[C] 纯文本查看 复制代码 u8 MPU_Set_Protection(u32 baseaddr, u32 size, u32 rnum, u8 ap, u8 sen, u8 cen, u8 ben)
MPU_Region_InitTypeDef MPU_Initure;
HAL_MPU_Disable(); //配置MPU之前先关闭MPU,配置完成以后在使能MPU
MPU_Initure.Enable = MPU_REGION_ENABLE; //使能该保护区域
MPU_Initure.Number = rnum; //设置保护区域
MPU_Initure.BaseAddress = baseaddr; //设置基址
MPU_Initure.Size = size; //设置保护区域大小
MPU_Initure.AccessPermission = (u8)ap; //设置访问权限,
MPU_Initure.IsShareable = sen; //是否共用?
MPU_Initure.IsCacheable = cen; //是否cache?
MPU_Initure.IsBufferable = ben; //是否缓冲?
MPU_Initure.TypeExtField = MPU_TEX_LEVEL0;
MPU_Initure.SubRegionDisable = 0x00;
MPU_Initure.DisableExec = MPU_INSTRUCTION_ACCESS_ENABLE;
HAL_MPU_ConfigRegion(&MPU_Initure); //配置MPU
HAL_MPU_Enable(MPU_PRIVILEGED_DEFAULT); //开启MPU
return 0;
//设置需要保护的存储块
//必须对部分存储区域进行MPU保护,否则可能导致程序运行异常
//比如MCU屏不显示,摄像头采集数据出错等等问题...
void MPU_Memory_Protection(void)
//保护整个D1 SRAM 512KB
MPU_Set_Protection(0x24000000, //基地址
MPU_REGION_SIZE_512KB, //长度
MPU_REGION_NUMBER1, // NUMER1
MPU_REGION_FULL_ACCESS, //全访问
MPU_ACCESS_NOT_SHAREABLE, //允许共享
MPU_ACCESS_NOT_CACHEABLE, //允许cache
MPU_ACCESS_NOT_BUFFERABLE); //禁止缓冲
// 保护SRAM1,SRAM2和SRAM3
MPU_Set_Protection(0x30000000, //基地址
MPU_REGION_NUMBER2, // NUMER1
// //保护SDRAM区域,共32M字节
// MPU_Set_Protection( 0XC0000000, //基地址
// MPU_REGION_SIZE_32MB, //长度
// MPU_REGION_NUMBER2, //NUMER2
// MPU_REGION_FULL_ACCESS, //全访问
// MPU_ACCESS_NOT_SHAREABLE, //禁止共享
// MPU_ACCESS_CACHEABLE, //允许cache
// MPU_ACCESS_BUFFERABLE); //允许缓冲
