567890, buffer) = '\0';
