[li]Independent supply and input common-mode voltages[/li][li]Wide common-mode operating range: 2.9 V to 70 V in single-supply configuration, -2.1 V to 65 V in dual-supply configuration[/li][li]Wide common-mode surviving range: -16 V to 75 V (reversed battery and load-dump conditions)[/li][li]Supply voltage range: 2.7 to 5.5 V in single-supply configuration[/li][li]Low current consumption: I[sub]CC[/sub]max = 360 μA[/li][li]Pin selectable gain: 20 V/V, 25 V/V, 50 V/V or 100 V/V[/li][li]Buffered output[/li]
