查看: 278|回复: 1
[emWin] 只有4个TEXT控件的EMIWN不进入WM_KEY?
发表于 2024-4-15 16:13:14 | 显示全部楼层 |阅读模式
#include "DIALOG.h"
extern GUI_CONST_STORAGE GUI_FONT GUI_Fontfont28;
extern GUI_CONST_STORAGE GUI_FONT GUI_Fontfont24;
extern GUI_CONST_STORAGE GUI_FONT GUI_Fontfont18;
*       Defines
#define ID_FRAMEWIN_0         (GUI_ID_USER + 0x00)
#define ID_TEXT_0 (GUI_ID_USER + 0x02)
#define ID_TEXT_1 (GUI_ID_USER + 0x04)
#define ID_TEXT_2 (GUI_ID_USER + 0x06)
#define ID_TEXT_3 (GUI_ID_USER + 0x08)
#define ID_TEXT_4 (GUI_ID_USER + 0x0C)
// USER START (Optionally insert additional defines)
// USER END
*       Static data
// USER START (Optionally insert additional static data)
// USER END
*       _aDialogCreate
static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] =
        { FRAMEWIN_CreateIndirect, "Framewin", ID_FRAMEWIN_0, 0, 0, 800, 480, 0, 0, 0},
        { TEXT_CreateIndirect, "Text0", ID_TEXT_0, 2, 1, 159, 40, 0, 100, 0 },
        { TEXT_CreateIndirect, "Text1", ID_TEXT_1, 340, 50, 30, 150, 0, 100, 0 },
        { TEXT_CreateIndirect, "Text2", ID_TEXT_2, 408, 50, 30, 150, 0, 100, 0 },
        { TEXT_CreateIndirect, "Text3", ID_TEXT_3, 340, 232, 30, 150, 0, 100, 0 },
        { TEXT_CreateIndirect, "Text4", ID_TEXT_4, 408, 232, 30, 150, 0, 100, 0 },
        //{ GRAPH_CreateIndirect, "Graph0", ID_GRAPH_0, 75, 35, 253, 180, 0, 0x0, 0},
        //{ GRAPH_CreateIndirect, "Graph1", ID_GRAPH_1, 450, 35, 253, 180, 0, 0x0, 0},
        //{ GRAPH_CreateIndirect, "Graph2", ID_GRAPH_2, 75, 217, 253, 180, 0, 0x0, 0},
        //{ GRAPH_CreateIndirect, "Graph3", ID_GRAPH_3, 450, 217, 253, 180, 0, 0x0, 0},
*       Static code
// USER START (Optionally insert additional static code)
// USER END
*       _cbDialog
  WM_HWIN hItem;
        GUI_UC_SetEncodeUTF8();
  // USER END
  switch (pMsg->MsgId) {
  case WM_INIT_DIALOG:
    // Initialization of 'Framewin'
            //初始化FRAMEWIN
                hItem = pMsg->hWin;
    FRAMEWIN_SetTitleHeight(hItem, 80);
          FRAMEWIN_SetText(hItem, "参数曲线");
    FRAMEWIN_SetTextAlign(hItem, GUI_TA_HCENTER | GUI_TA_VCENTER);
    FRAMEWIN_SetFont(hItem, &GUI_Fontfont28);
    FRAMEWIN_SetTextColor(hItem, 0x00000000);
    // Initialization of 'Text0'
    hItem = WM_GetDialogItem(pMsg->hWin, ID_TEXT_0);
    TEXT_SetText(hItem, "上下键翻页");
    TEXT_SetTextColor(hItem, 0x00000000);
    TEXT_SetFont(hItem, &GUI_Fontfont18);
    TEXT_SetTextAlign(hItem, GUI_TA_HCENTER | GUI_TA_VCENTER);
    // Initialization of 'Text1'
    hItem = WM_GetDialogItem(pMsg->hWin, ID_TEXT_1);
    TEXT_SetText(hItem, "高\n压\n曲\n线");
    TEXT_SetFont(hItem, &GUI_Fontfont24);
    // Initialization of 'Text2'
    hItem = WM_GetDialogItem(pMsg->hWin, ID_TEXT_2);
    TEXT_SetText(hItem, "脉\n搏\n波");
    // Initialization of 'Text3'
    hItem = WM_GetDialogItem(pMsg->hWin, ID_TEXT_3);
    TEXT_SetText(hItem, "低\n压\n曲\n线");
    // Initialization of 'Text4'
    hItem = WM_GetDialogItem(pMsg->hWin, ID_TEXT_4);
    TEXT_SetText(hItem, "脉\n率\n曲\n线");
                // USER START (Optionally insert additional code for further widget initialization)
    // USER END
  case WM_KEY:
            switch (((WM_KEY_INFO*)(pMsg->Data.p))->Key)
                case GUI_KEY_ENTER:
                    GUI_EndDialog(pMsg->hWin,0);
                        User1_historicaldata();
                case GUI_KEY_ESCAPE:
        CreateFramewin1();
  // USER END
  default:
    WM_DefaultProc(pMsg);
*       Public code
*       CreateFramewin
WM_HWIN User6_historicaldata(void);
WM_HWIN User6_historicaldata(void) {
  WM_HWIN hWin;
  hWin = GUI_CreateDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), &_cbDialog, WM_HBKWIN, 10, 9);
  return hWin;
 楼主| 发表于 2024-4-15 19:35:37 | 显示全部楼层
已经解决,是因为i控件全是TEXT,无法响应WM_KEY
修改办法:加入了一个大小是1X1的LISTVIEW控件
GMT+8, 2024-11-11 03:43 , Processed in 0.185241 second(s), 24 queries .
