查看: 3000|回复: 1
[FreeRTOS] FreeRTOS task.c pxPortInitialiseStack
发表于 2018-4-10 23:22:22 | 显示全部楼层 |阅读模式
有大佬能解释一下这个函数嘛?搜了一下相关讲解,说的是压栈,有点不懂,这几个赋值语句就压栈了嘛?不用PUSH指令嘛?
StackType_t *pxPortInitialiseStack( StackType_t *pxTopOfStack, TaskFunction_t pxCode, void *pvParameters )
    /* Simulate the stack frame as it would be created by a context switch
    interrupt. */
    /* Offset added to account for the way the MCU uses the stack on entry/exit
    of interrupts, and to ensure alignment. */
    pxTopOfStack--;
    *pxTopOfStack = portINITIAL_XPSR;    /* xPSR */
    pxTopOfStack--;
    *pxTopOfStack = ( ( StackType_t ) pxCode ) & portSTART_ADDRESS_MASK;    /* PC */
    pxTopOfStack--;
    *pxTopOfStack = ( StackType_t ) prvTaskExitError;    /* LR */
    /* Save code space by skipping register initialisation. */
    pxTopOfStack -= 5;    /* R12, R3, R2 and R1. */
    *pxTopOfStack = ( StackType_t ) pvParameters;    /* R0 */
    /* A save method is being used that requires each task to maintain its
    own exec return value. */
    pxTopOfStack--;
    *pxTopOfStack = portINITIAL_EXEC_RETURN;
    pxTopOfStack -= 8;    /* R11, R10, R9, R8, R7, R6, R5 and R4. */
    return pxTopOfStack;
发表于 2018-4-11 01:03:16 | 显示全部楼层
这个是任务栈空间初始化,栈空间初始化就是就是初始化CM内核的所有寄存器。不需要push,CM内核是向下生长的满栈,直接从边界开初始化栈空间即可。
简单说的,每个任务都保存着一套系统寄存的数值,需要切换到那个任务,就保存当前值,恢复另一个任务的寄存器值给这些系统寄存器,从而实现任务切换。
每个任务创建的时候会给他分配栈空间,把进程栈指针PSP指向这个栈空间即可。这样就实现了每个任务的独立性栈空间操作。
GMT+8, 2024-5-24 06:11 , Processed in 0.186173 second(s), 25 queries .
