查看: 2913|回复: 14
[STM32H7] stm32H750驱动AD7606出现问题
发表于 2021-8-9 21:51:05 | 显示全部楼层 |阅读模式
H750串口定时输出读取,现在的问题是采集端在不接入电压有数据显示,接入电压后数值不变
已经调了好多天了,就是查不出哪里的问题
接线
FMC_D0->PD14
FMC_D1->PD15
FMC_D2->PD0
FMC_D3->PD1
FMC_D4->PE7
FMC_D5->PE8
FMC_D6->PE9
FMC_D7->PE10
FMC_D8->PE11
FMC_D9->PE12
FMC_D10->PE13
FMC_D11->PE14
FMC_D12->PE15
FMC_D13->PD8
FMC_D14->PD9
FMC_D15->PD10
//信号引脚
FMC_NOE->PD4
FMC_CS->PC7
//控制引脚
BUSY->PE6
CONVEST->PC6
OS0->PC8
OS1->PC9
OS2->PC10
RANGE->PC11
RESET->PC12
AD7606的驱动程序
#include "ad7606.h"
#include "stdio.h"
#include "bsp_SysTick.h"
#define OS0_0()                GPIOC->BSRR = ((uint32_t)GPIO_PIN_8<<16U)
#define OS0_1()                GPIOC->BSRR = GPIO_PIN_8
#define OS1_0()                GPIOC->BSRR = ((uint32_t)GPIO_PIN_9<<16U)
#define OS1_1()                GPIOC->BSRR = GPIO_PIN_9
#define OS2_0()                GPIOC->BSRR = ((uint32_t)GPIO_PIN_10<<16U)
#define OS2_1()                GPIOC->BSRR = GPIO_PIN_10
#define CONVST_1()        GPIOC->BSRR = GPIO_PIN_6
#define CONVST_0()        GPIOC->BSRR = ((uint32_t)GPIO_PIN_6<<16U)
/*éè&#214;&#195;ê&#228;è&#235;á&#191;3ìμ&#196;GPIO: PC11 */
#define RANGE_1()        GPIOC->BSRR = GPIO_PIN_11
#define RANGE_0()        GPIOC->BSRR = ((uint32_t)GPIO_PIN_11<<16U)
/*AD7606&#184;′&#206;&#187;&#191;ú&#207;&#223; : PC12*/
#define RESET_1()        GPIOC->BSRR = GPIO_PIN_12
#define RESET_0()        GPIOC->BSRR = ((uint32_t)GPIO_PIN_12<<16U)
/*AD7606 FSMC×ü&#207;&#223;μ&#216;&#214;·£&#172;&#214;&#187;&#196;ü&#182;á,&#206;TDèD′ */
#define AD7606_RESULT()        *(__IO uint16_t *)0x60000000
AD7606_VAR_T g_tAD7606;                        /* &#182;¨ò&#229;1&#184;&#246;è&#171;&#190;&#214;±&#228;á&#191;£&#172;±£′&#230;ò&#187;D&#169;2&#206;êy */
AD7606_FIFO_T g_tAdcFifo;                /* &#182;¨ò&#229;FIFO&#189;á11ì&#229;±&#228;á&#191; */
static void AD7606_CtrlLinesConfig(void);
static void AD7606_FSMCConfig(void);
void bsp_InitAD7606(void)
        AD7606_CtrlLinesConfig();
        AD7606_FSMCConfig();
        AD7606_SetOS(AD_OS_NO);
        AD7606_SetInputRange(0);
        AD7606_Reset();
        CONVST_1();
        __HAL_RCC_GPIOB_CLK_ENABLE();
        __HAL_RCC_GPIOC_CLK_ENABLE();
        __HAL_RCC_GPIOD_CLK_ENABLE();
        __HAL_RCC_GPIOE_CLK_ENABLE();
        __HAL_RCC_FMC_CLK_ENABLE();
        GPIO_InitStructure.Mode = GPIO_MODE_AF_PP;
        GPIO_InitStructure.Pull = GPIO_NOPULL;
        GPIO_InitStructure.Speed = GPIO_SPEED_FREQ_HIGH;
        GPIO_InitStructure.Alternate = GPIO_AF12_FMC;
        GPIO_InitStructure.Pin = GPIO_PIN_0 | GPIO_PIN_1|GPIO_PIN_4|GPIO_PIN_8 | GPIO_PIN_9 | GPIO_PIN_10 |
                                 GPIO_PIN_14 |GPIO_PIN_15;
        HAL_GPIO_Init(GPIOD, &GPIO_InitStructure);
        GPIO_InitStructure.Pin = GPIO_PIN_4 |GPIO_PIN_5|GPIO_PIN_7|GPIO_PIN_8 | GPIO_PIN_9 | GPIO_PIN_10 |
                                 GPIO_PIN_11|GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14 |GPIO_PIN_15;
        HAL_GPIO_Init(GPIOE, &GPIO_InitStructure);
                GPIO_InitStructure.Mode = GPIO_MODE_OUTPUT_PP;
                GPIO_InitStructure.Speed = GPIO_SPEED_FREQ_MEDIUM;
