查看: 200|回复: 2
[RL-FlashFS] 关于RLFS文件系统,文件时间的问题
发表于 2024-4-22 23:59:20 | 显示全部楼层 |阅读模式
按照文档,使用如下函数设置文件的时间,获取文件时间。
设置文件时间代码:
void set_timestamp (void) {
  fsTime timedate;
  // Set time and date
  timedate.hr   = 17;
  timedate.min  = 30;
  timedate.sec  = 2;
  timedate.day  = 25;
  timedate.mon  = 10;
  timedate.year = 2019;
  // Modify the timestamps
  if (ftime_set ("file.txt", &timedate, &timedate, &timedate) == fsOK) {
    printf ("File create, last access and last write time were successfully modified.\n");
  else {
    printf ("Failed to set the file timestamp.\n");
查看文件时间代码
void get_timestamp (void) {
  fsTime create, access, write;
  // Get the timestamps
  if (ftime_get ("file.txt", &create, &access, &write) == fsOK) {
    printf ("File create, last access and last write time were successfully retrieved.\n");
    //Output the file create time and date information
    printf ("Create Time: %d:%d:%d, %d.%d.%d\n", create.hr,  create.min, create.sec, \
                                                 create.day, create.mon, create.year);
  else {
    printf ("Failed to get the file timestamp.\n");
这两个函数,运行printf的信息都是成功的,设置文件时间后,又重新打印文件时间,运行看到的结果都是正确的。
但是,把SD卡拔出来,插到电脑上看,文件时间就不对了。时间也看不出什么规律来。这是什么问题?
发表于 2024-4-23 08:15:17 | 显示全部楼层
没测试过这个函数,后面有时间了试试。
发表于 2024-5-1 22:21:08 来自手机 | 显示全部楼层
试试先用fclose关掉文件,再设置ftime_set
GMT+8, 2024-5-22 03:26 , Processed in 0.267419 second(s), 26 queries .
