查看: 1117|回复: 4
[其它] 发现另外一个GUI:GUIslice
发表于 2022-7-31 08:48:58 | 显示全部楼层 |阅读模式
发现另外一个GUI,轻量级的
网址:https://github.com/ImpulseAdventure/GUIslice
  • Pure C library, no dynamic memory allocation
  • Widgets:
    • text, images, buttons, checkboxes, radio buttons, sliders, custom keypads, listbox, radial controls, scrolling textbox / terminal, graphs, etc. plus extensions and multiple pages.
  • Cross-platform GUIslice Builder application to generate layouts
  • Platform-independent GUI core currently supports:
    • Adafruit-GFX, TFT_eSPI, mcufriend, UTFT, LCDGFX, SDL1.2, SDL2.0
  • Devices:
    • Raspberry Pi, Arduino, ATmega2560, ESP8266 / NodeMCU, ESP32, M5stack, Teensy 3 / T4, WIO Terminal, Feather M0 (Cortex-M0), nRF52 (Cortex-M4F), LINUX, Beaglebone Black, STM32, Due, etc.
  • Typical displays:
    • PiTFT, Adafruit TFT 3.5" / 2.8" / 2.4" / 2.2" / 1.44", FeatherWing TFT, OLED 0.96", mcufriend, BuyDisplay / EastRising 4.3" 5" 7", Waveshare, 4D Cape
  • Display drivers include:
    • ILI9341, ST7735, SSD1306, HX8347D, HX8357, PCD8544, RA8875, RA8876, ILI9225, ILI9341_t3, ILI9341_due
  • Touchscreen control including:
    • STMPE610, FT6206, FT5206, XPT2046, 4-wire, tslib, URTouch, Adafruit Seesaw
  • IDE Support:
    • GUIslice has been tested for use in the Arduino IDE and Platform IO environments, in addition to LINUX make
  • Foreign characters / UTF-8 encoding (in SDL mode), anti-aliased fonts (in TFT_eSPI mode)
  • Dynamic display rotation
  • GPIO / pin / keyboard / Adafruit Seesaw navigation for non-touchscreen devices
参与人数 1金币 +100 收起 理由
eric2013 + 100 很给力!
发表于 2022-7-31 10:10:14 | 显示全部楼层
有些价值,GUI本身很简单,但是还提供了上位机拖拽的方式去做,这个收下了
发表于 2022-7-31 13:34:03 | 显示全部楼层
谢谢楼主分享。
发表于 2022-7-31 21:19:54 | 显示全部楼层
看了一下,好像确实不错的样子,但是,好像底层驱动方式看了好久 没看出个啥出来
发表于 2022-8-1 10:43:11 | 显示全部楼层
ST早期也做过一个类似的GUI组件,也有上位机拖拽,不过在后来各家GUI争霸的情况下,他们放弃了,直接整第3方了。
GMT+8, 2024-5-19 16:14 , Processed in 0.176069 second(s), 26 queries .
