查看: 6481|回复: 1
[客户分享] ST最新发布的9轴SoB套件STEVAL-MKI121V1INEMO-M1 Discovery(含原理图,gerber,丰
发表于 2014-2-22 13:03:58 | 显示全部楼层 |阅读模式
地址:点击进入
Key Features
    [li]Two power supply options: through the USB bus or from one of two external supply voltages, VEXT (from 3.6 to 6 V) or D_VDD (from 2.4 V to 3.3 V)[/li][li]INEMO-M1: 9-axis SoB, 13x13x2 mm size factor[/li][li]LPS331AP: MEMS pressure sensor 260-1260 mbar absolute digital output barometer[/li][li]INEMO-M1 pinout available on two double connectors[/li][li]SWD connector for programming and debugging.[/li][li]Two pushbuttons (reset and user)[/li][li]Two LEDs: user LED, power-on LED[/li][li]RoHS compliant[/li]
发表于 2014-2-24 13:51:11 | 显示全部楼层
[s:150] [s:150] [s:150] [s:151] [s:151] [s:151] [s:151]
GMT+8, 2024-6-12 16:43 , Processed in 0.170863 second(s), 29 queries .
