查看: 4537|回复: 1
[LibJPEG] 【LibJPEG专题系列二十二】提取图像大小
春暖花开
发表于 2015-5-18 17:13:46 | 显示全部楼层 |阅读模式
              Section - [22] How can my program extract
                    image dimensions from a JPEGfile?
The header of a JPEG file consists of a series of blocks, called "markers". The image height and width are stored
in a marker of type SOFn (Start Of Frame, type N).  To find the SOFn you must skip over the preceding markers;
you don't have to know what's in the other types of markers, just use their length words to skip over them.  The
minimum logic needed is perhaps a page of C code.  (Some people have recommended just searching for the byte
pair representing SOFn, without paying attention to the marker block structure. This is unsafe because a prior
marker might contain the SOFn pattern, either by chance or because it contains a JPEG-compressed thumbnail
image.  If you don't follow the marker structure you will retrieve the thumbnail's size instead of the main image
size.)  A profusely commented example in C can be found in rdjpgcom.c in the IJG distribution (see part 2, item
15).  Perl code can be found in wwwis, from http://www.tardis.ed.ac.uk/~ark/wwwis/.
努力打造安富莱高质量微信公众号:点击扫描图片关注
春暖花开
 楼主| 发表于 2015-5-18 17:14:58 | 显示全部楼层
                                   Section 22—提取图像尺寸
        JPEG文件的头文件包含一系列的块,被称为“标记”( markers)。图像的高度和宽度都存储在SOFn
类型(帧图像开始,N型)标记。为了找到SOFn必须跳过前面的标记;你不必知道其他类型的标记包含什么,
只需要使用它们的length words来跳过即可。所需的最低的逻辑也许只是一页C代码。(一些人曾建议只要搜
索一对一对的字节来表示SOFn,而不用把注意力放在块结构化标记上。但这是不保险的,因为以前的标记可
能包含SOFn模式,无论是偶然还是因为它包含了一个JPEG压缩的缩略图。如果不遵循标记结构,你检索的
将是缩略图的大小而非主图像的大小。)在IJG分区(part 2, item 15)的rdjpgcom.c中可以找到很多注释过
的例子。在wwwis中可找到Perl代码,可见于http://www.tardis.ed.ac.uk/~ark/wwwis/
GMT+8, 2024-5-23 19:38 , Processed in 0.238155 second(s), 25 queries .
