STM32F4 C++ 封装库 之 EXTI
这几天看了下 mbed 的源码,给上层应用调用的接口封装的还是不错的。代码质量比较高,注释也很详细,文档和例程比较全。但是驱动层的程序全是 C 语言编写的,代码质量就没有那么高了,注释比较少而且不规范,比较怀疑 mbed 的稳定性。mbed 的实时内核是用的 RTX5 ,文件系统用的 FatFs ,还有一些开源的协议栈,整套系统比较繁杂。mbed 框架是为物联网设备开发的,工业控制级别的产品可以考虑用 RTE 框架。RTE 框架目前驱动层程序还不太完善,有好多需要自己去实现,可能在过一段时间会好一些吧。总之物联网产品可以用 mbed ,工业控制产品可以用 RTE 。这几天封装了 EXTI ,距离整套系统可以产生生产力还有很长的距离要走,我也不知道整个系统会成什么样子,我能坚持多久,不管了先做再说。在这里分享我的 STM32F4 C++ 封装之旅。今天分享《STM32F4 C++ 封装库 之 EXTI》,直接上代码了~
stm32f4xx_xexti.h 文件
- * \file stm32f4xx_xexti.h
- * \author XinLi
- * \version v1.0
- * \date 20-March-2018
- * \brief Header file for external interrupt/event controller module.
- * \attention
- * <h2><center>Copyright © 2018 XinLi</center></h2>
- * This program is free software: you can redistribute it and/or modify
- * it under the terms of the GNU General Public License as published by
- * the Free Software Foundation, either version 3 of the License, or
- * (at your option) any later version.
- * This program is distributed in the hope that it will be useful,
- * but WITHOUT ANY WARRANTY; without even the implied warranty of
- * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
- * GNU General Public License for more details.
- * You should have received a copy of the GNU General Public License
- * along with this program. If not, see <https://www.gnu.org/licenses/>.
- #ifndef STM32F4XX_XEXTI_H
- #define STM32F4XX_XEXTI_H
- #include "stm32f4xx_ll_exti.h"
- /*! External interrupt/event controller module. */
- class XExti
- public:
- /*! Enumerate of EXTI lines. */
- enum ExtiLine
- Line0 = LL_EXTI_LINE_0, /*!< EXTI line 0. */
- Line1 = LL_EXTI_LINE_1, /*!< EXTI line 1. */
- Line2 = LL_EXTI_LINE_2, /*!< EXTI line 2. */
- Line3 = LL_EXTI_LINE_3, /*!< EXTI line 3. */
- Line4 = LL_EXTI_LINE_4, /*!< EXTI line 4. */
- Line5 = LL_EXTI_LINE_5, /*!< EXTI line 5. */
- Line6 = LL_EXTI_LINE_6, /*!< EXTI line 6. */
- Line7 = LL_EXTI_LINE_7, /*!< EXTI line 7. */
- Line8 = LL_EXTI_LINE_8, /*!< EXTI line 8. */
- Line9 = LL_EXTI_LINE_9, /*!< EXTI line 9. */
- Line10 = LL_EXTI_LINE_10, /*!< EXTI line 10. */
- Line11 = LL_EXTI_LINE_11, /*!< EXTI line 11. */
- Line12 = LL_EXTI_LINE_12, /*!< EXTI line 12. */
- Line13 = LL_EXTI_LINE_13, /*!< EXTI line 13. */
- Line14 = LL_EXTI_LINE_14, /*!< EXTI line 14. */
- Line15 = LL_EXTI_LINE_15, /*!< EXTI line 15. */
- #ifdef LL_EXTI_LINE_16
- Line16 = LL_EXTI_LINE_16, /*!< EXTI line 16. */
- #endif
- #ifdef LL_EXTI_LINE_17
- Line17 = LL_EXTI_LINE_17, /*!< EXTI line 17. */
- #endif
- #ifdef LL_EXTI_LINE_18
- Line18 = LL_EXTI_LINE_18, /*!< EXTI line 18. */
- #endif
- #ifdef LL_EXTI_LINE_19
- Line19 = LL_EXTI_LINE_19, /*!< EXTI line 19. */
- #endif
- #ifdef LL_EXTI_LINE_20
- Line20 = LL_EXTI_LINE_20, /*!< EXTI line 20. */
- #endif
- #ifdef LL_EXTI_LINE_21
- Line21 = LL_EXTI_LINE_21, /*!< EXTI line 21. */
- #endif
- #ifdef LL_EXTI_LINE_22
- Line22 = LL_EXTI_LINE_22, /*!< EXTI line 22. */
- #endif
- #ifdef LL_EXTI_LINE_23
- Line23 = LL_EXTI_LINE_23, /*!< EXTI line 23. */
- #endif
- #ifdef LL_EXTI_LINE_24
- Line24 = LL_EXTI_LINE_24, /*!< EXTI line 24. */
- #endif
- #ifdef LL_EXTI_LINE_25
- Line25 = LL_EXTI_LINE_25, /*!< EXTI line 25. */
- #endif
- #ifdef LL_EXTI_LINE_26
- Line26 = LL_EXTI_LINE_26, /*!< EXTI line 26. */
- #endif
- #ifdef LL_EXTI_LINE_27
- Line27 = LL_EXTI_LINE_27, /*!< EXTI line 27. */
- #endif
- #ifdef LL_EXTI_LINE_28
- Line28 = LL_EXTI_LINE_28, /*!< EXTI line 28. */
- #endif
- #ifdef LL_EXTI_LINE_29
- Line29 = LL_EXTI_LINE_29, /*!< EXTI line 29. */
- #endif
- #ifdef LL_EXTI_LINE_30
- Line30 = LL_EXTI_LINE_30, /*!< EXTI line 30. */
- #endif
- #ifdef LL_EXTI_LINE_31
- Line31 = LL_EXTI_LINE_31, /*!< EXTI line 31. */
- #endif
- /*! Enumerate of EXTI modes. */
- enum ExtiMode
- ModeInterrupt = LL_EXTI_MODE_IT, /*!< EXTI interrupt mode. */
- ModeEvent = LL_EXTI_MODE_EVENT, /*!< EXTI event mode. */
- ModeInterruptEvent = LL_EXTI_MODE_IT_EVENT, /*!< EXTI interrupt and event mode. */
- /*! Enumerate of EXTI triggers. */
- enum ExtiTrigger
- TriggerNone = LL_EXTI_TRIGGER_NONE, /*!< EXTI none trigger. */
- TriggerRising = LL_EXTI_TRIGGER_RISING, /*!< EXTI rising trigger. */
- TriggerFalling = LL_EXTI_TRIGGER_FALLING, /*!< EXTI falling trigger. */
- TriggerRisingFalling = LL_EXTI_TRIGGER_RISING_FALLING, /*!< EXTI rising and falling trigger. */
- XExti(ExtiLine line, ExtiMode mode, ExtiTrigger trigger = TriggerNone);
