查看: 1860|回复: 1
[其它] PicoTCP 一个免费开源的TCP/IP协议栈
发表于 2019-9-20 17:19:24 | 显示全部楼层 |阅读模式
https://gitlab.com/insane-adding-machines/picotcp
准备玩一玩
picoTCP
Welcome to the one and only picoTCP repository.
picoTCP is a small-footprint, modular TCP/IP stack designed for embedded systems and the Internet of Things. It's actively being developed by Altran Intelligent Systems.
This code is released under the terms of GNU GPL v2 and GNU GPL v3. Some rights reserved. Other licenses may apply at the sole discretion of the copyright holders.
Learn how to use picoTCP in your project by going through the Getting Started guide on our GitHub wiki.
For more information send us an email or contact us on Twitter, Facebook or Reddit.
Wondering about picoTCP's code quality? Check our TiCS score
Continuous integration
Functional tests: - Unit tests : - RFC compliance : - TICS quality : Coverity Scan Build status:
It runs on (pretty much) everything
By keeping interfaces simple, the porting effort to new platforms and OSses are very low. To give you an indication: porting to a new platform can be done in 3 days or less, a new OS in a single day and if you really go crazy, you can do an initial port in a single evening. Different platforms, mean different compilers, that’s why we continuously compile our stack with a bunch of them. The following list shows some of the currently supported platforms, device drivers and compilers.
PicoTCP has been used with
Platforms picoTCP runs on: ARM Cortex-M series (ST Micro STM, NXP LPC, TI Stellaris, Freescale K64F), ARM ARM9-series (ST Micro STR9), Texas Instruments (MSP430), Microchip (PIC24, PIC32), Atmel (AVR 8bit), Linux (User space (TUN/TAP), Kernel space), Windows (User space (TAP))
Network devices picoTCP has worked with: BCM43362 (IEEE 802.11), MRF24WG (IEEE 802.11), LPC Ethernet ENET/EMAC (IEEE 802.3), Stellaris Ethernet (IEEE 802.3), STM32 Ethernet (IEEE 802.3), Wiznet W5100 (IEEE 802.3), USB CDC-ECM (CDC1.2), PPP, Virtual drivers ( TUN/TAP, VDE, Libpcap)
(RT)OSes picoTCP has been integrated into: No OS / Bare metal, FreeRTOS, mbed-RTOS, Frosted, linux / POSIX, MS DOS, MS Windows
Libraries picoTCP has been integrated with: wolfSSL, mbedTLS, Mongoose RESTful library, MicroPython
Compilers picoTCP compiles under: GCC, Clang, TCC, ARM-RCVT, IAR, XC-16, XC-32, MSP-GCC, AVR-GCC
Unfortunately we can't release all the code, a.o. because some parts depend on code or binaries that aren't GPL compatible, some parts were developed under a commercial contract, and some consist of very rough proof-of-concept code. If you want to know more about the availability under the commercial license, or the possibility of using our expert services for porting or driver development, feel free to contact us at picotcp@altran.com.
Your favorite not in the list? Check out the wiki for information and examples on how to port picoTCP to a new platform!
参与人数 1金币 +50 收起 理由
eric2013 + 50 赞一个!
发表于 2019-9-20 19:00:52 | 显示全部楼层
谢谢楼主分享
GMT+8, 2024-5-30 05:43 , Processed in 0.157233 second(s), 29 queries .
