查看: 2222|回复: 5
[以太网] 配套新版RL-TCPnet V7.X和LwIP的DM9162/9161驱动,符合CMSIS-Driver驱动规范,适用于所有STM32系列
发表于 2019-8-14 01:17:46 | 显示全部楼层 |阅读模式
PHY_DM916x.c (8.92 KB, 下载次数: 36)
PHY_DM916x.h (7.57 KB, 下载次数: 37)
  1. /*
  3. *
  4. *        模块名称 : DM9161/9162 FOR CMSIS Driver
  5. *        文件名称 : PHY_DM916x.c
  6. *        版    本 : V1.0
  7. *        说    明 : DM9161/9162驱动。
  8. *
  9. *        修改记录 :
  10. *                版本号   日期         作者        说明
  11. *                V1.0    2019-08-14   Eric2013     首版
  12. *
  13. *        Copyright (C), 2019-2030, 安富莱电子 www.armfly.com
  14. *
  16. */
  17. /* Copyright (c) 2013-2018 Arm Limited. All rights reserved.
  18. *
  19. * SPDX-License-Identifier: Apache-2.0
  20. *
  21. * Licensed under the Apache License, Version 2.0 (the License); you may
  22. * not use this file except in compliance with the License.
  23. * You may obtain a copy of the License at
  24. *
  25. * www.apache.org/licenses/LICENSE-2.0
  26. *
  27. * Unless required by applicable law or agreed to in writing, software
  28. * distributed under the License is distributed on an AS IS BASIS, WITHOUT
  29. * WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
  30. * See the License for the specific language governing permissions and
  31. * limitations under the License.
  32. *
  33. * -----------------------------------------------------------------------
  34. *
  35. * $Date:        25. May 2018
  36. * $Revision:    V6.3
  37. *
  38. * Driver:       Driver_ETH_PHYn (default: Driver_ETH_PHY0)
  39. * Project:      Ethernet Physical Layer Transceiver (PHY)
  40. *               Driver for KSZ8081RNA (KSZ8081RNB compatible)
  41. * -----------------------------------------------------------------------
  42. * Use the following configuration settings in the middleware component
  43. * to connect to this driver.
  44. *
  45. *   Configuration Setting                     Value
  46. *   ---------------------                     -----
  47. *   Connect to hardware via Driver_ETH_PHY# = n (default: 0)
  48. * -------------------------------------------------------------------- */
  49. /* History:
  50. *  Version 6.3
  51. *    Added reference clock select configuration option (ETH_PHY_REF_CLK_50M)
  52. *  Version 6.2
  53. *    Updated for ARM compiler 6
  54. *  Version 6.1
  55. *    Added driver flow control flags
  56. *  Version 6.0
  57. *    Initial release
  58. */
  59. #include "PHY_DM916x.h"
  60. #define ARM_ETH_PHY_DRV_VERSION ARM_DRIVER_VERSION_MAJOR_MINOR(6,2) /* driver version */
  61. #ifndef ETH_PHY_NUM
  62. #define ETH_PHY_NUM          0        /* Default driver number */
  63. #endif
  64. #ifndef ETH_PHY_ADDR
  65. #define ETH_PHY_ADDR         0x01     /* Default device address */
  66. #endif
  67. #ifndef ETH_PHY_REF_CLK_50M
  68. #define ETH_PHY_REF_CLK_50M  0        /* RMII Reference Clock (0:25MHz,1:50MHz) */
  69. #endif
  70. /* Driver Version */
  71. static const ARM_DRIVER_VERSION DriverVersion = {
  72.   ARM_ETH_PHY_API_VERSION,
  73.   ARM_ETH_PHY_DRV_VERSION
  74. };
  75. /* Ethernet PHY control structure */
  76. static PHY_CTRL PHY = { NULL, NULL, 0, 0, 0 };
  77. /**
  78.   \fn          ARM_DRIVER_VERSION GetVersion (void)
  79.   \brief       Get driver version.
  80.   \return      \ref ARM_DRIVER_VERSION
  81. */
  82. static ARM_DRIVER_VERSION GetVersion (void) {
  83.   return DriverVersion;
  84. }
  85. /**
  86.   \fn          int32_t Initialize (ARM_ETH_PHY_Read_t  fn_read,
  87.                                    ARM_ETH_PHY_Write_t fn_write)
  88.   \brief       Initialize Ethernet PHY Device.
  89.   \param[in]   fn_read   Pointer to \ref ARM_ETH_MAC_PHY_Read
  90.   \param[in]   fn_write  Pointer to \ref ARM_ETH_MAC_PHY_Write
  91.   \return      \ref execution_status
  92. */
  93. static int32_t Initialize (ARM_ETH_PHY_Read_t fn_read, ARM_ETH_PHY_Write_t fn_write) {
  94.   if ((fn_read == NULL) || (fn_write == NULL)) { return ARM_DRIVER_ERROR_PARAMETER; }
  95.   if ((PHY.flags & PHY_INIT) == 0U) {
  96.     /* Register PHY read/write functions. */
  97.     PHY.reg_rd = fn_read;
  98.     PHY.reg_wr = fn_write;
  99.     PHY.bmcr   = 0U;
  100.     PHY.flags  = PHY_INIT;
  101.   }
  102.   return ARM_DRIVER_OK;
  103. }
  104. /**
  105.   \fn          int32_t Uninitialize (void)
  106.   \brief       De-initialize Ethernet PHY Device.
