楼主 |
发表于 2012-12-23 17:54:26
显示全部楼层
* How to use this driver
* 1. Enable write access to IWDG_PR and IWDG_RLR registers using
* IWDG_WriteAccessCmd(IWDG_WriteAccess_Enable) function
* 2. Configure the IWDG prescaler using IWDG_SetPrescaler() function
* 3. Configure the IWDG counter value using IWDG_SetReload() function.
* This value will be loaded in the IWDG counter each time the counter
* is reloaded, then the IWDG will start counting down from this value.
* 4. Start the IWDG using IWDG_Enable() function, when the IWDG is used
* in software mode (no need to enable the LSI, it will be enabled
* by hardware)
* 5. Then the application program must reload the IWDG counter at regular
* intervals during normal operation to prevent an MCU reset, using
* IWDG_ReloadCounter() function. |
