帮你使用我们的8.3.8版本测试了,默认配置无法拖动。
基于V5,V6和V7的LVGL模板,驱动支持单缓冲,双缓冲和配合硬件消隐的双缓冲,以及电容和电阻触摸全支持(2023-07-19)
https://www.armbbs.cn/forum.php?mod=viewthread&tid=120161
[C] 纯文本查看 复制代码 #include "../../lv_examples.h"
#if LV_USE_BTN && LV_BUILD_EXAMPLES
static void event_handler(lv_event_t * e)
lv_event_code_t code = lv_event_get_code(e);
if(code == LV_EVENT_CLICKED) {
LV_LOG_USER("Clicked");
else if(code == LV_EVENT_VALUE_CHANGED) {
LV_LOG_USER("Toggled");
void lv_example_btn_1(void)
lv_obj_t * label;
lv_obj_t * btn1 = lv_btn_create(lv_scr_act());
lv_obj_add_event_cb(btn1, event_handler, LV_EVENT_ALL, NULL);
lv_obj_align(btn1, LV_ALIGN_CENTER, 0, -40);
label = lv_label_create(btn1);
lv_label_set_text(label, "Button");
lv_obj_center(label);
lv_obj_t * btn2 = lv_btn_create(lv_scr_act());
lv_obj_add_event_cb(btn2, event_handler, LV_EVENT_ALL, NULL);
lv_obj_align(btn2, LV_ALIGN_CENTER, 0, 40);
lv_obj_add_flag(btn2, LV_OBJ_FLAG_CHECKABLE);
lv_obj_set_height(btn2, LV_SIZE_CONTENT);
label = lv_label_create(btn2);
lv_label_set_text(label, "Toggle");
