查看: 7477|回复: 3
生产USBee的公司CWAV, Inc宣布关闭,不再售卖USBee测试工具
发表于 2016-1-5 18:22:18 | 显示全部楼层 |阅读模式
官方地址:http://www.usbee.com/company.htm
上位机界面
USBee的产品主要如下:
Technology
Wired Interconnect
USB 3.0 or USB 2.0 USB 2.0 USB 2.0  USB 2.0  USB 2.0   USB 2.0
Wireless Interconnect
WiFi 802.11b/g - - - - -
Mixed Signal Oscilloscope (MSO)
Logic Analyzer and Oscilloscope
Digital Channels
24
Max Sample Rate Digital
600 MS/s
600 MS/s
24 MS/s
24 MS/s
24 MS/s
24 MS/s
Fastest Digital Signal Measurable
300 MHz
300 MHz
12 MHz
12 MHz
12 MHz
12 MHz
Analog Channels
Max Sample Rate Analog
100 MS/s
100 MS/s
24 MS/s
na
na
na
Analog Resolution
1.4 mV
11.7 mV
78 mV
na
na
na
Analog Bandwidth (-3dB)
50 MHz
50 MHz
12 MHz
na
na
na
Max Sample Rate All Channels Sampling
100 MS/s
100 MS/s
8 MS/s
24 MS/s
24 MS/s
24 MS/s
Other Sample Rates (sps) - number of channels
200M - 16D
300M - 10D
600M - 4D
plus 100M on other channels
200M - 8D
300M - 5D
600M - 2D
24M - 8D
12M - 8Dx1A
12M - 16D
12M - 2A
24M - 8D
24M
24M - 8D
Sample Buffer Depth
896M samples shared by all channels internal
558M samples shared by all channels internal
200+ Million samples.  Uses PC RAM
Streams to Disk
200M
Streams to Disk or RAM
Up to 1T Samples to disk with optional QX Stream Module
To RAM
To RAM
Sample Compression
Maximum Capture Time all channels max speed max buffer
32 days
* depends on signal activity
16.3 days
25 secs
8.3 secs
8.3 secs
8.3 secs
Analog Input Range
+/- 6V or+/- 60V
+/- 6V or+/- 60V
+/- 10V
ADC
Quad 10-bit
Dual 10-bit
Dual 8-bit
Digital Input Range
+/- 60V
+/- 60V
0-5V
0-5V
0-5V
0-5V
Logic Threshold
Variable
-1V to +2V
Variable
-1V to +2V
Fixed
1.5V
Fixed
1.5V
Fixed
1.5V
Fixed
1.5V
Time Synchronized Spectrum Analyzer
FFT Analysis
with optional USBee QX Suite Pro
 楼主| 发表于 2016-1-5 18:25:57 | 显示全部楼层
发表于 2016-10-26 01:31:13 | 显示全部楼层
照片是什么意思?没有看懂。
 楼主| 发表于 2018-1-25 21:51:07 | 显示全部楼层
顶贴,清垃圾。
GMT+8, 2024-5-23 01:17 , Processed in 0.178302 second(s), 34 queries .
