查看: 2518|回复: 2
[服务器设置] 2023-03-04转移图片到国内服务器,DZ论坛批量替换帖子中的链接
发表于 2022-1-13 08:45:48 | 显示全部楼层 |阅读模式
在DZ后台数据库中执行语句:
UPDATE pre_forum_post SET message=REPLACE(message,'需要替换的内容','替换后的内容');
UPDATE pre_forum_post SET message=REPLACE(message,'https://img.anfulai.cn/bbs','https://img.anfulai.cn/bbs');
需要后台开启, 站长,数据库,升级
如果您想自己随意书写 SQL 升级语句,需要将 config/config_global.php 当中的 $_config[admincp][runquery] 设置修改为 1。
 楼主| 发表于 2023-3-4 10:47:19 | 显示全部楼层
2023-03-04
转移按图片到国内服务器
UPDATE pre_forum_post SET message=REPLACE(message,'https://img.anfulai.cn/dz/attachment/forum','https://img.anfulai.cn/dz/attachment/forum');
支持远程附件的后缀:
jpg
png
zip
7z
bmp
pdf
rar
txt
lua
c
h
exe
flm
pack
jpeg
gif
2将本地附件目录data/attachment里面的文件夹移动到远程服务器上
3数据库执行sql语句
论坛的(0表示本地,1表示远程,)
update pre_forum_attachment_0 set remote=1 where remote=0;
update pre_forum_attachment_1 set remote=1 where remote=0;
update pre_forum_attachment_2 set remote=1 where remote=0;
update pre_forum_attachment_3 set remote=1 where remote=0;
update pre_forum_attachment_4 set remote=1 where remote=0;
update pre_forum_attachment_5 set remote=1 where remote=0;
update pre_forum_attachment_6 set remote=1 where remote=0;
update pre_forum_attachment_7 set remote=1 where remote=0;
update pre_forum_attachment_8 set remote=1 where remote=0;
update pre_forum_attachment_9 set remote=1 where remote=0;
门户的
update pre_portal_article_title set remote=1 where remote=0;
update pre_portal_attachment set remote=1 where remote=0;
update pre_portal_topic_pic set remote=1 where remote=0;
相册的{相册表中的remote取值还有一种情况为remote=2(论坛附件图片保存到相册
update pre_home_pic set remote=remote+1;
 楼主| 发表于 2023-3-9 10:48:56 | 显示全部楼层
2023-03-09
UPDATE pre_forum_post SET message=REPLACE(message,'http://www.armbbs.cn/data','https://img.anfulai.cn/dz');
UPDATE pre_forum_post SET message=REPLACE(message,'https://img.anfulai.cn/armbbs','https://img.anfulai.cn/dz');
GMT+8, 2024-5-19 11:48 , Processed in 0.155885 second(s), 27 queries .
