查看: 6760|回复: 4
[摄像头] STM32H7的摄像头接口DCMI配套的函数HAL_DCMI_Start_DMA非常不错,支持大分辨率直接传输
发表于 2019-3-4 03:05:46 | 显示全部楼层 |阅读模式
函数HAL_DCMI_Start_DMA封装的通用定时器DMA1,DMA2。使用这个定时器的特点是限制单轮最大65535次传输,这样使用大分辨率摄像头非常不方便。
使用这个函数的话,解决了这个问题,程序里面做了一个处理,对于需要大于65536次传输的情况,使用了双缓冲,不断动态调整地址,直到一帧传输完毕后会使能DCMI的帧中断
  1. /**
  2.   * @brief  Enables DCMI DMA request and enables DCMI capture
  3.   * @param  hdcmi:     pointer to a DCMI_HandleTypeDef structure that contains
  4.   *                    the configuration information for DCMI.
  5.   * @param  DCMI_Mode: DCMI capture mode snapshot or continuous grab.
  6.   * @param  pData:     The destination memory Buffer address (LCD Frame buffer).
  7.   * @param  Length:    The length of capture to be transferred.
  8.   * @retval HAL status
  9.   */
  10. HAL_StatusTypeDef HAL_DCMI_Start_DMA(DCMI_HandleTypeDef* hdcmi, uint32_t DCMI_Mode, uint32_t pData, uint32_t Length)
  11. {
  12.   /* Initialize the second memory address */
  13.   uint32_t SecondMemAddress = 0;
  14.   /* Check function parameters */
  15.   assert_param(IS_DCMI_CAPTURE_MODE(DCMI_Mode));
  16.   /* Process Locked */
  17.   __HAL_LOCK(hdcmi);
  18.
  19.   /* Lock the DCMI peripheral state */
  20.   hdcmi->State = HAL_DCMI_STATE_BUSY;
  21.   /* Enable DCMI by setting DCMIEN bit */
  22.   __HAL_DCMI_ENABLE(hdcmi);
  23.
  24.   /* Configure the DCMI Mode */
  25.   hdcmi->Instance->CR &= ~(DCMI_CR_CM);
  26.   hdcmi->Instance->CR |=  (uint32_t)(DCMI_Mode);
  27.   /* Set the DMA memory0 conversion complete callback */
  28.   hdcmi->DMA_Handle->XferCpltCallback = DCMI_DMAXferCplt;
  29.   /* Set the DMA error callback */
  30.   hdcmi->DMA_Handle->XferErrorCallback = DCMI_DMAError;
  31.   /* Set the dma abort callback */
  32.   hdcmi->DMA_Handle->XferAbortCallback = NULL;
  33.   /* Reset transfer counters value */
  34.   hdcmi->XferCount = 0;
  35.   hdcmi->XferTransferNumber = 0;
  36.
  37.   if(Length <= 0xFFFF)
  38.   {
  39.     /* Enable the DMA Stream */
  40.     HAL_DMA_Start_IT(hdcmi->DMA_Handle, (uint32_t)&hdcmi->Instance->DR, (uint32_t)pData, Length);
  41.   }
  42.   else /* DCMI_DOUBLE_BUFFER Mode */
  43.   {
  44.     /* Set the DMA memory1 conversion complete callback */
  45.     hdcmi->DMA_Handle->XferM1CpltCallback = DCMI_DMAXferCplt;
  46.     /* Initialize transfer parameters */
  47.     hdcmi->XferCount = 1;
  48.     hdcmi->XferSize = Length;
  49.     hdcmi->pBuffPtr = pData;
  50.
  51.     /* Get the number of buffer */
  52.     while(hdcmi->XferSize > 0xFFFF)
  53.     {
  54.       hdcmi->XferSize = (hdcmi->XferSize/2);
  55.       hdcmi->XferCount = hdcmi->XferCount*2;
  56.     }
  57.     /* Update DCMI counter  and transfer number*/
  58.     hdcmi->XferCount = (hdcmi->XferCount - 2);
  59.     hdcmi->XferTransferNumber = hdcmi->XferCount;
  60.     /* Update second memory address */
  61.     SecondMemAddress = (uint32_t)(pData + (4*hdcmi->XferSize));
  62.     /* Start DMA multi buffer transfer */
  63.     HAL_DMAEx_MultiBufferStart_IT(hdcmi->DMA_Handle, (uint32_t)&hdcmi->Instance->DR, (uint32_t)pData, SecondMemAddress, hdcmi->XferSize);
  64.   }
  65.
