查看: 8875|回复: 3
[其它] 官方flash_loader_demo_v2.7.0版本下载,用于STM8和STM32的串口ISP下载
发表于 2015-7-13 15:20:29 | 显示全部楼层 |阅读模式
实际测试V2.7.0比V2.6.0版本好用,使用教程:http://www.armbbs.cn/forum.php?mod=viewthread&tid=10967
stsw-mcu005.zip (33.36 MB, 下载次数: 4153)
* V2.7.0 - 15-September-2014
New Features
    + Adding support of New STM32F0xx/STM32F3xx/STM32F4xx/STM32L1xx/STM32L0xx/ devices
    + Project Source files upgraded to Visual Studio 2013
Known Limitations
    + Options Bytes management of STM8, STM32L1/L0 and STM32F0/2/3/4 devices is supported only in Command line version
      for batch programming,
    + Automatic selection of some STM8 devices may not work properly. If required, use
      command line version with batch files customization,
    + on Some STM32 MCus Write protection of last pages which is controlled by the last protection bit7
      in WPR3 options byte is working properly but the Graphical view of check boxes may not updated
      accordingly on some devices with large size greater than 128Kbytes.
      To enable/disable the write protection of last pages, you can check/uncheck only the first
      page of this group of pages on the graphical view.
    + STM32L "Erase all" feature is not supported. See AN2606 for more details.
* V2.6.0 - 07-November-2012
New Features
    + Adding support of STM32F3xx devices
    + Adding support of STM32F0xx devices
    + Add options bytes data for STM32L devices
Known Limitations
    + Options Bytes management of STM8, STM32L1 and STM32F0/2/3/4 devices is supported only in Command line version
    + STM32F1xx Write protection of last pages which is controlled by the last protection bit7
发表于 2017-5-11 10:53:43 | 显示全部楼层
最近官方有更新吗?
 楼主| 发表于 2017-5-11 10:57:37 | 显示全部楼层
回 caicaptain2 的帖子
caicaptain2:最近官方有更新吗?
 (2017-05-11 10:53)
这是当前最新的
http://www.armbbs.cn/forum.php?mod=viewthread&tid=23064
发表于 2017-5-11 11:01:08 | 显示全部楼层
[attachment=undefined]
GMT+8, 2025-5-13 10:46 , Processed in 0.392407 second(s), 27 queries .
