查看: 12133|回复: 13
[LVGL] Littlevgl GUI相关总结(基于v6.0)-(包含模拟器及oled移植)
发表于 2019-8-12 10:58:58 | 显示全部楼层 |阅读模式
Littlevgl GUI相关总结(v6.0)
The whole graphics library project consists of a few repostories:
  • lvgl the graphics library itself
  • lv_examples tutorials and example GUI applications
  • lv_boards ready to use project on various development boards and microcontrollers
  • lv_drivers drivers for common touch pad and display controllers
  • lv_utils image and font converter utilities
  • pc_simulator a cross platform simulator project to run LittlevGL on PC
一、PC端模拟器开发环境搭建
官方教程:https://littlevgl.com/pc-simulator
软件下载地址:
1.Eclipse CDT
eclipse-cpp-oxygen-R-win32-x86_64.zip
http://www.eclipse.org/cdt/downloads.php
2.SDL2
SDL2-devel-2.0.7-mingw.tar.gz
https://www.libsdl.org/download-2.0.php
3.MinGW-w64
x86_64-7.2.0-release-win32-sjlj-rt_v5-rev0.7z
https://sourceforge.net/projects/mingw-w64/files/?source=navbar
1、Install Eclipse CDT
Eclipse CDT is C/C++ IDE. You can use other IDEs as well but in this tutorial the configuration for Eclipse CDT is shown.
Eclipse is a Java based software therefore be sure Jave Runtime Environment is installed on your system.
On linux: sudo apt-get install default-jre
You can download Eclipse's CDT from: https://eclipse.org/cdt/. Start the nstaller and choose *Eclipse CDT* from the list
因不写java,不需要jdk,只要装jre就可以了
2、Install MinGW
官方MinGW很难下载,选择MinGW-w64替代。解压到某个目录,并且添加环境变量D:\mingw64\bin,打开CMD,输入gcc -v测试是否添加成功。重命名mingw64\bin下的mingw32-make.exe为make.exe
3、Install SDL 2
1)Download the development libraries of SDL.
Go to https://www.libsdl.org/download-2.0.php and download Development Libraries: SDL2-devel-2.0.5-mingw.tar.gz
2)Uncompress the file and go to x86_64-w64-mingw32 directory (for 64 bit MinGW) or to i686-w64-mingw32 (for 32 bit MinGW)
C:/Users/Administrator/AppData/Local/YNote/data/yanchao7788_neo@163.com/8fce9ef6e7584eb79861b33ce4301e27/clipboard.png
3)Copy x86_64-w64-mingw32/include/SDL2 folder to D:\mingw64\x86_64-w64-mingw32/include
C:/Users/Administrator/AppData/Local/YNote/data/yanchao7788_neo@163.com/425cd067ecb84a15a06c944d71261d77/clipboard.png
4)Copy x86_64-w64-mingw32/lib/ content to D:\mingw64\x86_64-w64-mingw32\lib
C:/Users/Administrator/AppData/Local/YNote/data/yanchao7788_neo@163.com/f7f11c4b965b4b33a505e1a769efbf66/clipboard.png
5)Copy x86_64-w64-mingw32/bin/SDL2.dll to {eclipse_worksapce}/pc_simulator/Debug/. Do it later when Eclipse is installed.
C:/Users/Administrator/AppData/Local/YNote/data/yanchao7788_neo@163.com/1c8203a33b69491091eea4821fb6510b/clipboard.png
4、Download example eclipse project
项目地址:https://github.com/littlevgl/pc_simulator_sdl_eclipse
clone到需要的地方,然后执行submodule update,将引用的仓库同步过来。
这是我修改好的工程:
https://gitee.com/yc_911/littevgl_eclipse_prj
5、Import pre-configed project to Eclipse
File->Import and choose General->Existing project into Workspace.
