查看: 286|回复: 4
[STM32H7] STM32H7 ADC+DMA双缓存,数据不连续
发表于 2024-2-26 15:23:32 | 显示全部楼层 |阅读模式
STM32H7 time1+ADC+DMA双缓存,数据不连续,传输M0到M1缓存数据连续,再到M0就不连续了,传续128个数据,串口打印数据,程序是从V7-ADC定时器触发+DMA双缓冲实现更改来,使用硬件DMA双缓存,100Hz采样
MPU配置
*        函 数 名: MPU_Config
*        功能说明: 配置MPU
*        形    参: 无
*        返 回 值: 无
static void MPU_Config( void )
        MPU_Region_InitTypeDef MPU_InitStruct;
        /* 禁止 MPU */
        HAL_MPU_Disable();
        /* 配置AXI SRAM的MPU属性为Write back, Read allocate,Write allocate */
        MPU_InitStruct.Enable           = MPU_REGION_ENABLE;
        MPU_InitStruct.BaseAddress      = 0x24000000;
        MPU_InitStruct.Size             = MPU_REGION_SIZE_512KB;
        MPU_InitStruct.IsBufferable     = MPU_ACCESS_BUFFERABLE;
        MPU_InitStruct.IsCacheable      = MPU_ACCESS_CACHEABLE;
        MPU_InitStruct.IsShareable      = MPU_ACCESS_NOT_SHAREABLE;
        MPU_InitStruct.Number           = MPU_REGION_NUMBER0;
        MPU_InitStruct.TypeExtField     = MPU_TEX_LEVEL1;
        MPU_InitStruct.DisableExec      = MPU_INSTRUCTION_ACCESS_ENABLE;
        /* 配置FMC扩展IO的MPU属性为Device或者Strongly Ordered */
        MPU_InitStruct.BaseAddress      = 0x60000000;
        MPU_InitStruct.Size             = ARM_MPU_REGION_SIZE_64KB;
        MPU_InitStruct.IsCacheable      = MPU_ACCESS_NOT_CACHEABLE;        /* 不能用MPU_ACCESS_CACHEABLE;会出现2次CS、WE信号 */
        MPU_InitStruct.Number           = MPU_REGION_NUMBER1;
        MPU_InitStruct.TypeExtField     = MPU_TEX_LEVEL0;
        /* 配置SRAM4的属性为Write through, read allocate,no write allocate */
    MPU_InitStruct.BaseAddress      = 0x38000000;
    MPU_InitStruct.IsBufferable     = MPU_ACCESS_NOT_BUFFERABLE;
    MPU_InitStruct.Number           = MPU_REGION_NUMBER2;
        /*使能 MPU */
        HAL_MPU_Enable(MPU_PRIVILEGED_DEFAULT);
*        函 数 名: CPU_CACHE_Enable
*        功能说明: 使能L1 Cache
*        形    参: 无
*        返 回 值: 无
static void CPU_CACHE_Enable(void)
        /* 使能 I-Cache */
        SCB_EnableICache();
        /* 使能 D-Cache */
        SCB_EnableDCache();
bsp_adc.c
#include "bsp.h"
/* 选择ADC的时钟源 */
#define ADC_CLOCK_SOURCE_AHB     /* 选择AHB时钟源 */
//#define ADC_CLOCK_SOURCE_PLL     /* 选择PLL时钟源 */
/* 方便Cache类的API操作,做32字节对齐 */
#if defined ( __ICCARM__ )
#pragma location = 0x38000000
uint16_t ADCxValues[128];
#elif defined ( __CC_ARM )
ALIGN_32BYTES(__attribute__((section (".RAM_D3"))) uint16_t ADC1ConvertedValue_a[128] = {0});
ALIGN_32BYTES(__attribute__((section (".RAM_D3"))) uint16_t ADC1ConvertedValue_b[128] = {0});
uint16_t *ADC1ConvertedValue;
uint8_t flag_dma = 0;
uint8_t flag_AdcDwg = 0;
DMA_HandleTypeDef   DmaHandle = {0};
TIM_HandleTypeDef  htim ={0};
*        函 数 名: TIM1_Config
*        功能说明: 配置TIM1,用于触发ADC,当前配置的100KHz触发频率
*        形    参: 无
*        返 回 值: 无
static void TIM1_Config(void)
        TIM_OC_InitTypeDef sConfig = {0};
        /* 使能时钟 */
        __HAL_RCC_TIM1_CLK_ENABLE();
                bsp.c 文件中 void SystemClock_Config(void) 函数对时钟的配置如下:
        System Clock source       = PLL (HSE)
        SYSCLK(Hz)                = 400000000 (CPU Clock)
        HCLK(Hz)                  = 200000000 (AXI and AHBs Clock)
        AHB Prescaler             = 2
        D1 APB3 Prescaler         = 2 (APB3 Clock  100MHz)
