只有一个说明bit [03: 00] Flash Frequency, device specific,没有具体说明不同参数对应的频率
- # The section block specifies the sequence of boot commands to be written to the SB file
- section (0) {
- #1. Prepare Flash option
- # 0xc0233007 is the tag for Serial NOR parameter selection
- # bit [31:28] Tag fixed to 0x0C
- # bit [27:24] Option size fixed to 0
- # bit [23:20] Flash type option
- # 0 - QuadSPI SDR NOR
- # 1 - QUadSPI DDR NOR
- # 2 - HyperFLASH 1V8
- # 3 - HyperFLASH 3V
- # 4 - Macronix Octal DDR
- # 6 - Micron Octal DDR
- # 8 - Adesto EcoXIP DDR
- # bit [19:16] Query pads (Pads used for query Flash Parameters)
- # 0 - 1
- # 2 - 4
- # 3 - 8
- # bit [15:12] CMD pads (Pads used for command)
- # 0 - 1
- # 2 - 4
- # 3 - 8
- # bit [11: 08] fixed to 0
- # bit [07: 04] fixed to 0
- # bit [03: 00] Flash Frequency, device specific
- # In this example, the 0xc0233007 represents:
- # HyperFLASH 1V8, Query pads: 8 pads, Cmd pads: 8 pads, Frequency: 133MHz
- load 0xc0233007 > 0x2000;
- # Configure HyperFLASH using option a address 0x2000
- enable flexspinor 0x2000;
- #2 Erase flash as needed.(Here only 1MBytes are erased)
- erase 0x60000000..0x60100000;
- #3. Program config block
- # 0xf000000f is the tag to notify Flashloader to program FlexSPI NOR config block to the start of device
- load 0xf000000f > 0x3000;
- # Notify Flashloader to response the option at address 0x3000
- enable flexspinor 0x3000;
- #5. Program image
- load myBinFile > kAbsAddr_Ivt;
