各位大佬 请教一下
环境: STM32H745 FDCAN (使用经典CAN) (滤波器 不限制) 连接USBCAN 由PC发讯
现象: 测试1. PC USB 上发出的第一包ID一定要是F结尾 1F FF等...之后ID 就可以不限制F结尾 (这样能收到)(HAL_FDCAN_GetRxMessage 接收到的资料是正确的)
测试2. PC USB 上发出的ID都不是F结尾 结果:HAL_FDCAN_RxFifo0Callback()能进去,但HAL_FDCAN_GetRxMessage()资料都是0
"测试2" 一但发送了F结尾的ID 之后就跟 "测试1"一样正常接收了
看网上没人有这个问题,研究了2天还是找不出原因 1.Filter改不同配置试过了 2. BaudRate 1M 500K 也试过 3.先由STM32发送一次再接收也一样
有点玄想不透
还请各位大佬指点指点 谢谢
void MX_FDCAN1_Init(void)
hfdcan1.Instance = FDCAN1;
hfdcan1.Init.FrameFormat = FDCAN_FRAME_CLASSIC;
hfdcan1.Init.Mode = FDCAN_MODE_NORMAL;
hfdcan1.Init.AutoRetransmission = DISABLE;
hfdcan1.Init.TransmitPause = DISABLE;
hfdcan1.Init.ProtocolException = DISABLE;
hfdcan1.Init.NominalPrescaler = 10;
hfdcan1.Init.NominalSyncJumpWidth = 1;
hfdcan1.Init.NominalTimeSeg1 = 5;
hfdcan1.Init.NominalTimeSeg2 = 2;
hfdcan1.Init.DataPrescaler = 10;
hfdcan1.Init.DataSyncJumpWidth = 1;
hfdcan1.Init.DataTimeSeg1 = 5;
hfdcan1.Init.DataTimeSeg2 = 2;
hfdcan1.Init.MessageRAMOffset = 0;
hfdcan1.Init.StdFiltersNbr = 1;
hfdcan1.Init.ExtFiltersNbr = 0;
hfdcan1.Init.RxFifo0ElmtsNbr = 32;
hfdcan1.Init.RxFifo0ElmtSize = FDCAN_DATA_BYTES_8;
hfdcan1.Init.RxFifo1ElmtsNbr = 0;
hfdcan1.Init.RxFifo1ElmtSize = FDCAN_DATA_BYTES_8;
hfdcan1.Init.RxBuffersNbr = 0;
hfdcan1.Init.RxBufferSize = FDCAN_DATA_BYTES_8;
hfdcan1.Init.TxEventsNbr = 0;
hfdcan1.Init.TxBuffersNbr = 0;
hfdcan1.Init.TxFifoQueueElmtsNbr = 16;
hfdcan1.Init.TxFifoQueueMode = FDCAN_TX_FIFO_OPERATION;
hfdcan1.Init.TxElmtSize = FDCAN_DATA_BYTES_8;
if (HAL_FDCAN_Init(&hfdcan1) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN FDCAN1_Init 2 */
FDCAN_FilterTypeDef sFilterConfig;
sFilterConfig.IdType = FDCAN_STANDARD_ID; // vs. Extended ID FDCAN_STANDARD_ID/FDCAN_EXTENDED_ID
sFilterConfig.FilterIndex = 0; // the number of the filter we are using
sFilterConfig.FilterType = FDCAN_FILTER_MASK;//FDCAN_FILTER_MASK FDCAN_FILTER_RANGE
sFilterConfig.FilterConfig = FDCAN_FILTER_TO_RXFIFO0; // what to do filter match
sFilterConfig.FilterID1 = 0 ; // filter
sFilterConfig.FilterID2 = 0; // mask: 0=>accept all messages
if (HAL_FDCAN_ConfigFilter(&hfdcan1, &sFilterConfig) != HAL_OK)
// Filter configuration error
Error_Handler();
//FDCAN_REJECT FDCAN_ACCEPT_IN_RX_FIFO0
if (HAL_FDCAN_ConfigGlobalFilter(&hfdcan1, FDCAN_ACCEPT_IN_RX_FIFO0 , FDCAN_FILTER_REMOTE,
FDCAN_FILTER_REMOTE, FDCAN_FILTER_REMOTE) != HAL_OK)
Error_Handler();
if (HAL_FDCAN_Start(&hfdcan1) != HAL_OK)
Error_Handler();
