查看: 1090|回复: 6
[FreeRTOS] 基于CMSIS_RTOS_V2封装的FreeRTOS任务堆栈分配问题
发表于 2022-4-25 23:24:35 | 显示全部楼层 |阅读模式
因为移植OPENAMP的需求,将操作系统从RTX5切换到FreeRTOS,发现虽然用了CMSIS_RTOS_V2封装,但是无法给任务直接指定堆栈(指定后都无法进入任务),是我用法不对还是其他问题?
int main(void)
osKernelInitialize(); // 内核初始化
TaskIdleId = osThreadNew(TaskIdle, NULL, &TaskIdle_Attr); // 创建空闲任务
osKernelStart(); // 启动内核
//任务堆栈
uint64_t taskLv1Stk[LV1_STK_SIZE];
uint64_t taskLv2Stk[LV2_STK_SIZE];
uint64_t taskLv3Stk[LV3_STK_SIZE];
uint64_t taskIdleStk[IDLE_STK_SIZE];
//任务属性
const osThreadAttr_t TaskLv1_Attr = {
	.name = "TaskLv1",
	.attr_bits = osThreadDetached,
//    .stack_mem = taskLv1Stk,
//    .stack_size = sizeof(taskLv1Stk),
	  .stack_size = 128 * 4,
	.priority = osPriorityNormal3,
const osThreadAttr_t TaskLv2_Attr = {
	.name = "TaskLv2",
//    .stack_mem = taskLv2Stk,
//    .stack_size = sizeof(taskLv2Stk),
	.priority = osPriorityNormal2,
const osThreadAttr_t TaskLv3_Attr = {
	.name = "TaskLv3",
//    .stack_mem = taskLv3Stk,
//    .stack_size = sizeof(taskLv3Stk),
	.priority = osPriorityNormal1,
const osThreadAttr_t TaskIdle_Attr = {
	.name = "TaskIdle",
//    .stack_mem = taskIdleStk,
//    .stack_size = sizeof(taskIdleStk),
//	.priority = osPriorityIdle,
//任务id
osThreadId_t TaskLv1Id = NULL;
osThreadId_t TaskLv2Id = NULL;
osThreadId_t TaskLv3Id = NULL;
osThreadId_t TaskIdleId = NULL;
* @brief 进程LV1 1ms执行一次
void TaskLv1(void *arg)
    while(1)
		osDelay(1);
* @brief 进程LV2 10ms执行一次
void TaskLv2(void *arg)
    while(1)
        osDelay(10);
* @brief 进程LV3 1000ms执行一次
void TaskLv3(void *arg)
    while(1)
		GPIO_Toggle(LED_RED);
		GPIO_Toggle(LED_BLUE);
        osDelay(1000);
* @brief    空闲任务
void TaskIdle(void *arg)
	//创建任务
    TaskLv1Id = osThreadNew(TaskLv1, NULL, &TaskLv1_Attr);
    TaskLv2Id = osThreadNew(TaskLv2, NULL, &TaskLv2_Attr);
    TaskLv3Id = osThreadNew(TaskLv3, NULL, &TaskLv3_Attr);
	HAL_ResumeTick();
	while(1)
		shellTask(&SysShell);
发表于 2022-4-26 00:27:48 | 显示全部楼层
1、不用切,RTX5标配的CMSIS-RTOS V2封装层。
2、你楼主位的代码,由于你注释掉了
那么你这里是用的全局动态内存分配的。
 楼主| 发表于 2022-4-26 08:43:51 | 显示全部楼层
我开始是尝试静态分配的,但是任务跑不起来,查了很久,才发现是堆栈问题,注释掉后改成静态堆栈,就跑起来了
从这个 也可以看出来,FreeRTOS带CMSIS-RTOS V2封装后的并不能无脑用,和RTX5还是有差距的
发表于 2022-4-26 09:20:55 | 显示全部楼层
仅你楼主位的这种代码,不管是FreeRTOS还是RTX5都是可以随意配置的。
发表于 2022-4-27 10:54:04 | 显示全部楼层
动态堆栈,静态堆栈的切换,最好用ide重新生成一遍。 涉及到一些宏定义,自己改代码不好找。
 楼主| 发表于 2022-4-28 17:58:17 | 显示全部楼层
我直接去掉了CMSIS_RTOS_V2封装,还是直接用方便省事点
发表于 2022-4-30 23:04:02 | 显示全部楼层
请问: 动态堆栈和静态堆栈 ,分别怎么设置的?
GMT+8, 2024-5-23 06:16 , Processed in 0.169753 second(s), 25 queries .
