查看: 596|回复: 0
[CAN/FDCAN] STM32H7的CANFD过滤器配置有个FDCAN_FILTER_RANGE_NO_EIDM,其中EIDM是扩展ID屏蔽寄存器
发表于 2023-4-20 01:06:59 | 显示全部楼层 |阅读模式
过滤器设置:
/** @defgroup FDCAN_filter_type FDCAN Filter Type
#define FDCAN_FILTER_RANGE         ((uint32_t)0x00000000U) /*!< Range filter from FilterID1 to FilterID2                        */
#define FDCAN_FILTER_DUAL          ((uint32_t)0x00000001U) /*!< Dual ID filter for FilterID1 or FilterID2                       */
#define FDCAN_FILTER_MASK          ((uint32_t)0x00000002U) /*!< Classic filter: FilterID1 = filter, FilterID2 = mask            */
#define FDCAN_FILTER_RANGE_NO_EIDM ((uint32_t)0x00000003U) /*!< Range filter from FilterID1 to FilterID2, EIDM mask not applied */
GMT+8, 2024-6-8 10:35 , Processed in 0.258387 second(s), 28 queries .