  107.   \return      \ref execution_status
  108. */
  109. static int32_t Uninitialize (void) {
  110.   PHY.reg_rd = NULL;
  111.   PHY.reg_wr = NULL;
  112.   PHY.bmcr   = 0U;
  113.   PHY.flags  = 0U;
  114.   return ARM_DRIVER_OK;
  115. }
  116. /**
  117.   \fn          int32_t PowerControl (ARM_POWER_STATE state)
  118.   \brief       Control Ethernet PHY Device Power.
  119.   \param[in]   state  Power state
  120.   \return      \ref execution_status
  121. */
  122. static int32_t PowerControl (ARM_POWER_STATE state) {
  123.   uint16_t val;
  124.   switch ((int32_t)state) {
  125.     case ARM_POWER_OFF:
  126.       if ((PHY.flags & PHY_INIT) == 0U) {
  127.         /* Initialize must provide register access function pointers */
  128.         return ARM_DRIVER_ERROR;
  129.       }
  130.       PHY.flags &= ~PHY_POWER;
  131.       PHY.bmcr   =  BMCR_POWER_DOWN;
  132.       return (PHY.reg_wr(ETH_PHY_ADDR, REG_BMCR, PHY.bmcr));
  133.     case ARM_POWER_FULL:
  134.       if ((PHY.flags & PHY_INIT) == 0U) {
  135.         return ARM_DRIVER_ERROR;
  136.       }
  137.       if (PHY.flags & PHY_POWER) {
  138.         return ARM_DRIVER_OK;
  139.       }
  140.       /* Check Device Identification. */
  141.       PHY.reg_rd(ETH_PHY_ADDR, REG_PHYIDR1, &val);
  142.       if (val != PHY_ID1) {
  143.         /* Invalid PHY ID */
  144.         return ARM_DRIVER_ERROR_UNSUPPORTED;
  145.       }
  146.       PHY.reg_rd(ETH_PHY_ADDR, REG_PHYIDR2, &val);
  147.       if ((val & 0xFF00) != PHY_ID2) {
  148.         /* Invalid PHY ID */
  149.         return ARM_DRIVER_ERROR_UNSUPPORTED;
  150.       }
  151.       #if (ETH_PHY_REF_CLK_50M != 0)
  152.         /* PHY clock input XI is 50MHz */
  153.         PHY.reg_rd(ETH_PHY_ADDR, REG_PHYCR2, &val);
  154.         /* Set RMII Reference Clock Select bit */
  155.         val |= PHYCR2_REF_CLK_SELECT;
  156.         PHY.reg_wr(ETH_PHY_ADDR, REG_PHYCR2, val);
  157.       #endif
  158.       PHY.bmcr = 0U;
  159.       if (PHY.reg_wr(ETH_PHY_ADDR, REG_BMCR, PHY.bmcr) != ARM_DRIVER_OK) {
  160.         return ARM_DRIVER_ERROR;
  161.       }
  162.       PHY.flags |=  PHY_POWER;
  163.       return ARM_DRIVER_OK;
  164.     case ARM_POWER_LOW:
  165.     default:
  166.       return ARM_DRIVER_ERROR_UNSUPPORTED;
  167.   }
  168. }
  169. /**
  170.   \fn          int32_t SetInterface (uint32_t interface)
  171.   \brief       Set Ethernet Media Interface.
  172.   \param[in]   interface  Media Interface type
  173.   \return      \ref execution_status
  174. */
  175. static int32_t SetInterface (uint32_t interface) {
  176.   int32_t status;
  177.   if ((PHY.flags & PHY_POWER) == 0U) { return ARM_DRIVER_ERROR; }
  178.   /* This device only supports RMII interface */
  179.   switch (interface) {
  180.     case ARM_ETH_INTERFACE_RMII: status = ARM_DRIVER_OK; break;
  181.     default:
  182.       status = ARM_DRIVER_ERROR_UNSUPPORTED; break;
  183.   }
  184.   return (status);
  185. }
  186. /**
  187.   \fn          int32_t SetMode (uint32_t mode)
  188.   \brief       Set Ethernet PHY Device Operation mode.
