查看: 4858|回复: 5
[有问必答] 求一个安富莱V5 (7寸屏)的can通讯程序
发表于 2014-11-24 14:25:32 | 显示全部楼层 |阅读模式
求一个安富莱V5 (7寸屏)的can通讯程序,有没有例程
发表于 2014-11-24 17:52:45 | 显示全部楼层
说的还是挺不错的
www.k-lion.com
发表于 2014-11-24 18:18:38 | 显示全部楼层
can的例子一直没有搞,可以参考官方固件库库V1.4.0里面的例子。
 楼主| 发表于 2014-11-25 09:28:00 | 显示全部楼层
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOH|RCC_AHB1Periph_GPIOI, ENABLE);
     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
     GPIO_Init(GPIOI, &GPIO_InitStructure);
     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
     GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
     GPIO_Init(GPIOH, &GPIO_InitStructure);
void CAN_Config(void)
CAN_InitTypeDef        CAN_InitStructure;
  CAN_FilterInitTypeDef  CAN_FilterInitStructure;
  CanTxMsg TxMessage;
   RCC_APB1PeriphClockCmd(CAN_CLK, ENABLE);
  /* CAN register init */
  CAN_DeInit(CANx);
  /* CAN cell init */
  CAN_InitStructure.CAN_TTCM = DISABLE;
  CAN_InitStructure.CAN_ABOM = DISABLE;
  CAN_InitStructure.CAN_AWUM = DISABLE;
  CAN_InitStructure.CAN_NART = DISABLE;
  CAN_InitStructure.CAN_RFLM = DISABLE;
  CAN_InitStructure.CAN_TXFP = DISABLE;
  CAN_InitStructure.CAN_Mode = CAN_Mode_Normal;
  CAN_InitStructure.CAN_SJW = CAN_SJW_1tq;
  /* CAN Baudrate = 1 MBps (CAN clocked at 30 MHz) */
  CAN_InitStructure.CAN_BS1 = CAN_BS1_6tq;
  CAN_InitStructure.CAN_BS2 = CAN_BS2_8tq;
  CAN_InitStructure.CAN_Prescaler = 2;
  CAN_Init(CANx, &CAN_InitStructure);
  /* CAN filter init */
  CAN_FilterInitStructure.CAN_FilterNumber = 0;
  CAN_FilterInitStructure.CAN_FilterMode = CAN_FilterMode_IdMask;
  CAN_FilterInitStructure.CAN_FilterScale = CAN_FilterScale_32bit;
  CAN_FilterInitStructure.CAN_FilterIdHigh = 0x0000;
  CAN_FilterInitStructure.CAN_FilterIdLow = 0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdHigh = 0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdLow = 0x0000;
  CAN_FilterInitStructure.CAN_FilterFIFOAssignment = 0;
  CAN_FilterInitStructure.CAN_FilterActivation = ENABLE;
  CAN_FilterInit(&CAN_FilterInitStructure);
  /* Enable FIFO 0 message pending Interrupt */
  CAN_ITConfig(CANx, CAN_IT_FMP0, ENABLE);
void CAN_NVIC(void)
  NVIC_InitTypeDef  NVIC_InitStructure;
  NVIC_InitStructure.NVIC_IRQChannel = CAN1_RX0_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
void CAN1_RX0_IRQHandler(void)
  CanRxMsg RxMessage;
  CAN_Receive(CAN1, CAN_FIFO0, &RxMessage);
    int yuan_Number = RxMessage.Data[0];
我这样配置完,能不能收到数据?有没有错误的地方
 楼主| 发表于 2014-11-25 10:36:33 | 显示全部楼层
eric2013:can的例子一直没有搞,可以参考官方固件库库V1.4.0里面的例子。
 (2014-11-24 18:18)
帮忙看一下,谢谢
发表于 2014-12-16 11:02:26 | 显示全部楼层
可以查看我的帖子
GMT+8, 2024-11-1 08:06 , Processed in 0.237557 second(s), 31 queries .
