楼主 |
发表于 2020-8-24 20:38:39
显示全部楼层
硬汉兄,看看我的spi6配置有没有问题,调了一天没调出来
static DMA_HandleTypeDef hdma_tx;
static DMA_HandleTypeDef hdma_rx;
#define SPIx_TX_DMA_STREAM DMA2_Stream5
#define SPIx_RX_DMA_STREAM DMA2_Stream6
#define SPIx_TX_DMA_REQUEST BDMA_REQUEST_SPI6_TX
#define SPIx_RX_DMA_REQUEST BDMA_REQUEST_SPI6_RX
#define SPIx_DMA_TX_IRQn DMA2_Stream5_IRQn
#define SPIx_DMA_RX_IRQn DMA2_Stream6_IRQn
#define SPIx_DMA_TX_IRQHandler DMA2_Stream5_IRQHandler
#define SPIx_DMA_RX_IRQHandler DMA2_Stream6_IRQHandler
#define SPIx_IRQn SPI6_IRQn
#define SPIx_IRQHandler SPI6_IRQHandler
/* SPI6 init function */
void MX_SPI6_Init(void)
// u8 i;
// u32 tempreg=0;
__HAL_RCC_SPI6_CLK_ENABLE();
GPIO_Set(GPIOB,PIN3|PIN4|PIN5,GPIO_MODE_AF,GPIO_OTYPE_PP,GPIO_SPEED_FAST,GPIO_PUPD_PU);
GPIO_AF_Set(GPIOB,3,8); //PA5,AF5
GPIO_AF_Set(GPIOB,4,8); //PA5,AF5
GPIO_AF_Set(GPIOB,5,8); //PA5,AF5
// GPIO_AF_Set(GPIOE,6,8); //PA6,AF5
/* SPI6 interrupt Init */
MY_NVIC_Init(2,2,SPI6_IRQn,2);//组2,最低优先级
// HAL_NVIC_SetPriority(SPI4_IRQn, 4, 4);
// HAL_NVIC_EnableIRQ(SPI4_IRQn);
/* SPI6 parameter configuration*/
hspi6.Instance = SPI6;
hspi6.Init.Mode = SPI_MODE_MASTER;//SPI_MODE_SLAVE;
hspi6.Init.Direction = SPI_DIRECTION_2LINES;
hspi6.Init.DataSize = SPI_DATASIZE_8BIT;
hspi6.Init.CLKPolarity = SPI_POLARITY_HIGH;//SPI_POLARITY_LOW; SPI_POLARITY_HIGH
hspi6.Init.CLKPhase = SPI_PHASE_2EDGE;
hspi6.Init.NSS = SPI_NSS_SOFT;//SPI_NSS_HARD_INPUT;
hspi6.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_2;
hspi6.Init.FirstBit = SPI_FIRSTBIT_MSB;
hspi6.Init.TIMode = SPI_TIMODE_DISABLE;
hspi6.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
hspi6.Init.CRCPolynomial = 7;
if (HAL_SPI_Init(&hspi6) != HAL_OK)
/* 使能DMA时钟 */
__HAL_RCC_DMA2_CLK_ENABLE();
/* SPI DMA发送配置 */
hdma_tx.Instance = SPIx_TX_DMA_STREAM; /* 例化使用的DMA数据流 */
hdma_tx.Init.FIFOMode = DMA_FIFOMODE_DISABLE; /* 禁止FIFO*/
hdma_tx.Init.FIFOThreshold = DMA_FIFO_THRESHOLD_FULL; /* 禁止FIFO此位不起作用,用于设置阀值 */
hdma_tx.Init.MemBurst = DMA_MBURST_SINGLE; /* 禁止FIFO此位不起作用,用于存储器突发 */
hdma_tx.Init.PeriphBurst = DMA_PBURST_SINGLE; /* 禁止FIFO此位不起作用,用于外设突发 */
hdma_tx.Init.Request = SPIx_TX_DMA_REQUEST; /* 请求类型 */
hdma_tx.Init.Direction = DMA_MEMORY_TO_PERIPH; /* 传输方向是从存储器到外设 */
hdma_tx.Init.PeriphInc = DMA_PINC_DISABLE; /* 外设地址自增禁止 */
hdma_tx.Init.MemInc = DMA_MINC_ENABLE; /* 存储器地址自增使能 */