        D2 APB1 Prescaler         = 2 (APB1 Clock  100MHz)
        D2 APB2 Prescaler         = 2 (APB2 Clock  100MHz)
        D3 APB4 Prescaler         = 2 (APB4 Clock  100MHz)
        因为APB1 prescaler != 1, 所以 APB1上的TIMxCLK = APB1 x 2 = 200MHz;
        因为APB2 prescaler != 1, 所以 APB2上的TIMxCLK = APB2 x 2 = 200MHz;
        APB4上面的TIMxCLK没有分频,所以就是100MHz;
        APB1 定时器有 TIM2, TIM3 ,TIM4, TIM5, TIM6, TIM7, TIM12, TIM13, TIM14,LPTIM1
        APB2 定时器有 TIM1, TIM8 , TIM15, TIM16,TIM17
        APB4 定时器有 LPTIM2,LPTIM3,LPTIM4,LPTIM5
    TIM12CLK = 200MHz/(Period + 1) / (Prescaler + 1) = 200MHz / 2000 / 1 = 100KHz
    HAL_TIM_Base_DeInit(&htim);
    htim.Instance               = TIM1;
        htim.Init.Period            = 2000 - 1;
        htim.Init.Prescaler         = 1000 - 1;
        htim.Init.ClockDivision     = 0;
        htim.Init.CounterMode       = TIM_COUNTERMODE_UP;
        htim.Init.RepetitionCounter = 0;
        HAL_TIM_Base_Init(&htim);
    sConfig.OCMode     = TIM_OCMODE_PWM1;
    sConfig.OCPolarity = TIM_OCPOLARITY_LOW;
    /* 占空比50% */
    sConfig.Pulse = 1000;
    if(HAL_TIM_OC_ConfigChannel(&htim, &sConfig, TIM_CHANNEL_1) != HAL_OK)
    /* 启动OC1 */
    if(HAL_TIM_OC_Start(&htim, TIM_CHANNEL_1) != HAL_OK)
*        函 数 名: bsp_InitADC
*        功能说明: 初始化ADC
*        形    参: 无
*        返 回 值: 无
void bsp_InitADC(void)
    ADC_HandleTypeDef   AdcHandle = {0};
        ADC_ChannelConfTypeDef   sConfig = {0};
        GPIO_InitTypeDef         GPIO_InitStruct;
  /* ## - 1 - 配置ADC采样的时钟 ####################################### */
#if defined (ADC_CLOCK_SOURCE_PLL)
        /* 配置PLL2时钟为的72MHz,方便分频产生ADC最高时钟36MHz */
    RCC_PeriphCLKInitTypeDef PeriphClkInitStruct = {0};
        PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_ADC;
        PeriphClkInitStruct.PLL2.PLL2M = 25;
        PeriphClkInitStruct.PLL2.PLL2N = 504;
        PeriphClkInitStruct.PLL2.PLL2P = 7;
        PeriphClkInitStruct.PLL2.PLL2Q = 7;
        PeriphClkInitStruct.PLL2.PLL2R = 7;
        PeriphClkInitStruct.PLL2.PLL2RGE = RCC_PLL2VCIRANGE_0;
        PeriphClkInitStruct.PLL2.PLL2VCOSEL = RCC_PLL2VCOWIDE;
        PeriphClkInitStruct.PLL2.PLL2FRACN = 0;
        PeriphClkInitStruct.AdcClockSelection = RCC_ADCCLKSOURCE_PLL2;
        if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct) != HAL_OK)
#elif defined (ADC_CLOCK_SOURCE_AHB)
  /* 使用AHB时钟的话,无需配置,默认选择*/
        /* ## - 2 - 配置ADC采样使用的引脚 ####################################### */
        __HAL_RCC_GPIOA_CLK_ENABLE();
        GPIO_InitStruct.Pin = GPIO_PIN_4 | GPIO_PIN_6;
        GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
        HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
        /* ## - 3 - 配置ADC采样使用的时钟 ####################################### */
        __HAL_RCC_DMA1_CLK_ENABLE();
        DmaHandle.Instance                 = DMA1_Stream1;            /* 使用的DMA1 Stream1 */
        DmaHandle.Init.Request             = DMA_REQUEST_ADC1;            /* 请求类型采用DMA_REQUEST_ADC1 */
        DmaHandle.Init.Direction           = DMA_PERIPH_TO_MEMORY;    /* 传输方向是从外设到存储器 */
        DmaHandle.Init.PeriphInc           = DMA_PINC_DISABLE;        /* 外设地址自增禁止 */