                GPIO_InitStructure.Pin=GPIO_PIN_6|GPIO_PIN_8|GPIO_PIN_9|GPIO_PIN_10|GPIO_PIN_11|GPIO_PIN_12;
                HAL_GPIO_Init(GPIOC,&GPIO_InitStructure);
        SRAM_HandleTypeDef hsram = {0};
        FMC_NORSRAM_TimingTypeDef SRAM_Timing = {0};
        hsram.Instance  = FMC_NORSRAM_DEVICE;
        hsram.Extended  = FMC_NORSRAM_EXTENDED_DEVICE;
        SRAM_Timing.AddressSetupTime       = 5;
        SRAM_Timing.AddressHoldTime        = 2;
        SRAM_Timing.DataSetupTime          = 5;
        SRAM_Timing.BusTurnAroundDuration  = 1;
        SRAM_Timing.CLKDivision            = 2;
        SRAM_Timing.DataLatency            = 2;
        SRAM_Timing.AccessMode             = FMC_ACCESS_MODE_A;
        hsram.Init.NSBank             = FMC_NORSRAM_BANK1;
        hsram.Init.DataAddressMux     = FMC_DATA_ADDRESS_MUX_DISABLE;
        hsram.Init.MemoryType         = FMC_MEMORY_TYPE_SRAM;
        hsram.Init.MemoryDataWidth    = FMC_NORSRAM_MEM_BUS_WIDTH_16;
        hsram.Init.BurstAccessMode    = FMC_BURST_ACCESS_MODE_DISABLE;
        hsram.Init.WaitSignalPolarity = FMC_WAIT_SIGNAL_POLARITY_LOW;
        hsram.Init.WaitSignalActive   = FMC_WAIT_TIMING_BEFORE_WS;
        hsram.Init.WriteOperation     = FMC_WRITE_OPERATION_ENABLE;
        hsram.Init.WaitSignal         = FMC_WAIT_SIGNAL_DISABLE;
        hsram.Init.ExtendedMode       = FMC_EXTENDED_MODE_DISABLE;
        hsram.Init.AsynchronousWait   = FMC_ASYNCHRONOUS_WAIT_DISABLE;
        hsram.Init.WriteBurst         = FMC_WRITE_BURST_DISABLE;
        hsram.Init.ContinuousClock    = FMC_CONTINUOUS_CLOCK_SYNC_ONLY;
  hsram.Init.WriteFifo          = FMC_WRITE_FIFO_ENABLE;
        if(HAL_SRAM_Init(&hsram, &SRAM_Timing, &SRAM_Timing)!=HAL_OK)
                while(1){;}
void AD7606_SetOS(uint8_t _ucOS)
        g_tAD7606.ucOS = _ucOS;
        switch (_ucOS)
                case AD_OS_X2:
                        OS2_0();
                        OS1_0();
                        OS0_1();
                case AD_OS_X4:
                        OS2_0();
                        OS1_1();
                        OS0_0();
                case AD_OS_X8:
                        OS2_0();
                        OS1_1();
                        OS0_1();
                case AD_OS_X16:
                        OS2_1();
                        OS1_0();
                        OS0_0();
                case AD_OS_X32:
                        OS2_1();
                        OS1_0();
                        OS0_1();
                case AD_OS_X64:
                        OS2_1();
                        OS1_1();
                        OS0_0();
                case AD_OS_NO:
                default:
                        g_tAD7606.ucOS = AD_OS_NO;
                        OS2_0();
                        OS1_0();
                        OS0_0();
void AD7606_SetInputRange(uint8_t _ucRange)
        if(_ucRange == 0)
                g_tAD7606.ucRange = 0;
                RANGE_0();
                g_tAD7606.ucRange = 1;
                RANGE_1();
void AD7606_Reset(void)
        RESET_0();
        RESET_1();
        RESET_1();
        RESET_1();
        RESET_1();
