查看: 367|回复: 1
[以太网] H7下调试PTP的Slave模式发现问题
发表于 2023-9-26 16:22:31 | 显示全部楼层 |阅读模式
在H7下调试PTP的Slave模式,网络上有一台Master模式的ptp设备,能发出ptp v1 和ptp v2的同步数据。发现使用了H7的IEEE 1588 time stamping模式后,只要收到来自网络上的Ptp V2和V1数据, H7的网卡接收就停止工作,发送还是正常。查了H7的参数手册,有一个地方说到不能同时接收V1及V2的数据,可通过寄存器可设置接收V1或V2。但设置了V2的标志位,问题还是一样没有解决。不知道是不是H7的一个bug?!
发表于 2023-9-27 06:14:36 | 显示全部楼层
PTP客户端?
软件实现也行
https://learn.microsoft.com/ZH-C ... ptp-client/chapter1
   This is a small demo of the NetX Duo PTP client on the high-performance NetX Duo TCP/IP stack.
   This demo relies on ThreadX, NetX Duo and NetX Duo PTP client API to execute the Precision Time
   Protocol.
#include <stdio.h>
#include "nx_api.h"
#include "nxd_ptp_client.h"
#ifndef SAMPLE_DHCP_DISABLE
#include "nxd_dhcp_client.h"
#endif /* SAMPLE_DHCP_DISABLE */
#define PTP_THREAD_PRIORITY 2
/* Define the ThreadX and NetX object control blocks...  */
static TX_THREAD        thread_0;
static NX_PACKET_POOL   pool_0;
static NX_IP            ip_0;
static NX_DHCP          dhcp_client;
static NX_PTP_CLIENT    ptp_client;
/* Define the IP thread's stack area.  */
static ULONG            ip_thread_stack[2048 / sizeof(ULONG)];
/* Define packet pool for the demonstration.  */
static ULONG            packet_pool_area[((1536 + sizeof(NX_PACKET)) * 32) / sizeof(ULONG)];
/* Define the ARP cache area.  */
static ULONG            arp_space_area[512 / sizeof(ULONG)];
/* Define the main thread.  */
static ULONG            thread_0_stack[2048 / sizeof(ULONG)];
static ULONG            ptp_stack[2048 / sizeof(ULONG)];
/* Define an error counter.  */
static ULONG            error_counter;
/* Define ptp utc offset.  */
static SHORT            ptp_utc_offset = 0;
#define IPV4_ADDRESS            IP_ADDRESS(0, 0, 0, 0)
#define IPV4_NETWORK_MASK       IP_ADDRESS(0, 0, 0, 0)
#else
#define IPV4_ADDRESS            IP_ADDRESS(10, 1, 0, 212)
#define IPV4_NETWORK_MASK       IP_ADDRESS(255, 255, 0, 0)
#define IPV4_GATEWAY_ADDR       IP_ADDRESS(10, 1, 0, 1)
#define DNS_SERVER_ADDRESS      IP_ADDRESS(10, 1, 0, 1)
/* Define the main thread entry point. */
static VOID thread_0_entry(ULONG thread_input);
/* PTP handler.  */
static UINT ptp_event_callback(NX_PTP_CLIENT *ptp_client_ptr, UINT event, VOID *event_data, VOID *callback_data);
static void dhcp_wait();
/***** Substitute your ethernet driver entry function here *********/
#ifndef NETWORK_DRIVER
#define NETWORK_DRIVER _nx_ram_network_driver
extern VOID NETWORK_DRIVER(NX_IP_DRIVER *driver_req_ptr);
#ifndef CLOCK_CALLBACK
#define CLOCK_CALLBACK nx_ptp_client_soft_clock_callback
extern UINT CLOCK_CALLBACK(NX_PTP_CLIENT *client_ptr, UINT operation,
                           NX_PTP_TIME *time_ptr, NX_PACKET *packet_ptr,
#ifdef HARDWARE_SETUP
extern VOID HARDWARE_SETUP();
int main()
    HARDWARE_SETUP();
    /* Enter the ThreadX kernel.  */
    tx_kernel_enter();
    return 0;
/* Define what the initial system looks like.  */
void    tx_application_define(void *first_unused_memory)
UINT  status;
    /* Initialize the NetX system.  */
    nx_system_initialize();
    /* Create a packet pool.  */
    status =  nx_packet_pool_create(&pool_0, "NetX Main Packet Pool", 1536,  (ULONG*)(((int)packet_pool_area + 15) & ~15) , sizeof(packet_pool_area));
    /* Check for pool creation error.  */
    if (status)
        error_counter++;
    /* Create an IP instance.  */
    status = nx_ip_create(&ip_0,
                          "NetX IP Instance 0",
                          IPV4_ADDRESS,
                          IPV4_NETWORK_MASK,
                          &pool_0,
                          NETWORK_DRIVER,
                          (UCHAR*)ip_thread_stack,
                          sizeof(ip_thread_stack),
