LabTool is a versatile and powerful addition to your lab bench!
It is an add-on board to LPC-Link 2
(which is based on the LPC4370 - a 204 MHz Cortex-M4 with an 80 MHz ADC and two extra Cortex-M0 cores).
LabTool make use of all features on the LPC4370, creating a powerful development tool.[li]11 channel logic analyzer (up to 100Msamples per second)[/li][li]2 channel oscilloscope (up to 80 Msamples per second, 6MHz BW)[/li][li]11 channel digital signal generator (up to 80 Msamples per second)[/li][li]2 channel analog signal generator (40kHz BW)[/li]
The feature rich Windows software interface supports:[li]One shot and continuous sampling[/li][li]Sorting and moving of signals[/li][li]SPI, I2C, UART signal interpreters[/li][li]Project settings can be saved and restored[/li][li]Collected data can be exported[/li][li]Four cursors available to help interpret captured data[/li][li]Open source software[/li][li]Prepared for running under Linux and MAC[/li]
LabTool
Digital inputs | • 11 channel logic analyzer
• without trigger: 100 Msps (1-4 ch), 50 Msps (5-8 ch), 20 Msps (9-11 ch)
• with trigger: 100 Msps (1-2 ch), 80 Msps (3-4 ch), 40 Msps (5-8 ch), 20 Msps (9-11 ch)
• Falling/rising edge triggers with logical OR between channels
• 3.3V logic level as default but 2.4-5.5V supported via DIO_VCC | Analog inputs | • 2 channel oscilloscope
• 60 Msps (1 ch) and 30 Msps (2 ch) sampling (can be increased to 80/40 Msps if no hardware trigger is enabled)
• +-25V input range, 1 Mohm input impedance, TBD pF input capacitance
• AC/DC control
• BNC connector and flexible cables via 26-pos IDC connector
• 6 MHz BW (3 MHz for 20mV/div range and up to 12 MHz on 0.2V/div and 5V/div range) | Digital outputs | • 11 channel digital signal generator
• 80 Msps
• 3.3V logic level | Analog outputs | • 2 channel analog signal generator
• +-5V, 40 kHz BW
• Sine, square and triangle waveforms | Dimensions | 83 x 90 mm | Power | 5.0V via mini-B USB connector | Connectors |
• 26-pos IDC connector for digial and analog I/O
• Two BNC connectors
• Calibration signals, 1.25V/78mV
• Demo signals
• Cortex debug connector to on-board LPC812 (2x5 pos)
• Cortex debug connector from LPC-Link 2 connectors (2x5 pos) | Other | • 12 channel demo signal generator (UART, I2C, SPI, counter, PWM) from on-board LPC812.
• HW provision for I2C logging (sw not implemented)
• Analog calibration, can be done by user
• Open source software
我这里上传一个用户手册,其它的上位机软件,大家可以在官网下载
LabTool_UsersGuide_revPA5.pdf
(3.07 MB, 下载次数: 343)
http://www.embeddedartists.com/products/app/labtool.php
