楼主: eric2013
[ThreadX全家桶] ThreadX全家桶源码和文档下载,含GUIX,Filex,NetX,USBX,GUIX Studio,TraceX等,全部升级至V6.4.0(2024-01-03)
 楼主| 发表于 2020-7-25 11:26:07 | 显示全部楼层
更新完毕,所有资料都已经更新到最新版。
发表于 2020-7-25 11:49:17 | 显示全部楼层
谢谢分享!!
发表于 2020-7-25 12:28:08 | 显示全部楼层
ThreadX模块使RTOS可以动态加载和运行除与内核链接的线程以外的其他应用程序线程。 应用程序获得了增加的功能,而无需增加占用空间或增加内存的成本,同时又保留了有效的服务调用接口。 该技术还为部署的系统提供按需重新配置和更新。 ThreadX模块技术非常适合应用程序代码大小超出可用内存,部署产品后需要添加新模块或需要部分固件更新的情况。
下载单独的应用程序模块的另一个优点是,每个模块都可以由其自己的团队或单个程序员更容易地开发。 然后,每个团队都可以专注于产品功能的一个方面,而不必关心其他细节。
这个模块的方式,我们有示例示范如何使用吗?硬汉大哥用过这个功能吗?
 楼主| 发表于 2020-7-25 14:47:26 | 显示全部楼层
morning_enr6U 发表于 2020-7-25 12:28
ThreadX模块使RTOS可以动态加载和运行除与内核链接的线程以外的其他应用程序线程。 应用程序获得了增加的功 ...
还没研究过。
发表于 2020-7-26 12:18:34 | 显示全部楼层
贴一下ThreadX的升级日志,看样子快要推出官方IAR、VS2019等编译器的port了
This is an updated release of Azure RTOS that includes multiple bug fixes, as well as adding a number of additional MCU architecture and developer IDE options.
Azure RTOS ThreadX 6.0.1 release contains the following changes:
ports/cortex_m0/gnu/tx_thread_stack_build.S r10 is no longer set to the top of the thread stack and comment references to stack limit (sl) have been removed.
ports/cortex_m3/gnu/tx_thread_stack_build.S r10 is no longer set to the top of the thread stack and comment references to stack limit (sl) have been removed.
ports/cortex_m4/gnu/tx_thread_stack_build.S r10 is no longer set to the top of the thread stack and comment references to stack limit (sl) have been removed.
ports/cortex_m7/gnu/tx_thread_stack_build.S r10 is no longer set to the top of the thread stack and comment references to stack limit (sl) have been removed.
common/inc/tx_api.h update product constants.
Azure RTOS ThreadX 6.0.1 release contains the following additional processor ports and toolchains:
arc_em: metaware
arc_hs: metaware
arm9: ac5, gnu, iar
c667x: ccs
cortex_a15: gnu
cortex_a5: ac5, gnu, iar
cortex_a5x: ac6
cortex_a7: ac5, gnu, iar
cortex_a8: ac5, gnu, iar
cortex_a9: ac5, gnu, iar
cortex_m0: ac5, gnu, iar
cortex_m3: ac5, gnu, iar, keil
cortex_m4: ac5, gnu, iar, keil
cortex_m7: ac5, gnu, iar
cortex_r4: ac5, ac6, gnu, iar
cortex_r5: ac5, gnu, iar
linux: gnu
win32: vs_2019
 楼主| 发表于 2020-7-26 14:19:41 | 显示全部楼层
This is an updated release o ...
我一直在找他们的release note,不知道能不能找到早期的版本更新记录。
 楼主| 发表于 2020-8-8 15:00:20 | 显示全部楼层
更新下ThreadX内核到6.0.1。
这个6.0.1和之前的不同,是官方直接覆盖了之前的设计。
 楼主| 发表于 2020-8-16 13:26:28 | 显示全部楼层
更新ThreadX NetDuo和GUIX
发表于 2020-8-16 16:10:28 | 显示全部楼层
下载了Azure_RTOS_ThreadX_User_Guide,6.0版本,其他文档都没有更新吧?
发表于 2020-8-16 16:38:00 | 显示全部楼层
azure_rtos_guix_studio_setup_version_6.0.2.0_Aug_12_2020.exe 这个下不下来。中途会断。
 楼主| 发表于 2020-8-16 17:02:35 | 显示全部楼层
复制链接到迅雷下载靠谱。
发表于 2020-9-16 21:45:51 | 显示全部楼层
棒棒棒,资料下载飞快
 楼主| 发表于 2020-10-2 09:19:28 | 显示全部楼层
更新ThreadX内核到V6.1,更新TraceX到6.1
 楼主| 发表于 2020-10-11 01:00:44 | 显示全部楼层
升级各种中间件版本到6.1.0
 楼主| 发表于 2020-10-13 09:44:18 | 显示全部楼层
更新GUIX Studio到6.1.0
发表于 2020-10-13 16:25:10 | 显示全部楼层
你好,可否出一期切换窗口的自定义呢?因为我目前在做智能手表的开发,很多时候需要自定义事件触发窗口的切换,目前看配置上切换窗口比较繁琐,所以希望贵公司能否出一期自定义切换窗口呢?