  189.   \param[in]   mode  Operation Mode
  190.   \return      \ref execution_status
  191. */
  192. static int32_t SetMode (uint32_t mode) {
  193.   uint16_t val;
  194.   if ((PHY.flags & PHY_POWER) == 0U) { return ARM_DRIVER_ERROR; }
  195.   val = PHY.bmcr & BMCR_POWER_DOWN;
  196.   switch (mode & ARM_ETH_PHY_SPEED_Msk) {
  197.     case ARM_ETH_PHY_SPEED_10M:
  198.       break;
  199.     case ARM_ETH_PHY_SPEED_100M:
  200.       val |= BMCR_SPEED_SELECT;
  201.       break;
  202.     default:
  203.       return ARM_DRIVER_ERROR_UNSUPPORTED;
  204.   }
  205.   switch (mode & ARM_ETH_PHY_DUPLEX_Msk) {
  206.     case ARM_ETH_PHY_DUPLEX_HALF:
  207.       break;
  208.     case ARM_ETH_PHY_DUPLEX_FULL:
  209.       val |= BMCR_DUPLEX_MODE;
  210.       break;
  211.     default:
  212.       return ARM_DRIVER_ERROR_UNSUPPORTED;
  213.   }
  214.   if (mode & ARM_ETH_PHY_AUTO_NEGOTIATE) {
  215.     val |= BMCR_ANEG_EN;
  216.   }
  217.   if (mode & ARM_ETH_PHY_LOOPBACK) {
  218.     val |= BMCR_LOOPBACK;
  219.   }
  220.   if (mode & ARM_ETH_PHY_ISOLATE) {
  221.     val |= BMCR_ISOLATE;
  222.   }
  223.   PHY.bmcr = val;
  224.   return (PHY.reg_wr(ETH_PHY_ADDR, REG_BMCR, PHY.bmcr));
  225. }
  226. /**
  227.   \fn          ARM_ETH_LINK_STATE GetLinkState (void)
  228.   \brief       Get Ethernet PHY Device Link state.
  229.   \return      current link status \ref ARM_ETH_LINK_STATE
  230. */
  231. static ARM_ETH_LINK_STATE GetLinkState (void) {
  232.   ARM_ETH_LINK_STATE state;
  233.   uint16_t           val = 0U;
  234.   if (PHY.flags & PHY_POWER) {
  235.     PHY.reg_rd(ETH_PHY_ADDR, REG_BMSR, &val);
  236.   }
  237.   state = (val & BMSR_LINK_STAT) ? ARM_ETH_LINK_UP : ARM_ETH_LINK_DOWN;
  238.   return (state);
  239. }
  240. /**
  241.   \fn          ARM_ETH_LINK_INFO GetLinkInfo (void)
  242.   \brief       Get Ethernet PHY Device Link information.
  243.   \return      current link parameters \ref ARM_ETH_LINK_INFO
  244. */
  245. static ARM_ETH_LINK_INFO GetLinkInfo (void) {
  246.   ARM_ETH_LINK_INFO info;
  247.   uint16_t          val = 0U;
  248.   if (PHY.flags & PHY_POWER) {
  249.     /* Get operation mode indication from PHY DSCSR register */
  250.     PHY.reg_rd(ETH_PHY_ADDR, REG_DSCSR, &val);
  251.   }
  252.   /* Link must be up to get valid state */
  253.   info.speed  = ((val & DSCSR_100M_FD)|(val & DSCSR_100M_HD)) ? ARM_ETH_SPEED_100M  : ARM_ETH_SPEED_10M;
  254.   info.duplex = ((val & DSCSR_100M_FD)|(val & DSCSR_10M_FD)) ? ARM_ETH_DUPLEX_FULL : ARM_ETH_DUPLEX_HALF;
  255.   return (info);
  256. }
  257. /* PHY Driver Control Block */
  258. extern
  259. ARM_DRIVER_ETH_PHY ARM_Driver_ETH_PHY_(ETH_PHY_NUM);
  260. ARM_DRIVER_ETH_PHY ARM_Driver_ETH_PHY_(ETH_PHY_NUM) = {
  261.   GetVersion,
  262.   Initialize,
  263.   Uninitialize,
  264.   PowerControl,
  265.   SetInterface,
  266.   SetMode,
  267.   GetLinkState,
  268.   GetLinkInfo
  269. };
参与人数 1金币 +20 收起 理由
missfox + 20 赞一个!
 楼主| 发表于 2019-8-14 01:21:05 | 显示全部楼层
V7后面的新版RL-TCPnet V7.X教程和LwiIP将采用这个驱动。
发表于 2019-8-14 10:02:45 | 显示全部楼层
终于发了,只等完整模板了
代码不规范,亲人两行泪!
发表于 2019-8-14 10:02:57 | 显示全部楼层
硬汉辛苦了,注意休息
发表于 2019-8-14 21:07:29 | 显示全部楼层
V7的RL-TCPnet V7.X何时发布工程?
 楼主| 发表于 2019-8-15 01:15:28 | 显示全部楼层
快了,最近开始规范化一下模板例子
GMT+8, 2024-5-16 02:19 , Processed in 0.302119 second(s), 32 queries .
