查看: 1490|回复: 3
[ThreadX全家桶] USBX初始化出现UX_MEMORY_INSUFFICIENT错误
发表于 2022-4-15 19:07:17 | 显示全部楼层 |阅读模式
如题,芯片L4,USBX做MSC和HID功能。初始化时出错。
下在这句返回UX_MEMORY_INSUFFICIENT
  ret =  _ux_device_stack_initialize(NULL,
                                     0,
                                     device_framework_full_speed,
                                     device_framework_fs_length,
                                     string_framework,
                                     string_framework_length,
                                     language_id_framework,
                                     languge_id_framework_length, UX_NULL);
跟踪进去,就发现错误。
            while (endpoints_pool < (device -> ux_slave_device_endpoints_pool + endpoints_found))
                /* Obtain some memory.  */
                endpoints_pool -> ux_slave_endpoint_transfer_request.ux_slave_transfer_request_data_pointer =
                                _ux_utility_memory_allocate(UX_NO_ALIGN, UX_CACHE_SAFE_MEMORY, UX_SLAVE_REQUEST_DATA_MAX_LENGTH);
                /* Ensure we could allocate memory.  */
                if (endpoints_pool -> ux_slave_endpoint_transfer_request.ux_slave_transfer_request_data_pointer == UX_NULL)
                    status = UX_MEMORY_INSUFFICIENT;
                /* Create the semaphore for the endpoint.  */
                status =  _ux_utility_semaphore_create(&endpoints_pool -> ux_slave_endpoint_transfer_request.ux_slave_transfer_request_semaphore,
                                                    "ux_transfer_request_semaphore", 0);
                /* Check completion status.  */
                if (status != UX_SUCCESS)
                    status = UX_SEMAPHORE_ERROR;
                /* Next endpoint.  */
                endpoints_pool++;
 楼主| 发表于 2022-4-15 21:06:09 | 显示全部楼层
USBX_MEMORY_SIZE这个改大就对了,已经解决了。这个内存和整个协议栈的内存还不是一个概念。
发表于 2022-4-17 17:47:43 | 显示全部楼层
USBX_MEMORY_SIZE 这个值与应用的具体情况相关,生成代码设的都比较小。
发表于 2024-2-26 10:49:39 | 显示全部楼层
第一个红框把原本的改小
GMT+8, 2024-5-18 05:14 , Processed in 0.251866 second(s), 27 queries .