        DmaHandle.Init.MemInc              = DMA_MINC_ENABLE;         /* 存储器地址自增使能 */
        DmaHandle.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD;  /* 外设数据传输位宽选择半字,即16bit */
        DmaHandle.Init.MemDataAlignment    = DMA_MDATAALIGN_HALFWORD;  /* 存储器数据传输位宽选择半字,即16bit */
        DmaHandle.Init.Mode                = DMA_DOUBLE_BUFFER_M0;    /* 双缓冲模式,使用第一个目标内存M0 */
        DmaHandle.Init.Priority            = DMA_PRIORITY_LOW;        /* 优先级低 */
        DmaHandle.Init.FIFOMode            = DMA_FIFOMODE_DISABLE;    /* 禁止FIFO*/
        DmaHandle.Init.FIFOThreshold       = DMA_FIFO_THRESHOLD_FULL; /* 禁止FIFO此位不起作用,用于设置阀值 */
        DmaHandle.Init.MemBurst            = DMA_MBURST_SINGLE;       /* 禁止FIFO此位不起作用,用于存储器突发 */
        DmaHandle.Init.PeriphBurst         = DMA_PBURST_SINGLE;       /* 禁止FIFO此位不起作用,用于外设突发 */
    /* 初始化DMA */
    if(HAL_DMA_Init(&DmaHandle) != HAL_OK)
    /* 开启DMA1 Stream1的中断 */
    HAL_NVIC_SetPriority(DMA1_Stream1_IRQn, 2, 0);
    HAL_NVIC_EnableIRQ(DMA1_Stream1_IRQn);
    /* 关联ADC句柄和DMA句柄 */
        __HAL_LINKDMA(&AdcHandle, DMA_Handle, DmaHandle);
        /* ## - 4 - 配置ADC ########################################################### */
        __HAL_RCC_ADC12_CLK_ENABLE();
        AdcHandle.Instance = ADC1;
        AdcHandle.Init.ClockPrescaler        = ADC_CLOCK_ASYNC_DIV2;          /* 采用PLL异步时钟,2分频,即72MHz/2 = 36MHz */
        AdcHandle.Init.ClockPrescaler        = ADC_CLOCK_SYNC_PCLK_DIV4;      /* 采用AHB同步时钟,4分频,即200MHz/4 = 50MHz */
        AdcHandle.Init.Resolution            = ADC_RESOLUTION_16B;            /* 16位分辨率 */
        AdcHandle.Init.ScanConvMode          = ADC_SCAN_DISABLE;              /* 禁止扫描,因为仅开了一个通道 */
        AdcHandle.Init.EOCSelection          = ADC_EOC_SINGLE_CONV;           /* EOC转换结束标志 */
        AdcHandle.Init.LowPowerAutoWait      = DISABLE;                       /* 禁止低功耗自动延迟特性 */
        AdcHandle.Init.ContinuousConvMode    = DISABLE;                       /* 禁止自动转换,采用的定时器触发转换 */
        AdcHandle.Init.NbrOfConversion       = 1;                             /* 使用了1个转换通道 */
        AdcHandle.Init.DiscontinuousConvMode = DISABLE;                       /* 禁止不连续模式 */
        AdcHandle.Init.NbrOfDiscConversion   = 1;                             /* 禁止不连续模式后,此参数忽略,此位是用来配置不连续子组中通道数 */
        AdcHandle.Init.ExternalTrigConv      = ADC_EXTERNALTRIG_T1_CC1;            /* 定时器1的CC1触发 */
        AdcHandle.Init.ExternalTrigConvEdge  = ADC_EXTERNALTRIGCONVEDGE_RISING;    /* 上升沿触发 */
        AdcHandle.Init.ConversionDataManagement = ADC_CONVERSIONDATA_DMA_CIRCULAR; /* DMA循环模式接收ADC转换的数据 */
        AdcHandle.Init.Overrun                  = ADC_OVR_DATA_OVERWRITTEN;        /* ADC转换溢出的话,覆盖ADC的数据寄存器 */
        AdcHandle.Init.OversamplingMode         = DISABLE;                         /* 禁止过采样 */
    /* 初始化ADC */
        if (HAL_ADC_Init(&AdcHandle) != HAL_OK)
        /* 校准ADC,采用偏移校准 */
        if (HAL_ADCEx_Calibration_Start(&AdcHandle, ADC_CALIB_OFFSET, ADC_SINGLE_ENDED) != HAL_OK)
        /* 配置ADC通道  */
        sConfig.Channel      = ADC_CHANNEL_3;              /* 配置使用的ADC通道 */
        sConfig.Rank         = ADC_REGULAR_RANK_1;          /* 采样序列里的第1个 */
        sConfig.SamplingTime = ADC_SAMPLETIME_1CYCLE_5;     /* 采样周期 */
