查看: 583|回复: 15
[STM32H7] HAL库tick时基不对
发表于 2023-6-1 14:33:44 | 显示全部楼层 |阅读模式
  HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);//选择系统时钟源600MHz
  HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/3000);   //1毫秒产生一次中断
  NVIC_SetPriority(SysTick_IRQn, 15);
这样除3000才是1ms的时基,新手求救
 楼主| 发表于 2023-6-1 14:34:02 | 显示全部楼层
使用STM32H7B0VBT6芯片
发表于 2023-6-1 14:57:30 | 显示全部楼层
可以考虑直接CubeMX生成个代码,测试下正常不,然后排查自己的配置。
发表于 2023-6-1 14:59:04 | 显示全部楼层
初始化时钟之后在初始化Systick
 楼主| 发表于 2023-6-1 17:15:53 | 显示全部楼层
直接生成的也是这样
 楼主| 发表于 2023-6-1 17:16:09 | 显示全部楼层
庄永 发表于 2023-6-1 14:59
初始化时钟之后在初始化Systick
是在时钟时候初始化的
 楼主| 发表于 2023-6-1 17:16:53 | 显示全部楼层
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLM = 5;
  RCC_OscInitStruct.PLL.PLLN = 112;
  RCC_OscInitStruct.PLL.PLLP = 2;
  RCC_OscInitStruct.PLL.PLLQ = 2;
  RCC_OscInitStruct.PLL.PLLR = 2;
  RCC_OscInitStruct.PLL.PLLRGE = RCC_PLL1VCIRANGE_2;
  RCC_OscInitStruct.PLL.PLLVCOSEL = RCC_PLL1VCOWIDE;
  RCC_OscInitStruct.PLL.PLLFRACN = 0;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  /** Initializes the CPU, AHB and APB buses clocks
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2
                              |RCC_CLOCKTYPE_D3PCLK1|RCC_CLOCKTYPE_D1PCLK1;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.SYSCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_HCLK_DIV1;
  RCC_ClkInitStruct.APB3CLKDivider = RCC_APB3_DIV2;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_APB1_DIV2;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_APB2_DIV2;
  RCC_ClkInitStruct.APB4CLKDivider = RCC_APB4_DIV2;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_7) != HAL_OK)
    Error_Handler();
时钟初始化代码
发表于 2023-6-2 08:32:58 | 显示全部楼层
Rose980 发表于 2023-6-1 17:15
直接生成的也是这样
把你自己添加的这三个函数删掉,CubeMX原始创建工程已经带滴答中断了。测试下正常不。
像你这个注释就有点问题,SYSTICK_CLKSOURCE_HCLK如何设置的600MHz。H7B0的最高不是280MHz么
然后就是正确的理解HCLK。
发表于 2023-6-2 09:26:12 | 显示全部楼层
做了个工程,分享下,正常。
7B0.7z (910.7 KB, 下载次数: 1)
 楼主| 发表于 2023-6-2 10:56:29 | 显示全部楼层
eric2013 发表于 2023-6-2 09:26
做了个工程,分享下,正常。
好的,谢谢我试一下,我的程序是烧录在外挂FLASH里的,不知道这个影响不影响
 楼主| 发表于 2023-6-2 10:56:53 | 显示全部楼层
HAL_SYSTICK_CL ...
因为之前超频到600了
 楼主| 发表于 2023-6-2 11:04:45 | 显示全部楼层
做了个工程,分享下,正常。
问下老哥,你这个示波器是测量哪里的
 楼主| 发表于 2023-6-2 11:12:22 | 显示全部楼层
做了个工程,分享下,正常。
这个工程好像选了Jlink烧录也没用啊
发表于 2023-6-2 11:33:08 | 显示全部楼层
Rose980 发表于 2023-6-2 11:12
这个工程好像选了Jlink烧录也没用啊
滴答中断里面加了个IO翻转。
 楼主| 发表于 2023-6-2 13:13:59 | 显示全部楼层
eric2013 发表于 2023-6-2 11:33
滴答中断里面加了个IO翻转。
破案了,嘉立创给我贴的8M的晶振
发表于 2023-6-2 16:14:14 | 显示全部楼层
Rose980 发表于 2023-6-2 13:13
破案了,嘉立创给我贴的8M的晶振
这种情况的话,防不胜防。
GMT+8, 2024-6-8 04:57 , Processed in 0.330549 second(s), 28 queries .