  66.   /* Enable Capture */
  67.   hdcmi->Instance->CR |= DCMI_CR_CAPTURE;
  68.   /* Release Lock */
  69.   __HAL_UNLOCK(hdcmi);
  70.   /* Return function status */
  71.   return HAL_OK;
  72. }
DMA传输完成中断里面的关键地方:
  1. /**
  2.   * @}
  3.   */
  4. /* Private functions ---------------------------------------------------------*/
  5. /** @defgroup DCMI_Private_Functions DCMI Private Functions
  6.   * @{
  7.   */
  8.   /**
  9.   * @brief  DMA conversion complete callback.
  10.   * @param  hdma: pointer to a DMA_HandleTypeDef structure that contains
  11.   *                the configuration information for the specified DMA module.
  12.   * @retval None
  13.   */
  14. static void DCMI_DMAXferCplt(DMA_HandleTypeDef *hdma)
  15. {
  16.   uint32_t tmp = 0;
  17.   DCMI_HandleTypeDef* hdcmi = ( DCMI_HandleTypeDef* )((DMA_HandleTypeDef* )hdma)->Parent;
  18.   if(hdcmi->XferCount != 0)
  19.   {
  20.     /* Update memory 0 address location */
  21.     tmp = ((((DMA_Stream_TypeDef *)(hdcmi->DMA_Handle->Instance))->CR) & DMA_SxCR_CT);
  22.     if(((hdcmi->XferCount % 2) == 0) && (tmp != 0))
  23.     {
  24.       tmp = ((DMA_Stream_TypeDef *)(hdcmi->DMA_Handle->Instance))->M0AR;
  25.       HAL_DMAEx_ChangeMemory(hdcmi->DMA_Handle, (tmp + (8*hdcmi->XferSize)), MEMORY0);
  26.       hdcmi->XferCount--;
  27.     }
  28.     /* Update memory 1 address location */
  29.     else if((((DMA_Stream_TypeDef *)(hdcmi->DMA_Handle->Instance))->CR & DMA_SxCR_CT) == 0)
  30.     {
  31.       tmp = ((DMA_Stream_TypeDef *)(hdcmi->DMA_Handle->Instance))->M1AR;
  32.       HAL_DMAEx_ChangeMemory(hdcmi->DMA_Handle, (tmp + (8*hdcmi->XferSize)), MEMORY1);
  33.       hdcmi->XferCount--;
  34.     }
  35.   }
  36.   /* Update memory 0 address location */
  37.   else if((((DMA_Stream_TypeDef *)(hdcmi->DMA_Handle->Instance))->CR & DMA_SxCR_CT) != 0)
  38.   {
  39.     ((DMA_Stream_TypeDef *)(hdcmi->DMA_Handle->Instance))->M0AR = hdcmi->pBuffPtr;
  40.   }
  41.   /* Update memory 1 address location */
  42.   else if((((DMA_Stream_TypeDef *)(hdcmi->DMA_Handle->Instance))->CR & DMA_SxCR_CT) == 0)
  43.   {
  44.     tmp = hdcmi->pBuffPtr;
  45.     ((DMA_Stream_TypeDef *)(hdcmi->DMA_Handle->Instance))->M1AR = (tmp + (4*hdcmi->XferSize));
  46.     hdcmi->XferCount = hdcmi->XferTransferNumber;
  47.   }
  48.   /* Check if the frame is transferred */
  49.   if(hdcmi->XferCount == hdcmi->XferTransferNumber)
  50.   {
  51.     /* Enable the Frame interrupt */
  52.     __HAL_DCMI_ENABLE_IT(hdcmi, DCMI_IT_FRAME);
  53.
  54.     /* When snapshot mode, set dcmi state to ready */
  55.     if((hdcmi->Instance->CR & DCMI_CR_CM) == DCMI_MODE_SNAPSHOT)
  56.     {
  57.       hdcmi->State= HAL_DCMI_STATE_READY;
  58.     }
  59.   }
  60. }
发表于 2019-3-4 09:11:38 | 显示全部楼层
研究的很深啦
发表于 2019-3-4 10:24:45 | 显示全部楼层
谢谢分享!
发表于 2022-5-10 17:06:27 | 显示全部楼层
楼主你好,我使用STM32H723的DCMI的HAL_DCMI_Start_DMA()函数,程序会跑到 hdcmi->DMA_Handle->XferErrorCallback = DCMI_DMAError;不知道是什么问题请指教
 楼主| 发表于 2022-5-11 09:41:55 | 显示全部楼层
jgmms 发表于 2022-5-10 17:06
楼主你好,我使用STM32H723的DCMI的HAL_DCMI_Start_DMA()函数,程序会跑到 hdcmi->DMA_Handle->XferError ...
直接使用我们的代码,测试是否正常。
GMT+8, 2024-6-3 01:16 , Processed in 0.158310 second(s), 25 queries .
