查看: 1767|回复: 11
[ThreadX全家桶] 借助Threadx强大性能,编写自己的内存管理malloc/free
发表于 2022-9-25 19:01:54 | 显示全部楼层 |阅读模式
咱们就直接上代码吧
mymalloc.c文件源码:
static void AppTaskMsgPro(ULONG thread_input)
	(void)thread_input;
  void *pvTest1 =NULL;
	void *pvTest2 =NULL;
	unsigned int count = 0;
	while(1)
		count = HAL_GetTick()%1024;
		pvTest1 = my_malloc(count);
		printf("pvTest1:%p count:%d\r\n",pvTest1,count);
		pvTest2 = my_malloc(count);
		printf("pvTest2:%p count:%d\r\n",pvTest2,count);
		my_free(pvTest1);
		my_free(pvTest2);
		bsp_LedToggle(2);
		tx_thread_sleep(1000);
跑一个线程测试一下:
	(void)thread_input;
	while(1)
		my_free(pvTest1);
		my_free(pvTest2);
		bsp_LedToggle(2);
效果:
 楼主| 发表于 2022-9-25 23:04:32 | 显示全部楼层
之前上传重复的代码了,以下是my_malloc.c
static TX_BYTE_POOL malloc_pool_ = {0};
int init_malloc(uintptr_t heap_start, size_t heap_size)
	uint8_t r;
    r = tx_byte_pool_create(&malloc_pool_, "Heap Memory Pool",
            (void *)heap_start,
            heap_size);
    return (r == TX_SUCCESS) ? 0 : -1;
void * my_malloc(size_t size)
    void * ptr = NULL;
    if(size > 0)
        // We simply wrap the threadX call into a standard form
        uint8_t r = tx_byte_allocate(&malloc_pool_, &ptr, size,
            TX_WAIT_FOREVER);
        if(r != TX_SUCCESS)
            ptr = NULL;
    //else NULL if there was no size
    return ptr;
void my_free(void * ptr)
    if(ptr) {
        //We simply wrap the threadX call into a standard form
        uint8_t r = tx_byte_release(ptr);
发表于 2022-9-26 02:14:59 | 显示全部楼层
谢谢楼主分享。
发表于 2022-9-26 09:50:39 | 显示全部楼层
只可惜它有个致命缺点,无法realloc。
发表于 2022-9-26 10:13:04 | 显示全部楼层
发表于 2022-9-26 11:16:44 | 显示全部楼层
自己写一个就是了,先分配一个,然后把就内存的数据复制过来,然后删除旧内存。
发表于 2022-9-26 11:19:10 | 显示全部楼层
void *
realloc(void *p, size_t size)
  /* Allocate area of requested size. */
  void *pp = malloc(size);
  /* If no memory, keep existing block and indicate failure to reallocate. */
  if (pp == 0)
    return pp;
  /* Copy existing block if we were given one. */
  if (p)
      /* Recover size */
      size_t existing_size = ((unsigned *)p)[-1];
      /* Limit size to copy. */
      if (existing_size < size)
        size = existing_size;
      /* Make copy of data. */
      memcpy(pp, p, size);
      /* And we're done with the original block. */
      free(p);
  /* Return newly allocated block. */
  return pp;
发表于 2022-9-26 19:49:07 | 显示全部楼层
eric2013 发表于 2022-9-26 11:19
[mw_shl_code=c,true]void *
老大,这个我还是知道的!是只这么做效率比较低,因为任何情况下都需要从新拷贝。
也许tx没有提供就是为了提高速度,剩下了从新拼接的时间。
发表于 2022-9-27 12:44:44 | 显示全部楼层
也许tx没有提供就是为 ...
realloc一直都这样,没有特别高效的,后面大家有好的方案了,欢迎分享下。
所以一般安全关键,时间关键项目禁用动态内存分配。
发表于 2023-8-23 18:07:56 | 显示全部楼层
小白想请教一下,threadX申请动态内存都需要提供起始地址,这个起始地址怎么选啊,怎么知道当前程序哪些sram空着没用可以拿来申请内存呢?
发表于 2023-8-24 01:22:51 | 显示全部楼层
qwq 发表于 2023-8-23 18:07
小白想请教一下,threadX申请动态内存都需要提供起始地址,这个起始地址怎么选啊,怎么知道当前程序哪些sra ...
直接定义个大数组,将数组地址给他就行。
发表于 2023-8-24 14:15:37 | 显示全部楼层
eric2013 发表于 2023-8-24 01:22
直接定义个大数组,将数组地址给他就行。
噢噢,明白了,谢谢硬哥
GMT+8, 2024-5-31 23:33 , Processed in 0.216241 second(s), 28 queries .
