查看: 1034|回复: 0
WIN11 注册表关于KEIL安装路径
发表于 2022-11-27 02:01:27 | 显示全部楼层 |阅读模式
Windows11系统:
        计算机\HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Keil\Products\MDK
                Path = C:\Keil_v5\ARM
CB10以后注册表的操作方式有所变化。
void __fastcall TForm2::InsertToRegBtnClick(TObject *Sender)
	TRegistry* reg = new TRegistry(KEY_READ);
	reg->RootKey = HKEY_LOCAL_MACHINE;
	if(!reg->KeyExists("Software\\MyCompanyName\\MyApplication\\"))
		MessageDlg("Key not found! Created now.",
					mtInformation, TMsgDlgButtons() << mbOK, 0);
	reg->Access = KEY_WRITE;
	bool openResult = reg->OpenKey("Software\\MyCompanyName\\MyApplication\\", true);
	if(!openResult)
		MessageDlg("Unable to create key! Exiting.",
					mtError, TMsgDlgButtons() << mbOK, 0);
		return;
	//Checking if the values exist and inserting when neccesary
	if(!reg->KeyExists("Creation\ Date"))
		TDateTime today = TDateTime::CurrentDateTime();
		reg->WriteDateTime("Creation\ Date", today);
	if(!reg->KeyExists("Licenced\ To"))
		reg->WriteString("Licenced\ To", "MySurname\ MyFirstName");
	if(!reg->KeyExists("App\ Location"))
		reg->WriteExpandString("App\ Location",
								"%PROGRAMFILES%\\MyCompanyName\\MyApplication\\");
	if(!reg->KeyExists("Projects\ Location"))
		reg->WriteExpandString("Projects\ Location",
								"%USERPROFILE%\\MyApplication\\Projects\\");
	reg->CloseKey();
	reg->Free();
void __fastcall TForm2::DelFromRegBtnClick(TObject *Sender)
	//Deleting the example registry entries
	TRegistry* reg = new TRegistry(KEY_WRITE);
	reg->DeleteKey("Software\\MyCompanyName\\MyApplication");
	reg->DeleteKey("Software\\MyCompanyName");
	reg->CloseKey();
	reg->Free();
GMT+8, 2024-5-14 12:13 , Processed in 0.229867 second(s), 24 queries .
