emwin文件
* SEGGER Microcontroller GmbH *
* Solutions for real time microcontroller applications *
* C-file generated by: *
* GUI_Builder for emWin version 6.16 *
* Compiled Nov 13 2020, 12:50:00 *
* (c) 2019 Segger Microcontroller GmbH *
* Internet: www.segger.com Support: support@segger.com *
// USER START (Optionally insert additional includes)
// USER END
#include "DIALOG.h"
#include "Menu_Icon.h"
#include "Win_Moitor.h"
* Defines
#define ID_WINDOW_0 (GUI_ID_USER + 0x00)
#define ID_GRAPH_0 (GUI_ID_USER + 0x01)
#define ID_IMAGE_0 (GUI_ID_USER + 0x02)
#define ID_ICONVIEW_0 (GUI_ID_USER + 0x03)
#define ID_TEXT_0 (GUI_ID_USER + 0x04)
#define ID_TEXT_1 (GUI_ID_USER + 0x05)
#define ID_ICONVIEW_1 (GUI_ID_USER + 0x06)
#define ID_TEXT_2 (GUI_ID_USER + 0x07)
#define ID_TEXT_3 (GUI_ID_USER + 0x08)
#define ID_TEXT_4 (GUI_ID_USER + 0x09)
#define ID_TEXT_5 (GUI_ID_USER + 0x0A)
#define ID_TEXT_6 (GUI_ID_USER + 0x0B)
#define ID_TEXT_7 (GUI_ID_USER + 0x0C)
#define ID_TEXT_8 (GUI_ID_USER + 0x0D)
#define ID_IMAGE_0_IMAGE_0 0x00
extern GUI_CONST_STORAGE GUI_BITMAP bmMenu_Icon;//主菜单图标
// USER START (Optionally insert additional defines)
// USER END
* Static data
* _acImage_0, "BMP", ID_IMAGE_0_IMAGE_0
static const U8 _acImage_0[463] = {
0x42, 0x4D, 0xCE, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3E, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x32, 0x00, 0x00, 0x00, 0x32, 0x00, 0x00, 0x00, 0x01, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x90, 0x01, 0x00, 0x00, 0x12, 0x0B, 0x00, 0x00,
0x12, 0x0B, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xC0, 0x00, 0xC2, 0x10, 0x84, 0x21, 0x08, 0x42, 0x40, 0x00, 0xA1, 0x08, 0x42, 0x10, 0x84, 0x21,
0x40, 0x00, 0x90, 0x84, 0x21, 0x08, 0x42, 0x10, 0xC0, 0x00, 0x88, 0x42, 0x10, 0x84, 0x21, 0x08, 0x40, 0x00, 0x84, 0x21, 0x08, 0x42, 0x10, 0x84, 0x40, 0x00, 0xC2, 0x10, 0x84, 0x21, 0x08, 0x42, 0x40, 0x00, 0xA1, 0x08, 0x42, 0x10, 0x84, 0x21, 0x40, 0x00,
0x90, 0x84, 0x21, 0x08, 0x42, 0x10, 0xC0, 0x00, 0x88, 0x42, 0x10, 0x84, 0x21, 0x08, 0x40, 0x00, 0x84, 0x21, 0x08, 0x42, 0x10, 0x84, 0x40, 0x00, 0xC2, 0x10, 0x84, 0x21, 0x08, 0x42, 0x40, 0x00, 0xA1, 0x08, 0x42, 0x10, 0x84, 0x21, 0x40, 0x00, 0x90, 0x84,
0x21, 0x08, 0x42, 0x10, 0xC0, 0x00, 0x88, 0x42, 0x10, 0x84, 0x21, 0x08, 0x40, 0x00, 0x84, 0x21, 0x08, 0x42, 0x10, 0x84, 0x40, 0x00, 0xC2, 0x10, 0x84, 0x21, 0x08, 0x42, 0x40, 0x00, 0xA1, 0x08, 0x42, 0x10, 0x84, 0x21, 0x40, 0x00, 0x90, 0x84, 0x21, 0x08,
0x42, 0x10, 0xC0, 0x00, 0x88, 0x42, 0x10, 0x84, 0x21, 0x08, 0x40, 0x00, 0x84, 0x21, 0x08, 0x42, 0x10, 0x84, 0x40, 0x00, 0xC2, 0x10, 0x84, 0x21, 0x08, 0x42, 0x40, 0x00, 0xA1, 0x08, 0x42, 0x10, 0x84, 0x21, 0x40, 0x00, 0x90, 0x84, 0x21, 0x08, 0x42, 0x10,
0xC0, 0x00, 0x88, 0x42, 0x10, 0x84, 0x21, 0x08, 0x40, 0x00, 0x84, 0x21, 0x08, 0x42, 0x10, 0x84, 0x40, 0x00, 0xC2, 0x10, 0x84, 0x21, 0x08, 0x42, 0x40, 0x00, 0xA1, 0x08, 0x42, 0x10, 0x84, 0x21, 0x40, 0x00, 0x90, 0x84, 0x21, 0x08, 0x42, 0x10, 0xC0, 0x00,
