查看: 8551|回复: 2
[embOS] SEGGER发布emModbus
发表于 2014-3-31 12:24:23 | 显示全部楼层 |阅读模式
emModbus
Modbus
Modbus is an open, mature, and straight forward communications protocol. It was originally published in 1979 by Modicon (Schneider Electric) and has since evolved into a standard communications protocol for industrial electronic devices.
Modbus was specifically designed to be used in supervisory control and data acquisition systems, connecting a supervisory computer with several remote terminal units (RTU). It therefore uses a master-slave-technique in which one device, the master, initiates transactions (called queries). Other devices, the slaves, respond by performing the action requested in the query and/or by supplying the requested data to the master.
See Wikipedia for further information.
emModbus
emModbus, SEGGER's implementation of the Modbus protocol, supports communication via UART (ASCII, RTU) and Ethernet (Modbus/TCP and Modbus/UDP) and is capable to communicate with any Modbus compliant device.
emModbus supports building master and slave devices, which can even be combined in the same product. Also, multiple interfaces in the same product are supported. Each interface can be configured at runtime, making it possible to build a pretested library to be deployed in multiple projects.
Features
    [li]Easy to integrate.[/li][li]Low memory footprint.[/li][li]ANSI-C code is completely portable and runs on any target.[/li][li]Follows the SEGGER coding standards: Efficient and compact, yet easy to read, understand & debug.[/li][li]Supports ASCII, RTU and Modbus/TCP (and UDP) protocol.[/li][li]Sample applications for all protocols included.[/li][li]Kernel abstraction layer: can be used with or without any RTOS.[/li][li]Works out-of-the-box with embOS.[/li][li]Modbus/TCP can be used with standard socket interface and any TCP/IP stack.[/li][li]Works out-of-the-box with embOS/IP.[/li][li]Project for executable on PC for Microsoft Visual Studio available.[/li]
 楼主| 发表于 2014-3-31 12:24:57 | 显示全部楼层
沈阳武警医院www.wjkfk.com/
发表于 2014-4-15 11:31:32 | 显示全部楼层
英文看不懂啊  整点中文的 老铁~
沈阳骨科医院www.wjkfk.com/
GMT+8, 2024-5-20 03:08 , Processed in 0.290527 second(s), 34 queries .
