发表于 2019-2-4 00:35:18
显示全部楼层
具体的错误类型是什么:
![](static/image/hrline/4.gif)
static const char * FR_Table[]=
"FR_OK:成功", /* (0) Succeeded */
"FR_DISK_ERR:底层硬件错误", /* (1) A hard error occurred in the low level disk I/O layer */
"FR_INT_ERR:断言失败", /* (2) Assertion failed */
"FR_NOT_READY:物理驱动没有工作", /* (3) The physical drive cannot work */
"FR_NO_FILE:文件不存在", /* (4) Could not find the file */
"FR_NO_PATH:路径不存在", /* (5) Could not find the path */
"FR_INVALID_NAME:无效文件名", /* (6) The path name format is invalid */
"FR_DENIED:由于禁止访问或者目录已满访问被拒绝", /* (7) Access denied due to prohibited access or directory full */
"FR_EXIST:由于访问被禁止访问被拒绝", /* (8) Access denied due to prohibited access */
"FR_INVALID_OBJECT:文件或者目录对象无效", /* (9) The file/directory object is invalid */
"FR_WRITE_PROTECTED:物理驱动被写保护", /* (10) The physical drive is write protected */
"FR_INVALID_DRIVE:逻辑驱动号无效", /* (11) The logical drive number is invalid */
"FR_NOT_ENABLED:卷中无工作区", /* (12) The volume has no work area */
"FR_NO_FILESYSTEM:没有有效的FAT卷", /* (13) There is no valid FAT volume */
"FR_MKFS_ABORTED:由于参数错误f_mkfs()被终止", /* (14) The f_mkfs() aborted due to any parameter error */
"FR_TIMEOUT:在规定的时间内无法获得访问卷的许可", /* (15) Could not get a grant to access the volume within defined period */
"FR_LOCKED:由于文件共享策略操作被拒绝", /* (16) The operation is rejected according to the file sharing policy */
"FR_NOT_ENOUGH_CORE:无法分配长文件名工作区", /* (17) LFN working buffer could not be allocated */
"FR_TOO_MANY_OPEN_FILES:当前打开的文件数大于_FS_SHARE", /* (18) Number of open files > _FS_SHARE */
"FR_INVALID_PARAMETER:参数无效" /* (19) Given parameter is invalid */