        RESET_0();
void AD7606_StartConvst(void)
              CONVST_0();
        CONVST_0();
        CONVST_0();
        CONVST_1();
void AD7606_ReadNowAdc(void)
        g_tAD7606.sNowAdc[0] = AD7606_RESULT();
        g_tAD7606.sNowAdc[1] = AD7606_RESULT();
        g_tAD7606.sNowAdc[2] = AD7606_RESULT();
        g_tAD7606.sNowAdc[3] = AD7606_RESULT();
        g_tAD7606.sNowAdc[4] = AD7606_RESULT();
        g_tAD7606.sNowAdc[5] = AD7606_RESULT();
        g_tAD7606.sNowAdc[6] = AD7606_RESULT();
        g_tAD7606.sNowAdc[7] = AD7606_RESULT();
定时中断读取
void TIM3_IRQHandler(void)
        if((TIM3->SR & TIM_FLAG_UPDATE) != RESET)
                AD7606_StartConvst();
                AD7606_ReadNowAdc();
                ucRefresh=1;
                HAL_GPIO_TogglePin(GPIOA,GPIO_PIN_1);
                TIM3->SR = ~ TIM_FLAG_UPDATE;
________________________________________________________________________________________
主函数
int main(void)
        ucRefresh=0;
        SystemClock_Config();
        MPU_Config(); //MPU config
        LED_GPIO_Config();
        DEBUG_USART_Config();
  bsp_InitAD7606();
        AD7606_Reset();
  TIM3_Init();
        while(1)
                if (ucRefresh == 1)
                        //′òó&#161;ADC2é&#209;ù&#189;á1&#251;
                        printf("Range = %d, OS = %d\r\n", g_tAD7606.ucRange, g_tAD7606.ucOS);
                        printf("CH1 = %6d, CH2 = %6d, CH3 = %6d, CH4 = %6d",
                                g_tAD7606.sNowAdc[0], g_tAD7606.sNowAdc[1], g_tAD7606.sNowAdc[2], g_tAD7606.sNowAdc[3]);
                        printf("CH5 = %6d, CH6 = %6d, CH7 = %6d, CH8 = %6d\r\n",
                                g_tAD7606.sNowAdc[4], g_tAD7606.sNowAdc[5], g_tAD7606.sNowAdc[6], g_tAD7606.sNowAdc[7]);
                  ucRefresh=0;
希望各位大佬能给点指点
串口打印
串口打印
发表于 2021-8-10 08:30:48 | 显示全部楼层
你的PC7片选应交配置在哪里了
 楼主| 发表于 2021-8-10 08:58:49 | 显示全部楼层
eric2013 发表于 2021-8-10 08:30
你的PC7片选应交配置在哪里了
啥是应交配置啊
 楼主| 发表于 2021-8-10 08:59:16 | 显示全部楼层
你的PC7片选应交配置在哪里了
应该在哪里配置呢
发表于 2021-8-10 09:01:56 | 显示全部楼层
应交 = 引脚
你贴的代码里面看不到PC7的引脚配置。
 楼主| 发表于 2021-8-10 09:06:30 | 显示全部楼层
eric2013 发表于 2021-8-10 09:01
应交 = 引脚
你贴的代码里面看不到PC7的引脚配置。
我加上PC7的配置了,还是不行
发表于 2021-8-10 09:11:21 | 显示全部楼层
Mr_Robot 发表于 2021-8-10 09:06
我加上PC7的配置了,还是不行
你的PC7怎么配置的,你贴出来我看下,我觉得你配置错了。
 楼主| 发表于 2021-8-10 09:17:16 | 显示全部楼层
        GPIO_InitStructure.Pin=GPIO_PIN_7;
        HAL_GPIO_Init(GPIOC, &GPIO_InitStructure);
这个
 楼主| 发表于 2021-8-10 09:17:36 | 显示全部楼层
        /* &#197;&#228;&#214;&#195;GPIOD */
这个
 楼主| 发表于 2021-8-10 09:29:18 | 显示全部楼层
现在加上PC7的配置后,串口打印都是-1了,加上电压也反应
发表于 2021-8-10 10:08:08 | 显示全部楼层
PC7配置错了,PC7做FMC_NE1,那么AF复用要使用AF9,即GPIO_AF9_FMC
 楼主| 发表于 2021-8-10 10:51:36 | 显示全部楼层
GPIO_InitStructure.Pin = GPIO_PIN_7;
  GPIO_InitStructure.Pull = GPIO_PULLUP;
  GPIO_InitStructure.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
  GPIO_InitStructure.Alternate = GPIO_AF9_FMC;
我加上这些配置后,串口打印仍然是-1,加上电压后示数没反应
发表于 2021-8-10 10:59:06 | 显示全部楼层
  GPIO_InitStr ...
别的问题看不出来了,你再找找。
发表于 2021-10-4 08:30:22 | 显示全部楼层
楼主问题解决了吗?
发表于 2022-3-12 23:42:23 | 显示全部楼层
您最后是怎么解决的呢
GMT+8, 2024-6-5 18:01 , Processed in 0.216107 second(s), 28 queries .
