查看: 415|回复: 1
[Cyclone TCP] CycloneTCP带宽测试
发表于 2024-3-8 14:16:29 | 显示全部楼层 |阅读模式
测试程序基于CycloneTCP nucleo_h743zi2 例程,硬件:nucleo_h743zi2开发板
测试程序如下,板子作为客户端,
void iperfTask(void *param){
        Socket *erfSocket;
      Socket *clientSocket;
        IpAddr erfipAddr;
      uint16_t clientPort;
      size_t recvSize=0;
        error_t error;
      while(1){
            erfSocket = socketOpen(SOCKET_TYPE_STREAM, SOCKET_IP_PROTO_TCP);
            if(erfSocket == NULL)
                 continue;
            error = socketBindToInterface(erfSocket,&netInterface[0]);
            if(error){
                 socketClose(erfSocket);
                 continue;
            #if 0
            error = socketBind(erfSocket, &IP_ADDR_ANY, 6650);
            if(error){
                 continue;
            error = socketListen(erfSocket, 0);
            if(error){
                 continue;
            clientSocket=socketAccept(erfSocket,&erfipAddr,&clientPort);
                 continue;
            ipStringToAddr("192.168.2.187", &erfipAddr);
            error =socketConnect(erfSocket,  &erfipAddr,5001);
          if(error){
                 continue;
            while(1)
                    //error =socketReceive(clientSocket,erfBuffer,2048,&recvSize,0);
                //    if(error){
                    //    continue;
                //    }else{
                        socketSend(erfSocket,txbuf_const,2048,NULL,0);
测试结构截图
测试结果感觉不理想,只有45Mbit,不知道哪里还能优化
順便相同硬件环境测试了一下freeRTOS+LWIP
能达到70Mbit
发表于 2024-3-9 01:02:10 | 显示全部楼层
H743应该拉满,优化空间还很大
GMT+8, 2024-5-20 00:42 , Processed in 0.201327 second(s), 29 queries .
