查看: 383|回复: 3
[其它] CMSIS 的 startup
发表于 2024-4-1 14:30:30 | 显示全部楼层 |阅读模式
新的DFP好像该用c来写startup了
发表于 2024-4-1 19:02:46 | 显示全部楼层
发出来看看
 楼主| 发表于 2024-4-1 21:40:18 | 显示全部楼层
发表于 2024-4-2 07:58:32 | 显示全部楼层
谢谢楼主分享,确实是的
https://github.com/ARM-software/ ... ce/startup_Device.c
 * @file     startup_<Device>.c
 * @brief    CMSIS-Core(M) Device Startup File for
 *           Device <Device>
 * @version  V1.0.0
 * @date     20. January 2021
 * Copyright (c) 2009-2021 Arm Limited. All rights reserved.
 * SPDX-License-Identifier: Apache-2.0
 * Licensed under the Apache License, Version 2.0 (the License); you may
 * not use this file except in compliance with the License.
 * You may obtain a copy of the License at
 * [url]www.apache.org/licenses/LICENSE-2.0[/url]
 * Unless required by applicable law or agreed to in writing, software
 * distributed under the License is distributed on an AS IS BASIS, WITHOUT
 * WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
 * See the License for the specific language governing permissions and
 * limitations under the License.
/* ToDo: rename this file from 'startup_Device.c' to 'startup_<Device>.c according to your device naming */
#include "<Device>.h"
  External References
extern uint32_t __INITIAL_SP;
extern uint32_t __STACK_LIMIT;
#if defined (__ARM_FEATURE_CMSE) && (__ARM_FEATURE_CMSE == 3U)
extern uint32_t __STACK_SEAL;
extern __NO_RETURN void __PROGRAM_START(void);
  Internal References
__NO_RETURN void Reset_Handler  (void);
__NO_RETURN void Default_Handler(void);
/* ToDo: Add Cortex exception handler according the used Cortex-Core */
  Exception / Interrupt Handler
/* Exceptions */
void NMI_Handler            (void) __attribute__ ((weak, alias("Default_Handler")));
void HardFault_Handler      (void) __attribute__ ((weak));
void MemManage_Handler      (void) __attribute__ ((weak, alias("Default_Handler")));
void BusFault_Handler       (void) __attribute__ ((weak, alias("Default_Handler")));
void UsageFault_Handler     (void) __attribute__ ((weak, alias("Default_Handler")));
void SecureFault_Handler    (void) __attribute__ ((weak, alias("Default_Handler")));
void SVC_Handler            (void) __attribute__ ((weak, alias("Default_Handler")));
void DebugMon_Handler       (void) __attribute__ ((weak, alias("Default_Handler")));
void PendSV_Handler         (void) __attribute__ ((weak, alias("Default_Handler")));
void SysTick_Handler        (void) __attribute__ ((weak, alias("Default_Handler")));
/* ToDo: Add your device specific interrupt handler */
void <DeviceInterrupt first>_Handler     (void) __attribute__ ((weak, alias("Default_Handler")));
void <DeviceInterrupt last>_Handler      (void) __attribute__ ((weak, alias("Default_Handler")));
  Exception / Interrupt Vector table
#if defined ( __GNUC__ )
#pragma GCC diagnostic push
#pragma GCC diagnostic ignored "-Wpedantic"
/* ToDo: Add Cortex exception vectors according the used Cortex-Core */
extern const VECTOR_TABLE_Type __VECTOR_TABLE[<Device vector table entries>];
       const VECTOR_TABLE_Type __VECTOR_TABLE[<Device vector table entries>] __VECTOR_TABLE_ATTRIBUTE = {
  (VECTOR_TABLE_Type)(&__INITIAL_SP),  /*     Initial Stack Pointer */
  Reset_Handler,                       /*     Reset Handler */
  NMI_Handler,                         /* -14 NMI Handler */
  HardFault_Handler,                   /* -13 Hard Fault Handler */
  MemManage_Handler,                   /* -12 MPU Fault Handler */
  BusFault_Handler,                    /* -11 Bus Fault Handler */
  UsageFault_Handler,                  /* -10 Usage Fault Handler */
  SecureFault_Handler,                 /*  -9 Secure Fault Handler */
  0,                                   /*     Reserved */
  0,                                   /*     Reserved */
  0,                                   /*     Reserved */
  SVC_Handler,                         /*  -5 SVCall Handler */
  DebugMon_Handler,                    /*  -4 Debug Monitor Handler */
  0,                                   /*     Reserved */
  PendSV_Handler,                      /*  -2 PendSV Handler */
  SysTick_Handler,                     /*  -1 SysTick Handler */
/* ToDo: Add your device specific interrupt vectors */
  /* Interrupts */
  <DeviceInterrupt first>_Handler,     /* first Device Interrupt */
  <DeviceInterrupt last>_Handler       /* last Device Interrupt */
#pragma GCC diagnostic pop
  Reset Handler called on controller reset
__NO_RETURN void Reset_Handler(void)
  __set_PSP((uint32_t)(&__INITIAL_SP));
/* ToDo: Initialize stack limit register for Armv8-M Main Extension based processors*/
  __set_MSPLIM((uint32_t)(&__STACK_LIMIT));
  __set_PSPLIM((uint32_t)(&__STACK_LIMIT));
/* ToDo: Add stack sealing for Armv8-M based processors */
  __TZ_set_STACKSEAL_S((uint32_t *)(&__STACK_SEAL));
  SystemInit();                    /* CMSIS System Initialization */
  __PROGRAM_START();               /* Enter PreMain (C library entry point) */
#if defined(__ARMCC_VERSION) && (__ARMCC_VERSION >= 6010050)
  #pragma clang diagnostic push
  #pragma clang diagnostic ignored "-Wmissing-noreturn"
  Hard Fault Handler
void HardFault_Handler(void)
  while(1);
  Default Handler for Exceptions / Interrupts
  while(1);
  #pragma clang diagnostic pop
GMT+8, 2024-6-3 19:57 , Processed in 0.285172 second(s), 33 queries .