 楼主| 发表于 2020-10-14 02:33:11 | 显示全部楼层
1278854021@qq.c 发表于 2020-10-13 16:25
你好,可否出一期切换窗口的自定义呢?因为我目前在做智能手表的开发,很多时候需要自定义事件触发窗口的切 ...
好的,后面做一期。
发表于 2020-10-14 09:11:41 | 显示全部楼层
eric2013 发表于 2020-10-14 02:33
好的,后面做一期。
谢谢,目前感觉就我们家做guix studio最全的
发表于 2020-10-14 09:12:20 | 显示全部楼层
好的,后面做一期。
谢谢,目前感觉就我们家做guix studio最全的,哈哈
 楼主| 发表于 2020-10-20 02:15:11 | 显示全部楼层
升级ThreadX到6.1.1
 楼主| 发表于 2020-10-27 11:38:31 | 显示全部楼层
由于GUIX  Studio V6.1.0不支持了Win7,所以将支持Win7的最后一个版本V6.1.0添加上。
 楼主| 发表于 2020-11-11 14:02:27 | 显示全部楼层
升级ThreadX内核到6.1.2
 楼主| 发表于 2020-11-12 03:38:33 | 显示全部楼层
更新FileX,NetX和LevelX
 楼主| 发表于 2020-11-15 01:46:11 | 显示全部楼层
升级NetXDUO到V6.1.2
发表于 2020-11-21 16:52:04 | 显示全部楼层
收藏一下, 每次都找不到了
发表于 2020-12-21 20:15:27 | 显示全部楼层
你好,请教下,有什么方法可以吧 threadx 全家桶里面的相关源码 自己 制作成 库 的形式啊 ?
最好是 mdk,iar 都可以共用的,当然,如果不能够同时兼容的话,单个的也行,
 楼主| 发表于 2020-12-22 10:42:37 | 显示全部楼层
最好是 mdk ...
参考这个
【更新完毕】授人以渔,ThreadX GUIX的GCC,MDK和IAR库文件生成方法及其模板文件
http://www.armbbs.cn/forum.php?m ... 8823&fromuid=58
发表于 2020-12-22 10:58:05 | 显示全部楼层
eric2013 发表于 2020-12-22 10:42
参考这个
 楼主| 发表于 2021-1-10 09:32:40 | 显示全部楼层
更新ThreadX全家桶所有软件包。
发表于 2021-1-11 13:01:06 | 显示全部楼层
新学员   非常感谢老师的分享   学习一下  慢慢理解吧
发表于 2021-1-22 06:21:57 | 显示全部楼层
I'm just starting to use ThreadX and its components. Meanwhile, I bought a complete v7 board with h737XI core (https://www.aliexpress.com/item/ ... .0.0.799f7bd4imaBKI, order 8123709609098273). I just receive the board (OK) with a lot of information that seller provided. Nevertheless, the seller cannot provided the electrical schemes. Can anyone help me in this thing? Thanks
 楼主| 发表于 2021-1-22 09:24:48 | 显示全部楼层
LuizPereira 发表于 2021-1-22 06:21
I'm just starting to use ThreadX and its components. Meanwhile, I bought a complete v7 board with h7 ...
give me your email ,
发表于 2021-1-22 22:00:38 | 显示全部楼层
If you can help me, thanks. My e-mail is: luiz@ua.pt
Regards
 楼主| 发表于 2021-1-24 08:43:51 | 显示全部楼层
Regards
Already sent to you,
发表于 2021-1-25 00:48:17 | 显示全部楼层
Yeas, I received. Perfect. Now, everything is complete. Thank you very much. I hope help the colleagues in this wonderful form.   Regards
发表于 2021-2-3 23:14:01 | 显示全部楼层
楼主你太伟大了,小弟俺刚做完rt-thread项目,年底总结要计划来年,正准备开始threadX,搜到你的页面,那个高兴啊
 楼主| 发表于 2021-2-5 09:08:52 | 显示全部楼层
升级部分中间件到V6.1.4。
发表于 2021-2-5 13:09:58 | 显示全部楼层
eric2013 发表于 2021-2-5 09:08
升级部分中间件到V6.1.4。
6.1.4更新完毕。 ThreadX, LevelX, FileX 没有改动,所以这次没有release.
 楼主| 发表于 2021-3-6 09:13:24 | 显示全部楼层
更新ThreadX全家桶到V6.1.5
发表于 2021-3-10 16:22:29 | 显示全部楼层
汉哥,有GUIX Studio直接可以打开的工程例程吗?
GMT+8, 2024-5-3 10:15 , Processed in 0.420023 second(s), 24 queries .