- virtual ~XExti();
- void setLine(ExtiLine line);
- ExtiLine getLine() const;
- void setMode(ExtiMode mode);
- ExtiMode getMode() const;
- void setTrigger(ExtiTrigger trigger);
- ExtiTrigger getTrigger() const;
- void setFlag();
- void clearFlag();
- bool isFlagSet() const;
- bool open();
- void close();
- bool isOpen() const;
- private:
- ExtiLine line;
- ExtiMode mode;
- ExtiTrigger trigger;
- bool openFlag;
- XExti(const XExti &) = delete;
- XExti & operator = (const XExti &) = delete;
- #endif // STM32F4XX_XEXTI_H
stm32f4xx_xexti.cpp 文件
例程
- * @file main.cpp
- * @author XinLi
- * @version v1.0
- * @date 20-March-2018
- * @brief Main program body.
- * @attention
- /* Header includes -----------------------------------------------------------*/
- #include "main.h"
- #include "stm32f4xx_xgpio.h"
- #include "stm32f4xx_xexti.h"
- /* Macro definitions ---------------------------------------------------------*/
- /* Type definitions ----------------------------------------------------------*/
- /* Variable declarations -----------------------------------------------------*/
- /* Variable definitions ------------------------------------------------------*/
- /* Function declarations -----------------------------------------------------*/
- static void SystemClock_Config(void);
- /* Function definitions ------------------------------------------------------*/
- * @brief Main program.
- * @param None.
- * @return None.
- int main(void)
- /* STM32F4xx HAL library initialization:
- - Configure the Flash prefetch, instruction and Data caches
- - Configure the Systick to generate an interrupt each 1 msec
- - Set NVIC Group Priority to 4
- - Global MSP (MCU Support Package) initialization
- HAL_Init();
- /* Configure the system clock to 168 MHz */
- SystemClock_Config();
- XExti exti4(XExti::Line4, XExti::ModeInterrupt);
- exti4.open();
- XGpio led0(XGpio::PortF, XGpio::Pin9, XGpio::ModeOutput);
- XGpio led1(XGpio::PortF, XGpio::Pin10, XGpio::ModeOutput);
- led0.open();
- led1.open();
- for(;;)
- if(exti4.isFlagSet() != true)
- exti4.setFlag();
- led0.setLevel(XGpio::LevelLow);
- led1.setLevel(XGpio::LevelHigh);
- else
- exti4.clearFlag();
- led0.setLevel(XGpio::LevelHigh);
- led1.setLevel(XGpio::LevelLow);
- HAL_Delay(250);
- * @brief System Clock Configuration
- * The system Clock is configured as follow :
- * System Clock source = PLL (HSE)
- * SYSCLK(Hz) = 168000000
- * HCLK(Hz) = 168000000
- * AHB Prescaler = 1
- * APB1 Prescaler = 4
- * APB2 Prescaler = 2
- * HSE Frequency(Hz) = 8000000
- * PLL_M = 8
- * PLL_N = 336
- * PLL_P = 2
- * PLL_Q = 7
- * VDD(V) = 3.3
- * Main regulator output voltage = Scale1 mode
- * Flash Latency(WS) = 5
- * @param None
- * @retval None
- RCC_ClkInitTypeDef RCC_ClkInitStruct;
- RCC_OscInitTypeDef RCC_OscInitStruct;
- /* Enable Power Control clock */
- __HAL_RCC_PWR_CLK_ENABLE();
- /* The voltage scaling allows optimizing the power consumption when the device is
- clocked below the maximum system frequency, to update the voltage scaling value
- regarding system frequency refer to product datasheet. */
- __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
- /* Enable HSE Oscillator and activate PLL with HSE as source */
- RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
- RCC_OscInitStruct.HSEState = RCC_HSE_ON;
- RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
- RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
- RCC_OscInitStruct.PLL.PLLM = 8;
- RCC_OscInitStruct.PLL.PLLN = 336;
- RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
- RCC_OscInitStruct.PLL.PLLQ = 7;
- HAL_RCC_OscConfig(&RCC_OscInitStruct);
- /* Select PLL as system clock source and configure the HCLK, PCLK1 and PCLK2
- clocks dividers */
- RCC_ClkInitStruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2);
- RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
- RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
- RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
- RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
- HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5);
- /* STM32F405x/407x/415x/417x Revision Z devices: prefetch is supported */
- if (HAL_GetREVID() == 0x1001)
- /* Enable the Flash prefetch */
- __HAL_FLASH_PREFETCH_BUFFER_ENABLE();
归档链接
STM32F4 C++ 封装库 之 GPIO
