发表于 2014-6-21 10:29:44
显示全部楼层
看了你的程序了,你的时间片没有设置啊,可以在这里两个地方进行设置,如果想全局的设置用第一个,如果想分别设置各个任务用第二个:
1. OSSchedRoundRobinCfg(DEF_ENABLED,
0,
&err);
2. OSTaskCreate((OS_TCB *)&AppTaskCH1TCB,
(CPU_CHAR *)"App Task CH1",
(OS_TASK_PTR )AppCH1,
(void *)0,
(OS_PRIO )APP_CFG_TASK_CH1_PRIO,
(CPU_STK *)&AppTaskCH1Stk[0],
(CPU_STK_SIZE )APP_CFG_TASK_CH1_STK_SIZE / 10,
(CPU_STK_SIZE )APP_CFG_TASK_CH1_STK_SIZE,
(OS_MSG_QTY )2,
(OS_TICK )0,
(void *)0,
(OS_OPT )(OS_OPT_TASK_STK_CHK | OS_OPT_TASK_STK_CLR),
(OS_ERR *)&err); |
