查看: 22286|回复: 6
[OLED] 【安富莱】0.96寸和1.3寸OLED显示模块(128x64)资料
发表于 2012-6-27 13:01:58 | 显示全部楼层 |阅读模式
安富莱0.96寸OLED模块采用的OLED屏为 悠景科技的。
0.96寸128x64 ,30P引脚,有3种颜色:白色、蓝色、双色(黄蓝分区,第1行黄色,下面3行蓝色)
SSD1306-Revision 1.1 (Charge Pump).pdf (1.79 MB, 下载次数: 2216)
悠景科技 UG-2864HLBEG01-Specification (30P 蓝色).pdf (1.64 MB, 下载次数: 2148)
悠景科技 UG-2864HMBEG01 Specification (30P 双色).pdf (1.13 MB, 下载次数: 1229)
悠景科技 UG-2864HSWEG01 Specification (30P 白色).pdf (820 KB, 下载次数: 1102)
悠景科技 UG-2864HSWEG01 Evaluation Kit User Guide.pdf (509 KB, 下载次数: 1029)
1.3寸OLED和0.96寸引脚一样,软件完全兼容。
UG-2864HSWEG01 user guide.pdf (537 KB, 下载次数: 2471)
UG-2864KSWLG01-drawing.pdf (132 KB, 下载次数: 993)
初始化代码:
void initial_ic(void);
void reset_ssd1306(void);
void write_c(unsigned char out_command);
void write_d(unsigned char out_data);
E_RD=1;
D_C=0;
R_W=0;
CS=0;
reset_ssd1306();
write_c(0xae);//display off
  write_c(0x81);//set contrast
  write_c(0x8f);
  write_c(0xa4);//Normal Mode
  write_c(0xa6);//No Inverse
  write_c(0xa8);//set multiplex ratio
    write_c(0x3f);
    write_c(0xa1);//set segment re-map
    write_c(0xd3);//display offset
    write_c(0x00);
write_c(0xc8);//Set COM Output Scan Direction
    write_c(0xda);//Com Pins Hardware
    write_c(0x12);
    write_c(0xd5);//Set display clock divide ratio
    write_c(0x80);
write_c(0xd9);//(set pre-charge period)
    write_c(0x22);
write_c(0xdb);//Set VcomH
    write_c(0x40);
write_c(0x40);//Start line
write_c(0x8d);//charge pump
write_c(0x14);//enable*((disable 0x10))
// delay_1ms(200);
write_c(0xaf);//display on
RES=0;
delay_1ms(100);
RES=1;
D_C=0;
CS=0;
E_RD=1;
R_W=0;
d_bus=out_command;
R_W=1;
CS=1;
D_C=1;
D_C=1;
CS=0;
E_RD=1;
R_W=0;
d_bus=out_data;
R_W=1;
CS=1;
E_RD=1;
发表于 2013-7-26 09:56:11 | 显示全部楼层
谢谢了
发表于 2016-11-14 21:29:42 | 显示全部楼层
您遇到过OLED屏幕花屏的问题吗?
当我用SPI模式的时候,使用ST的spi, 会出现屏幕偶尔花屏的问题。
GMT+8, 2025-7-5 00:23 , Processed in 0.263578 second(s), 26 queries .
