查看: 3774|回复: 6
[FreeRTOS] prvIdleTask定义在哪
发表于 2018-12-15 13:59:30 | 显示全部楼层 |阅读模式
在看FreeRTOS, vTaskStartScheduler源码的时候有个疑问prvIdleTask这个任务定义到底在哪。
根据查找就说:portTASK_FUNCTION就是prvIdleTask。。怎么实现的啊,请指教一下
* The Idle task.
* The portTASK_FUNCTION() macro is used to allow port/compiler specific
* language extensions.  The equivalent prototype for this function is:
* void prvIdleTask( void *pvParameters );
static portTASK_FUNCTION( prvIdleTask, pvParameters )
        /* Stop warnings. */
        ( void ) pvParameters;
        /** THIS IS THE RTOS IDLE TASK - WHICH IS CREATED AUTOMATICALLY WHEN THE
        SCHEDULER IS STARTED. **/
        /* In case a task that has a secure context deletes itself, in which case
        the idle task is responsible for deleting the task's secure context, if
        any. */
        portTASK_CALLS_SECURE_FUNCTIONS();
        for( ;; )
                /* See if any tasks have deleted themselves - if so then the idle task
                is responsible for freeing the deleted task's TCB and stack. */
                prvCheckTasksWaitingTermination();
                #if ( configUSE_PREEMPTION == 0 )
vTaskStartScheduler
vTaskStartScheduler
 楼主| 发表于 2018-12-15 14:35:46 | 显示全部楼层
顶一下,怎么没人来看看呢
发表于 2018-12-15 14:48:28 | 显示全部楼层
/* Task function macros as described on the FreeRTOS.org WEB site.  These are
not necessary for to use this port.  They are defined so the common demo files
(which build with all the ports) will build. */
#define portTASK_FUNCTION_PROTO( vFunction, pvParameters ) void vFunction( void *pvParameters )
#define portTASK_FUNCTION( vFunction, pvParameters ) void vFunction( void *pvParameters )
 楼主| 发表于 2018-12-15 15:03:27 | 显示全部楼层
还是没看出来怎么联系起来 的
发表于 2018-12-15 15:12:31 | 显示全部楼层
bian 发表于 2018-12-15 15:03
还是没看出来怎么联系起来 的
你太菜了,这就是个简单的宏定义呀
 楼主| 发表于 2018-12-15 16:29:26 | 显示全部楼层
portTASK_FUNCTION   和  prvIdleTask 的联系啊
发表于 2022-8-23 11:21:47 | 显示全部楼层
宏定义:#define portTASK_FUNCTION( vFunction, pvParameters ) void vFunction( void *pvParameters )
宏定义应该会替换成:
static  void prvIdleTask( void *pvParameters )
GMT+8, 2024-5-18 08:24 , Processed in 0.171340 second(s), 27 queries .
