楼主 |
发表于 2015-5-5 18:02:57
显示全部楼层
Section - [13] Isn't there a lossless JPEG?
There's a great deal of confusion on this subject, which is not surprising because there are several different
compression methods all known as "JPEG". The commonly used method is "baseline JPEG" (or its variant "
progressive JPEG"). The same ISO standard also defines a very different method called "lossless JPEG".
And if that's not confusing enough, a new lossless standard called "JPEG-LS" is about to hit the streets.
When I say "lossless", I mean mathematically lossless: a lossless compression algorithm is one that guaran-
tees its decompressed output is bit-for-bit identical to the original input. This is a much stronger claim than "
visually indistinguishable from the original". Baseline JPEG can reach visual indistinguishability for most
photo-like images, but it can never be truly lossless.
Lossless JPEG is a completely different method that really is lossless. However, it doesn't compress nearly
as well as baseline JPEG; it typically can compress full-color data by around 2:1. And lossless JPEG works
well only on continuous-tone images. It does not provide useful compression of palette-color images or
low-bit-depth images.
Lossless JPEG has never been popular --- in fact, no common applications support it --- and it is now largely
obsolete. (For example, the new PNG standard outcompresses lossless JPEG on most images.) Recognizing
this, the ISO JPEG committee recently finished an all-new lossless compression standard called JPEG-LS
(you may have also heard of it under the name LOCO). JPEG-LS gives better compression than original
lossless JPEG, but still nowhere near what you can get with a lossy method. It's anybody's guess whether
this new standard will achieve any popularity.
It's worth repeating that cranking a regular JPEG implementation up to its maximum quality setting *does
not* get you lossless storage; even at the highest possible quality setting, baseline JPEG is lossy because it
is subject to roundoff errors in various calculations. Roundoff errors alone are nearly always too small to be
seen, but they will accumulate if you put the image through multiple cycles of compression (see section 10).
Many implementations won't even let you get to the maximum possible setting, because it's such an inefficient
way to use regular JPEG. With the IJG JPEG software, for example, you have to not only select "quality 100"
but also turn off chroma downsampling to minimize loss of information. The resulting files are far larger and
of only fractionally better quality than files generated at more reasonable settings. And they're still slightly
lossy! If you really need lossless storage, don't try to approximate it with regular JPEG. |