        sConfig.SingleDiff   = ADC_SINGLE_ENDED;            /* 单端输入 */
        sConfig.OffsetNumber = ADC_OFFSET_NONE;             /* 无偏移 */
        sConfig.Offset = 0;                                 /* 无偏移的情况下,此参数忽略 */
        if (HAL_ADC_ConfigChannel(&AdcHandle, &sConfig) != HAL_OK)
        /* ## - 6 - 启动ADC的DMA方式传输 ####################################### */
//        if (HAL_ADC_Start_DMA(&AdcHandle, (uint32_t *)ADC1ConvertedValue_a, 128) != HAL_OK)
//                Error_Handler(__FILE__, __LINE__);
        if (HAL_DMAEx_MultiBufferStart_IT(&DmaHandle, (uint32_t)&AdcHandle.Instance->DR, (uint32_t)ADC1ConvertedValue_a,(uint32_t)ADC1ConvertedValue_b, 128) != HAL_OK)
        HAL_ADC_Start(&AdcHandle);
        /* ## - 5 - 配置ADC的定时器触发 ####################################### */
        TIM1_Config();
*        函 数 名: DMA1_Stream1_IRQHandler
*        功能说明: DMA1 Stream1中断服务程序
*        形    参: 无
*        返 回 值: 无
void DMA1_Stream1_IRQHandler(void)
        /* 传输完成中断 */
        if((DMA1->LISR & DMA_FLAG_TCIF1_5) != RESET)
                flag_dma = 1;
          /* Current memory buffer used is Memory 0 */
          if((((DMA_Stream_TypeDef   *)DmaHandle.Instance)->CR & DMA_SxCR_CT) == 0U)
                ADC1ConvertedValue = ADC1ConvertedValue_b;
          /* Current memory buffer used is Memory 1 */
                ADC1ConvertedValue = ADC1ConvertedValue_a;
                /* 清除标志 */
                DMA1->LIFCR = DMA_FLAG_TCIF1_5;
        /* 半传输完成中断 */
        if((DMA1->LISR & DMA_FLAG_HTIF1_5) != RESET)
                /* 清除标志 */
                DMA1->LIFCR = DMA_FLAG_HTIF1_5;
        /* 传输错误中断 */
        if((DMA1->LISR & DMA_FLAG_TEIF1_5) != RESET)
                /* 清除标志 */
                DMA1->LIFCR = DMA_FLAG_TEIF1_5;
        /* 直接模式错误中断 */
        if((DMA1->LISR & DMA_FLAG_DMEIF1_5) != RESET)
                /* 清除标志 */
                DMA1->LIFCR = DMA_FLAG_DMEIF1_5;
main
int main(void)
        ST固件库中的启动文件已经执行了 SystemInit() 函数,该函数在 system_stm32f4xx.c 文件,主要功能是
    配置CPU系统的时钟,内部Flash访问时序,配置FSMC用于外部SRAM
    bsp_Init(); /* 硬件初始化 */
    bsp_StartAutoTimer(0, 500); /* 启动1个500ms的自动重装的定时器 */
    uint16_t i = 0;
    /* 进入主程序循环体 */
    while (1)
        if(bsp_CheckTimer(0))
            bsp_LedToggle(2);
        if(flag_dma == 1)
                        for(i=0;i<128;i++){
                                printf("%d\n",ADC1ConvertedValue);
            flag_dma = 0;
发表于 2024-2-26 17:12:13 | 显示全部楼层
1、触发速度设置为10Hz
2、RAM D3的MPU配置设置成和AXI SRAM一样试试,也就是关闭Cache读写
 楼主| 发表于 2024-2-27 09:02:33 | 显示全部楼层
触发速度改为10Hz,就好很多
更改/* 配置SRAM3的属性为Write back, Read allocate,Write allocate */ 数据仍旧不连续,M0切换M1连续,再从M1切换M0数据不连续
        MPU_InitStruct.BaseAddress      = 0x30040000;
更改定时器,触发速度从100Hz改为10Hz,串口数据好很多
        htim.Init.Prescaler         = 10000 - 1;
    /* 占空比50% */
    /* 启动OC1 */
 楼主| 发表于 2024-2-27 09:31:12 | 显示全部楼层
100Hz的速度会导致数据不连续么.100Hz速度不是很快,还是MPU没有配置好
发表于 2024-2-27 09:40:39 | 显示全部楼层
zqy 发表于 2024-2-27 09:02
触发速度改为10Hz,就好很多
更改/* 配置SRAM3的属性为Write back, Read allocate,Write allocate */ 数 ...
修改的应该是这样的,设置为这个帖子里面一样的最低性能
https://www.armbbs.cn/forum.php?mod=viewthread&tid=99322
然后你的这个RAM_D3的首地址是多少
GMT+8, 2024-5-12 21:57 , Processed in 0.269731 second(s), 29 queries .