hdma_tx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE; /* 外设数据传输位宽选择字节,即8bit */
hdma_tx.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE; /* 存储器数据传输位宽选择字节,即8bit */
hdma_tx.Init.Mode = DMA_NORMAL; /* 正常模式 */
hdma_tx.Init.Priority = DMA_PRIORITY_LOW; /* 优先级低 */
/* 复位DMA */
if(HAL_DMA_DeInit(&hdma_tx) != HAL_OK)
/* 初始化DMA */
if(HAL_DMA_Init(&hdma_tx) != HAL_OK)
/* 关联DMA句柄到SPI */
__HAL_LINKDMA(&hspi6, hdmatx, hdma_tx);
/* SPI DMA接收配置 */
hdma_rx.Instance = SPIx_RX_DMA_STREAM; /* 例化使用的DMA数据流 */
hdma_rx.Init.FIFOMode = DMA_FIFOMODE_DISABLE; /* 禁止FIFO*/
hdma_rx.Init.FIFOThreshold = DMA_FIFO_THRESHOLD_FULL;/* 禁止FIFO此位不起作用,用于设置阀值 */
hdma_rx.Init.MemBurst = DMA_MBURST_SINGLE; /* 禁止FIFO此位不起作用,用于存储器突发 */
hdma_rx.Init.PeriphBurst = DMA_PBURST_SINGLE; /* 禁止FIFO此位不起作用,用于外设突发 */
hdma_rx.Init.Request = SPIx_RX_DMA_REQUEST; /* 请求类型 */
hdma_rx.Init.Direction = DMA_PERIPH_TO_MEMORY; /* 传输方向从外设到存储器 */
hdma_rx.Init.PeriphInc = DMA_PINC_DISABLE; /* 外设地址自增禁止 */
hdma_rx.Init.MemInc = DMA_MINC_ENABLE; /* 存储器地址自增使能 */
hdma_rx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE; /* 外设数据传输位宽选择字节,即8bit */
hdma_rx.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE; /* 存储器数据传输位宽选择字节,即8bit */
hdma_rx.Init.Mode = DMA_NORMAL; /* 正常模式 */
hdma_rx.Init.Priority = DMA_PRIORITY_HIGH; /* 优先级低 */
/* 复位DMA */
if(HAL_DMA_DeInit(&hdma_rx) != HAL_OK)
/* 初始化DMA */
if(HAL_DMA_Init(&hdma_rx) != HAL_OK)
/* 关联DMA句柄到SPI */
__HAL_LINKDMA(&hspi6, hdmarx, hdma_rx);
/* 配置DMA接收中断 */
HAL_NVIC_SetPriority(SPIx_DMA_RX_IRQn, 1, 0);
HAL_NVIC_EnableIRQ(SPIx_DMA_RX_IRQn);
/* 配置DMA发送中断 */
HAL_NVIC_SetPriority(SPIx_DMA_TX_IRQn, 1, 0);
HAL_NVIC_EnableIRQ(SPIx_DMA_TX_IRQn);
/* 配置SPI中断 */
HAL_NVIC_SetPriority(SPIx_IRQn, 1, 0);
HAL_NVIC_EnableIRQ(SPIx_IRQn);
void DMA2_Stream6_IRQHandler(void)
HAL_DMA_IRQHandler(hspi6.hdmarx);
void DMA2_Stream5_IRQHandler(void)
HAL_DMA_IRQHandler(hspi6.hdmatx);
void SPI6_IRQHandler(void)
HAL_SPI_IRQHandler(&hspi6);
void HAL_SPI_RxCpltCallback(SPI_HandleTypeDef *hspi)
// HAL_SPI_Receive_IT(&hspi4, tt3, 1);
// HAL_SPI_Receive(&hspi4, tt3, 1,100);
* 函 数 名: HAL_SPI_TxRxCpltCallback,HAL_SPI_ErrorCallback
* 功能说明: SPI数据传输完成回调和传输错误回调
* 形 参: SPI_HandleTypeDef 类型指针变量
* 返 回 值: 无
u8 wTransferState = 0;
void HAL_SPI_TxRxCpltCallback(SPI_HandleTypeDef *hspi)
wTransferState = TRANSFER_COMPLETE;
void HAL_SPI_ErrorCallback(SPI_HandleTypeDef *hspi)
wTransferState = TRANSFER_ERROR;
