楼主 |
发表于 2018-9-28 09:14:01
显示全部楼层
我用的phy是KSZ8863FLL,硬件是没有问题的,以前用的是Lwip跑的很稳定,以太网和phy驱动用的是ST提供的stm32f4x7_eth,现在想测试下Tcpnet,所以就移植了下。目前phy和以太网驱动都使用的lwip上的,Tcpnet使用的几个函数也进行了修改移植。现在怀疑是接收和发送函数那里没有按照Tcpnet的格式来,可能造成错误。
1、我使能了硬件以太网CRC校验
2、使用了memcpy字节copy函数3、ETH中断中发送信号给以太网数据处理任务
主要代码如下:
- static void ETH_MACDMA_Config(void)
- __IO uint32_t EthStatus = 0;
- ETH_InitTypeDef ETH_InitStructure;
- /* Enable ETHERNET clock */
- RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_ETH_MAC | RCC_AHB1Periph_ETH_MAC_Tx |
- RCC_AHB1Periph_ETH_MAC_Rx, ENABLE);
- /* Reset ETHERNET on AHB Bus */
- ETH_DeInit();
- /* Software reset */
- ETH_SoftwareReset();
- /* Wait for software reset */
- while (ETH_GetSoftwareResetStatus() == SET);
- /* ETHERNET Configuration --------------------------------------------------*/
- /* Call ETH_StructInit if you don't like to configure all ETH_InitStructure parameter */
- ETH_StructInit(D_InitStructure);
- /* Fill ETH_InitStructure parametrs */
- /*------------------------ MAC -----------------------------------*/
- ETH_InitStructure.ETH_AutoNegotiation = ETH_AutoNegotiation_Enable;
- //ETH_InitStructure.ETH_AutoNegotiation = ETH_AutoNegotiation_Disable;
- //ETH_InitStructure.ETH_Speed = ETH_Speed_10M;
- //ETH_InitStructure.ETH_Mode = ETH_Mode_FullDuplex;
- ETH_InitStructure.ETH_LoopbackMode = ETH_LoopbackMode_Disable;
- ETH_InitStructure.ETH_RetryTransmission = ETH_RetryTransmission_Disable;
- ETH_InitStructure.ETH_AutomaticPadCRCStrip = ETH_AutomaticPadCRCStrip_Disable;
- ETH_InitStructure.ETH_ReceiveAll = ETH_ReceiveAll_Disable;
- ETH_InitStructure.ETH_BroadcastFramesReception = ETH_BroadcastFramesReception_Enable;
- ETH_InitStructure.ETH_PromiscuousMode = ETH_PromiscuousMode_Disable;
- ETH_InitStructure.ETH_MulticastFramesFilter = ETH_MulticastFramesFilter_Perfect;
- ETH_InitStructure.ETH_UnicastFramesFilter = ETH_UnicastFramesFilter_Perfect;
- #ifdef CHECKSUM_BY_HARDWARE
- ETH_InitStructure.ETH_ChecksumOffload = ETH_ChecksumOffload_Enable;
- #endif
- /*------------------------ DMA -----------------------------------*/
- /* When we use the Checksum offload feature, we need to enable the Store and Forward mode:
- the store and forward guarantee that a whole frame is stored in the FIFO, so the MAC can insert/verify the checksum,
- if the checksum is OK the DMA can handle the frame otherwise the frame is dropped */
- ETH_InitStructure.ETH_DropTCPIPChecksumErrorFrame = ETH_DropTCPIPChecksumErrorFrame_Enable;
- ETH_InitStructure.ETH_ReceiveStoreForward = ETH_ReceiveStoreForward_Enable;
- ETH_InitStructure.ETH_TransmitStoreForward = ETH_TransmitStoreForward_Enable;
- ETH_InitStructure.ETH_ForwardErrorFrames = ETH_ForwardErrorFrames_Disable;
- ETH_InitStructure.ETH_ForwardUndersizedGoodFrames = ETH_ForwardUndersizedGoodFrames_Disable;
- ETH_InitStructure.ETH_SecondFrameOperate = ETH_SecondFrameOperate_Enable;
- ETH_InitStructure.ETH_AddressAlignedBeats = ETH_AddressAlignedBeats_Enable;
- ETH_InitStructure.ETH_FixedBurst = ETH_FixedBurst_Enable;
- ETH_InitStructure.ETH_RxDMABurstLength = ETH_RxDMABurstLength_32Beat;
- ETH_InitStructure.ETH_TxDMABurstLength = ETH_TxDMABurstLength_32Beat;
- ETH_InitStructure.ETH_DMAArbitration = ETH_DMAArbitration_RoundRobin_RxTx_2_1;
- /* Configure Ethernet */
- EthStatus = ETH_Init(D_InitStructure, PHY_ADDRESS);
- /* Enable the Ethernet Rx Interrupt */
- ETH_DMAITConfig(ETH_DMA_IT_NIS | ETH_DMA_IT_R, ENABLE);
