发表于 2019-3-16 23:43:29
显示全部楼层
创建的时候设置8字节对齐解决不了根本问题,根本问题是移植文件里面得做8字节对齐,这里设置后,即使任务栈不是对齐也没关系,因为移植这里修改为对齐了。
p_stk = (CPU_STK *)((CPU_STK)(p_stk) & 0xFFFFFFF8); 这句话是关键
- * INITIALIZE A TASK'S STACK
- * Description: This function is called by OS_Task_Create() or OSTaskCreateExt() to initialize the stack
- * frame of the task being created. This function is highly processor specific.
- * Arguments : p_task Pointer to the task entry point address.
- * p_arg Pointer to a user supplied data area that will be passed to the task
- * when the task first executes.
- * p_stk_base Pointer to the base address of the stack.
- * stk_size Size of the stack, in number of CPU_STK elements.
- * opt Options used to alter the behavior of OS_Task_StkInit().
- * (see OS.H for OS_TASK_OPT_xxx).
- * Returns : Always returns the location of the new top-of-stack' once the processor registers have
- * been placed on the stack in the proper order.
- * Note(s) : 1) Interrupts are enabled when task starts executing.
- * 2) All tasks run in Thread mode, using process stack.
- CPU_STK *OSTaskStkInit (OS_TASK_PTR p_task,
- void *p_arg,
- CPU_STK *p_stk_base,
- CPU_STK *p_stk_limit,
- CPU_STK_SIZE stk_size,
- OS_OPT opt)
- CPU_STK *p_stk;
- (void)opt; /* Prevent compiler warning */
- p_stk = &p_stk_base[stk_size]; /* Load stack pointer */
- /* Align the stack to 8-bytes. */
- p_stk = (CPU_STK *)((CPU_STK)(p_stk) & 0xFFFFFFF8);
- /* Registers stacked as if auto-saved on exception */
- *--p_stk = (CPU_STK)0x01000000u; /* xPSR */
- *--p_stk = (CPU_STK)p_task; /* Entry Point */
- *--p_stk = (CPU_STK)OS_TaskReturn; /* R14 (LR) */
- *--p_stk = (CPU_STK)0x12121212u; /* R12 */
- *--p_stk = (CPU_STK)0x03030303u; /* R3 */
- *--p_stk = (CPU_STK)0x02020202u; /* R2 */
- *--p_stk = (CPU_STK)p_stk_limit; /* R1 */
- *--p_stk = (CPU_STK)p_arg; /* R0 : argument */
- /* Remaining registers saved on process stack */
- *--p_stk = (CPU_STK)0x11111111u; /* R11 */
- *--p_stk = (CPU_STK)0x10101010u; /* R10 */
- *--p_stk = (CPU_STK)0x09090909u; /* R9 */
- *--p_stk = (CPU_STK)0x08080808u; /* R8 */
- *--p_stk = (CPU_STK)0x07070707u; /* R7 */
- *--p_stk = (CPU_STK)0x06060606u; /* R6 */
- *--p_stk = (CPU_STK)0x05050505u; /* R5 */
- *--p_stk = (CPU_STK)0x04040404u; /* R4 */
- return (p_stk);
