查看: 2214|回复: 1
Intel Cyclone 10 LP FPGAs
发表于 2017-9-1 02:47:11 | 显示全部楼层 |阅读模式
 楼主| 发表于 2017-9-1 02:47:30 | 显示全部楼层
Half the Power at Half the Cost1
Intel's Cyclone® 10 LP FPGA family extends the Cyclone FPGA series low cost and power leadership. Ideal for high-volume, cost-sensitive functions, Intel Cyclone 10 LP FPGAs are designed for a broad spectrum of general logic applications.
Reduce Power Consumption
Built on a power-optimized 60 nm process, Intel Cyclone 10 LP FPGAs extend the low-power leadership of the previous generation Cyclone V FPGAs. The latest generation devices reduces core static power by up to 50 percent compared to the previous generations.
Lower Your System Costs
All Intel Cyclone 10 LP FPGAs require only two core power supplies for operation, simplifying your power distribution network and saving you board costs, board space, and design time. The flexibility of the Intel Cyclone 10 LP FPGA enables you to design in a smaller, lower cost device, lowering your total system costs.
Start your design today
Download Quartus Software
Buy Silicon Now
Buy Evaluation Kits Now
Applications
Intel Cyclone 10 LP FPGAs are ideal for cost
sensitive applications that require increasing lower static power as the need for scalable processing acceleration increases system interface requirements.
Typical end market examples include:
I/O expansion
Interfacing
Bridging
Sensor fusion
Industrial motor control
GMT+8, 2024-5-18 13:18 , Processed in 0.159300 second(s), 28 queries .