0x88, 0x42, 0x10, 0x84, 0x21, 0x08, 0x40, 0x00, 0x84, 0x21, 0x08, 0x42, 0x10, 0x84, 0x40, 0x00, 0xC2, 0x10, 0x84, 0x21, 0x08, 0x42, 0x40, 0x00, 0xA1, 0x08, 0x42, 0x10, 0x84, 0x21, 0x40, 0x00, 0x90, 0x84, 0x21, 0x08, 0x42, 0x10, 0xC0, 0x00, 0x88, 0x42,
0x10, 0x84, 0x21, 0x08, 0x40, 0x00, 0x84, 0x21, 0x08, 0x42, 0x10, 0x84, 0x40, 0x00, 0xC2, 0x10, 0x84, 0x21, 0x08, 0x42, 0x40, 0x00, 0xA1, 0x08, 0x42, 0x10, 0x84, 0x21, 0x40, 0x00, 0x90, 0x84, 0x21, 0x08, 0x42, 0x10, 0xC0, 0x00, 0x88, 0x42, 0x10, 0x84,
0x21, 0x08, 0x40, 0x00, 0x84, 0x21, 0x08, 0x42, 0x10, 0x84, 0x40, 0x00, 0xC2, 0x10, 0x84, 0x21, 0x08, 0x42, 0x40, 0x00, 0xA1, 0x08, 0x42, 0x10, 0x84, 0x21, 0x40, 0x00, 0x90, 0x84, 0x21, 0x08, 0x42, 0x10, 0xC0, 0x00, 0x88, 0x42, 0x10, 0x84, 0x21, 0x08,
0x40, 0x00, 0x84, 0x21, 0x08, 0x42, 0x10, 0x84, 0x40, 0x00, 0xC2, 0x10, 0x84, 0x21, 0x08, 0x42, 0x40, 0x00, 0xA1, 0x08, 0x42, 0x10, 0x84, 0x21, 0x40, 0x00, 0x90, 0x84, 0x21, 0x08, 0x42, 0x10, 0xC0, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xC0, 0x00,
0x00,
// USER START (Optionally insert additional static data)
// USER END
* _aDialogCreate 0x009001E
{ WINDOW_CreateIndirect, "Win_Monitor", ID_WINDOW_0, 320, 250, 320, 240, 0, 0x0, 0 },
{ GRAPH_CreateIndirect, "Nm_Deg_Graph", ID_GRAPH_0, 6, 59, 315, 176, 0, 0x0, 0 },
{ IMAGE_CreateIndirect, "Device_Logo", ID_IMAGE_0, 6, 8, 40, 40, 0, 0x00200020, 0 },
{ ICONVIEW_CreateIndirect, "Connect_Show", ID_ICONVIEW_0, 59, 9, 40, 40, 0, 0x0, 0 },
{ TEXT_CreateIndirect, "Task_Show_Text", ID_TEXT_0, 105, 8, 90, 40, 0, 0x64, 0 },
{ TEXT_CreateIndirect, "Time_Show", ID_TEXT_1, 201, 12, 60, 30, 0, 0x0, 0 },
{ IMAGE_CreateIndirect, "Menu_Icon", ID_ICONVIEW_1, 277, 8, 40, 40, 0,0x00200020, 0 },
{ TEXT_CreateIndirect, "Nm_Value_Text", ID_TEXT_2, 93, 66, 100, 25, 0, 0x0, 0 },
{ TEXT_CreateIndirect, "Deg_Value_Text", ID_TEXT_3, 93, 91, 100, 25, 0, 0x0, 0 },
{ TEXT_CreateIndirect, "Num_Value_Text", ID_TEXT_4, 94, 119, 100, 25, 0, 0x0, 0 },
{ TEXT_CreateIndirect, "N.m_Title_Text", ID_TEXT_5, 34, 67, 40, 25, 0, 0x0, 0 },
{ TEXT_CreateIndirect, "Deg_Title_Text", ID_TEXT_6, 36, 95, 40, 25, 0, 0x0, 0 },
{ TEXT_CreateIndirect, "Num_Title_Text", ID_TEXT_7, 36, 120, 40, 25, 0, 0x0, 0 },
{ TEXT_CreateIndirect, "Effect_Show", ID_TEXT_8, 281, 189, 30, 30, 0, 0x0, 0 },
// USER START (Optionally insert additional widgets)
// USER END
* Static code
* _GetImageById
static const void * _GetImageById(U32 Id, U32 * pSize) {
switch (Id) {
case ID_IMAGE_0_IMAGE_0:
*pSize = sizeof(_acImage_0);
return (const void *)_acImage_0;
return NULL;
// USER START (Optionally insert additional static code)
// USER END
* _cbDialog
const void * pData;
WM_HWIN hItem;
U32 FileSize;
int NCode;
int Id;
// USER END
switch (pMsg->MsgId) {
case WM_INIT_DIALOG:
// Initialization of 'Nm_Deg_Graph'
hItem = WM_GetDialogItem(pMsg->hWin, ID_GRAPH_0);
GRAPH_SetBorder(hItem, 0, 0, 0, 0);