                          1);
    /* Check for IP create errors.  */
    if (status)
        error_counter++;
    /* Enable ARP and supply ARP cache memory for IP Instance 0.  */
    status =  nx_arp_enable(&ip_0, (void *)arp_space_area, sizeof(arp_space_area));
    /* Check for ARP enable errors.  */
    if (status)
        error_counter++;
    /* Enable TCP traffic.  */
    status =  nx_tcp_enable(&ip_0);
    /* Check for TCP enable errors.  */
    if (status)
        error_counter++;
    /* Enable UDP traffic.  */
    status =  nx_udp_enable(&ip_0);
    /* Check for UDP enable errors.  */
    if (status)
        error_counter++;
    /* Enable ICMP.  */
    status =  nx_icmp_enable(&ip_0);
    /* Check for errors.  */
    if (status)
        error_counter++;
    /* Create the main thread.  */
    tx_thread_create(&thread_0, "thread 0", thread_0_entry, 0,
                     thread_0_stack, sizeof(thread_0_stack),
                     4, 4, TX_NO_TIME_SLICE, TX_AUTO_START);
/* Define the test threads.  */
void    thread_0_entry(ULONG thread_input)
NX_PTP_TIME tm;
NX_PTP_DATE_TIME date;
    dhcp_wait();
    /* Create the PTP client instance */
    nx_ptp_client_create(&ptp_client, &ip_0, 0, &pool_0,
                         PTP_THREAD_PRIORITY, (UCHAR *)ptp_stack, sizeof(ptp_stack),
                         CLOCK_CALLBACK, NX_NULL);
    /* start the PTP client */
    nx_ptp_client_start(&ptp_client, NX_NULL, 0, 0, 0, ptp_event_callback, NX_NULL);
    while(1)
        /* read the PTP clock */
        nx_ptp_client_time_get(&ptp_client, &tm);
        /* convert PTP time to UTC date and time */
        nx_ptp_client_utility_convert_time_to_date(&tm, -ptp_utc_offset, &date);
        /* display the current time */
        printf("%2u/%02u/%u %02u:%02u:%02u.%09lu\r\n", date.day, date.month, date.year, date.hour, date.minute, date.second, date.nanosecond);
        tx_thread_sleep(NX_IP_PERIODIC_RATE);
    NX_PARAMETER_NOT_USED(callback_data);
    switch (event)
        case NX_PTP_CLIENT_EVENT_MASTER:
            printf("new MASTER clock!\r\n");
        case NX_PTP_CLIENT_EVENT_SYNC:
            nx_ptp_client_sync_info_get((NX_PTP_CLIENT_SYNC *)event_data, NX_NULL, &ptp_utc_offset);
            printf("SYNC event: utc offset=%d\r\n", ptp_utc_offset);
        case NX_PTP_CLIENT_EVENT_TIMEOUT:
            printf("Master clock TIMEOUT!\r\n");
        default:
    return 0;
/* DHCP */
void dhcp_wait(void)
ULONG   actual_status;
ULONG   ip_address;
ULONG   network_mask;
ULONG   gw_address;
    printf("DHCP In Progress...\r\n");
    /* Create the DHCP instance.  */
    nx_dhcp_create(&dhcp_client, &ip_0, "dhcp_client");
    /* Start the DHCP Client.  */
    nx_dhcp_start(&dhcp_client);
    /* Wait util address is solved. */
    nx_ip_status_check(&ip_0, NX_IP_ADDRESS_RESOLVED, &actual_status, NX_WAIT_FOREVER);
    /* Get IP address. */
    nx_ip_address_get(&ip_0, &ip_address, &network_mask);
    nx_ip_gateway_address_get(&ip_0, &gw_address);
    /* Output IP address. */
    printf("IP address: %d.%d.%d.%d\r\nMask: %d.%d.%d.%d\r\nGateway: %d.%d.%d.%d\r\n",
           (INT)(ip_address >> 24),
           (INT)(ip_address >> 16 & 0xFF),
           (INT)(ip_address >> 8 & 0xFF),
           (INT)(ip_address & 0xFF),
           (INT)(network_mask >> 24),
           (INT)(network_mask >> 16 & 0xFF),
           (INT)(network_mask >> 8 & 0xFF),
           (INT)(network_mask & 0xFF),
           (INT)(gw_address >> 24),
           (INT)(gw_address >> 16 & 0xFF),
           (INT)(gw_address >> 8 & 0xFF),
           (INT)(gw_address & 0xFF));
GMT+8, 2024-5-6 07:16 , Processed in 0.227155 second(s), 26 queries .
