查看: 354|回复: 1
[emWin] 窗口管理对比
发表于 2024-11-11 15:40:09 | 显示全部楼层 |阅读模式
WM_CreateWindowAsChild(xPos, yPos, xSize, ySize, WM_HBKWIN, WM_CF_SHOW | WM_CF_HASTRANS, _cbWin1, 0);
GUI_CreateDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), _cbWin2, hParent, 0, 0);
_cbWin1 ,_cbWin2,这两个回调函数实现机制有啥区别?
我想在 WM_CreateWindowAsChild 的_cbWin1 管理按钮、文本框等操作,找到了例程序(如下),但是不知道ID_BUTTON_0 是什么时候被注册的?
static void _cbWin(WM_MESSAGE * pMsg) {
  GUI_RECT   Rect;
  int        Id;
  int        NCode;
  int        ReleasedItem;
  int        ActiveWindow;
  switch (pMsg->MsgId) {
  case WM_PAINT:
    // Draw a thin black frame around the SWIPELIST
    WM_GetClientRect(&Rect);
    GUI_SetColor(GUI_BLACK);
    GUI_AA_DrawRoundedRect(Rect.x0, Rect.y0, Rect.x1, Rect.y1, 5);
  case WM_NOTIFY_PARENT:
    NCode = pMsg->Data.v;
    switch(Id) {
    // If the button gets released we start an animation
    case ID_BUTTON_0:
      switch(NCode) {
      case WM_NOTIFICATION_CLICKED:
        _CreateAnim(&_hAnim, &_Data, _AnimSwipeInOut);
    case ID_SWIPELIST_0:
      switch (NCode) {
      // An item has been reeleased
        // Receive the ID of the item which has been released
        ReleasedItem = SWIPELIST_GetReleasedItem(pMsg->hWinSrc);
        ActiveWindow = SWIPELIST_GetItemUserData(pMsg->hWinSrc, ReleasedItem);
        // if it is different to the active window or not present
        if ((_aDataWindow.ActiveItem != ActiveWindow) || (_aDataWindow.Data.Dir == 0)) {
          _DoAnimation = 1;
          // If it is not displayed already, create an animation
          if (_aDataWindow.Data.Dir == 0) {
            _CreateAnim(&_aDataWindow.hAnim, &_aDataWindow.Data, _AnimMoveWindows);
          // Remeber the active window
          _aDataWindow.ActiveItem = ActiveWindow;
  default:
    WM_DefaultProc(pMsg);
发表于 2024-11-11 16:24:16 | 显示全部楼层
WM_CreateWindowAsChild麻烦,需要单独为这个窗口上创建控件。
GMT+8, 2025-6-11 08:08 , Processed in 0.332515 second(s), 24 queries .