C:/Users/Administrator/AppData/Local/YNote/data/yanchao7788_neo@163.com/bd2a117a2f6549e09d24aaf4f1eba80e/clipboard.png
注:这里导入后,需要对工程的properties做一些修改,否则会出现
undefined reference to `WinMain@16'错误
C:/Users/Administrator/AppData/Local/YNote/data/yanchao7788_neo@163.com/2f923ab207ac4ba59c4fb666d4e843ba/clipboard.png
C:/Users/Administrator/AppData/Local/YNote/data/yanchao7788_neo@163.com/5d10c9b592c441af8faf5536328841cd/clipboard.png
6、Compile and Run
1)工程默认是单线程编译,不能忍,开启多线程编译
Properties->C/C++ Build->Behavior->Enable parallel build
2)编译时可能会报错:
..\lv_drivers\display\fbdev.c:17:10: fatal error: linux/fb.h: No such file or directory
这时需要修改文件:
lv_drv_conf.h
  1. #ifndef USE_FBDEV
  2. #  define USE_FBDEV           1
  3. #endif
  2. #  define USE_FBDEV           0
  3. #endif
原因是当前使用的是windows环境
二、基于stm32f103及单色OLED12864移植littlevgl
1、项目地址:
https://gitee.com/yc_911/f103_sh1106_sd
工程也做好了emWin的移植……
2、移植关键点:
1)1bit表示一个像素的处理,更新像素时如何去修改中的一个bit位
  1. #define BIT_SET(a,b) ((a) |= (1U<<(b)))
  2. #define BIT_CLEAR(a,b) ((a) &= ~(1U<<(b)))
  3. static void set_px_cb(struct _disp_drv_t *disp_drv, uint8_t *buf, lv_coord_t buf_w, lv_coord_t x, lv_coord_t y,
  4.                       lv_color_t color, lv_opa_t opa)
  5. {
  6.     uint16_t byte_index = x + (( y >> 3 ) * buf_w);
  7.     uint8_t  bit_index  = y & 0x7;
  8.     // == 0 inverts, so we get blue on black
  9.     if ( color.full == 0 )
  10.     {
  11.         BIT_SET( buf[ byte_index ] , bit_index );
  12.     }
  13.     else
  14.     {
  15.         BIT_CLEAR( buf[ byte_index ] , bit_index );
  16.     }
  17. }
2)oled只能一次更新一个byte,即一次更新8个像素点,因此在更新FB时就只能扩大更新范围,只要更新某个bit,则需要更新整个byte
  1. <div yne-bulb-block="code" id="9399-1565577938779" data-theme="default" data-language="javascript">static void rounder_cb(struct _disp_drv_t *disp_drv, lv_area_t *area)
  2. {
  3.     area->y1 = (area->y1 & (~0x7));
  4.     area->y2 = (area->y2 & (~0x7)) + 7;
  5. }
  6. </div><div yne-bulb-block="paragraph" style="line-height: 1.75;"></div>
参与人数 2金币 +120 收起 理由
missfox + 20 赞一个!
eric2013 + 100 很给力!
发表于 2019-8-12 11:00:39 | 显示全部楼层
非常感谢楼主这么详细的总结
 楼主| 发表于 2019-8-12 11:03:50 | 显示全部楼层
eric2013 发表于 2019-8-12 11:00
非常感谢楼主这么详细的总结
搬了一部分官方的教程,然后添加了一些自己遇到的问题及解决方法
发表于 2019-8-12 11:18:17 | 显示全部楼层
Mark,好贴
代码不规范,亲人两行泪!
发表于 2019-8-13 20:20:39 | 显示全部楼层
我记得官方有vs2017的工程移植吧。。
发表于 2019-8-17 08:51:18 | 显示全部楼层
大力支持,正好在用
发表于 2019-8-17 16:46:22 | 显示全部楼层
单色OLED 屏幕我都用ugui之类的小库,杀鸡用牛刀啊
发表于 2019-8-19 00:45:49 | 显示全部楼层
发表于 2020-4-10 12:52:12 | 显示全部楼层
这个好支持下
发表于 2020-8-25 11:24:28 | 显示全部楼层
好帖,支持一下
发表于 2020-9-24 09:42:19 | 显示全部楼层
顶!顶!顶!
发表于 2020-11-19 10:59:04 | 显示全部楼层
能不能把最新的移植一下
发表于 2022-5-9 09:58:13 | 显示全部楼层
你们好,我移植到我的1.3寸oled(SH1106),屏幕最右侧有两列像素的不受控呢?有人遇到相同问题吗?
发表于 2022-7-7 15:18:24 | 显示全部楼层
我也遇到了相同问题
GMT+8, 2024-5-14 13:05 , Processed in 0.262375 second(s), 32 queries .
