我的MCU是H743,扩展了NAND和SDRAM,LTDC扩展了彩屏,如下的MPU代码,我不知道是否有不妥的地方。目前有一个比较严重的问题就是:NAND里用的FLASHFS文件系统,但有些系统在开机时,会出现fmount返回11(无文件系统)的情况,不知道是否和MPU配置有关系?麻烦硬汉兄看一下,指导一下。
static void MPU_Config( void )
MPU_Region_InitTypeDef MPU_InitStruct;
/* ?? MPU */
HAL_MPU_Disable();
/* ??AXI SRAM?MPU???Write through, read allocate,no write allocate */
MPU_InitStruct.Enable = MPU_REGION_ENABLE;
MPU_InitStruct.BaseAddress = 0x24000000;
MPU_InitStruct.Size = MPU_REGION_SIZE_512KB;
MPU_InitStruct.IsBufferable = MPU_ACCESS_NOT_BUFFERABLE;
MPU_InitStruct.IsCacheable = MPU_ACCESS_CACHEABLE;
MPU_InitStruct.IsShareable = MPU_ACCESS_SHAREABLE;
MPU_InitStruct.Number = MPU_REGION_NUMBER0;
MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL0;
MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_ENABLE;
/* ??NAND Flash */
MPU_InitStruct.BaseAddress = 0x80000000;
MPU_InitStruct.Size = MPU_REGION_SIZE_512MB; // MPU_REGION_SIZE_512MB;
MPU_InitStruct.IsCacheable = MPU_ACCESS_NOT_CACHEABLE;
MPU_InitStruct.IsShareable = MPU_ACCESS_NOT_SHAREABLE;
MPU_InitStruct.Number = MPU_REGION_NUMBER1;
配置SDRAM的MPU属性为Write through, read allocate,no write allocate
这种配置的情况下,读Cache对性能提升有一定的作用,但使用GUI做Alpha的场合要注意。
需要用户手动做无效化操作。
MPU_InitStruct.BaseAddress = 0xC0000000;
MPU_InitStruct.Size = MPU_REGION_SIZE_32MB;
MPU_InitStruct.IsBufferable = MPU_ACCESS_BUFFERABLE;
MPU_InitStruct.Number = MPU_REGION_NUMBER2;
MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL1;
HAL_MPU_Enable(MPU_PRIVILEGED_DEFAULT);
